New project... Boredom is a curse... Lol
    I had wondered how much counter balance weight you were gonna need to offset the mass of those motors that extremely aft.
    Now looks like a good time to do a redesign using your shaft drive that you proved out on your 39 to get those motors back up near the CG similar to the full size.
    Redesign...........blue foam.......... cheap............we're rootin for ya............:Cool:
      Absolutely, I actually had thought about a redo like that. The interesting thing is it can be done with this plane And I would think possibly easier than the P39. I will try flying this as is, and then if it's really not there go for the long shafts
      • mr.frankenjet
        Eat, sleep, FLY FLY FLY !
        • 448
        • Virginia, USA
        Great save Rifleman !
        I have used this method in the past to build and check cg on flying wings, works great
        good luck on the re-maiden !
        rc flyin addict
          Cool I like that, and it makes sense.
            Frankenjet, after using that method, the black dot is the CG location as of after adding the lead.
            • mr.frankenjet
              • 448
              • Virginia, USA
              Great, I have used this to test wings of known CG and it came out spot on. There are some calculators out there as well you could use to compare to be sure. It makes sense to me weight would need to be added forward with 2 motors aft.
              rc flyin addict
                This is what I used to find the location I needed on mine. http://fwcg.3dzone.dk/
                • Boots Whirlygig
                  • 560
                  • Granville Ohio USA
                  Hey rifleman, I'm getting ready to mount my retracts and wondered if you reinforced the mounts or just glued the pockets to the foam?
                    I bought the P38 plastic pockets and used 15 minute epoxy. That seems to hold up really well, as it's the same method I used for the P39 as well
                    • mr.frankenjet
                      • 448
                      • Virginia, USA
                      did the 2 cg methods come out with close results ? ?
                      rc flyin addict
                        Right about dead on results, I'm pretty stoked
                        • mr.frankenjet
                          • 448
                          • Virginia, USA
                          Sweet :)
                          rc flyin addict
                          • doctormike
                            HobbySquawk Moderator
                            • Oct 2013
                            • 1260
                            • Santa Fe NM
                            Glad you got your CG. Bet she'll fly now! Doc
                            • Dewey H Lee
                              WARBIRD JUNKIE
                              • Apr 2015
                              • 919
                              • Fayetteville NC. US
                              Cant wait to see it get off the ground now. Dont be bashful show it like you did before..i respect that.:pop
                              Dewey l
                                Will do, take two this weekend
                                • Dewey H Lee
                                  WARBIRD JUNKIE
                                  • Apr 2015
                                  • 919
                                  Looking forward to it Rifleman. Huraaa.
                                  Dewey l
                                    Hooah!
                                      Take two didn't get off the ground before the plane broke in two halves​. I will take the opportunity to endeavor into the long shaft option... Looks as though the weight was more than it could hold up to. Not giving up, a few spars and a couple of long shafts will begin planning today.
                                      • mr.frankenjet
                                        • 448
                                        • Virginia, USA
                                        Hang in there, looking forward to seeing the shaft design
                                        rc flyin addict
                                        • Dewey H Lee
                                          WARBIRD JUNKIE
                                          • Apr 2015
                                          • 919
                                          Sorry to hear that Rifleman. Hang in there man and keep us updated.
                                          Dewey l
