New project... Boredom is a curse... Lol
  • Boots Whirlygig
    • 560
    • Granville Ohio USA
    Ye shall be named Tenacious rifleman btx! How much smaller, and are you using same P-38 power? :pop
      This one is a 4' wingspan. So I'm looking at going with 3s power. I'm hoping with the smaller motors I can mount them in the rear and keep a respectable CG setup. So far it seems to be working.
        Getting close
        • mr.frankenjet
          Eat, sleep, FLY FLY FLY !
          • 448
          • Virginia, USA
          looking good, keep up the good work !
          rc flyin addict
            Now it's a waiting game for parts
              Good news! Power system is installed! Just a couple more pieces and she's ready to test also added a crow mix for the drag rudders
                Elevons and drag rudders are set up. Pics and video to come
                    Question of the day is, hand launch, or throw the gear under it :D
                    • RRHandy
                      Instructor Pilot
                      • 895
                      • Lilburn GA
                      Looks good. :Cool:
                      AMA 424553
                        Thanks will see if it makes it to the air today. It's cg is set to what the flying wing calculator says so hopefully we see success
                        • Dewey H Lee
                          WARBIRD JUNKIE
                          • Apr 2015
                          • 919
                          • Fayetteville NC. US
                          Hey rifleman is she up and away. Hope your still at the field wringing it out. Got my fingers crossed for a successful report.:Cool::Cool:
                          Dewey l
                          • mr.frankenjet
                            • 448
                            • Virginia, USA
                            Gear ads weight and wings land well as belly landers. You could make a launch cart for it to fly off from and belly land it if you have a little pavement to roll off . If you decide to hand launch mix a a few mm's of up ele to launch as wings tend to dip before they get on step. I use the spring trainer switch so I can dump it quickly with one hand as I throw with the other.
                            good luck !
                            rc flyin addict
                              Hand launch i can't get enough elevator to get it flying. Doesn't dive but just doesn't have the elevator in time to lift her off
                              • crankestein
                                • 316
                                I saw a few YT videos where the guy had some kind of a rail take off platform. He built it at an angle and the wing would shoot straight up in the air.
                                Your project seems very good, for now its a C until you make it fly, pending a possible A, and if you land it with no scrapes is a 100% and a cookie.
                                Kudos my friend, I leave the building to others, I do the flying and crashing...
                                • mr.frankenjet
                                  • 448
                                  • Virginia, USA
                                  Maybe with the down thrust angle it would be necessary to add additional "launch up-trim" till she gets on step. Also ck the cg is on w zagi method . Keep on keeping on, kudos for taking this on yet again. Happy landings.
                                  rc flyin addict
                                    Will do
                                      Also think my battery I'm using doesn't have the capacity to run both motors as one slows down rapidly after only a couple seconds running. So I'm gonna look at better battery size and c rate
                                        Rifleman......that statement just :Confused:me. If you are running both motors (ESC's paralleled) with one battery, how does only one motor slow down :Thinking:
                                          I'm not sure what it is. I've already changed out one of the escs still did the same, unless I have a motor going out
