nice work ! :pop
New project... Boredom is a curse... Lol
RM.......actually was looking for you to show a close up pic of this setup. Do they also function as ailerons too??Aaaaahhh very simple setup really, joining 3 pushrods with a wheel collar 2 to both control surfaces and one back to the servo. Added an easy connector to the servo arm no set screw. Leave space behind the easy connector for it to slide back when it's engaging the opposite rudder but add a brake spring from a RC nitro car to keep tension on the rudder when closed and you have a poor man's setup for a drag rudder system. :)
PS don't forget to solder the joint of the pushrods as well for extra security.Warbird Charlie
Oh sorry and no these don't these are just outboard rudder systems. Single servo. For what you want I would think you could have a spring loaded surfaces that can be switched activated. and would require two separate servos. I have no doubt can be created to work together as you could run the stock servo as your ailerons and set this system up mid surface and open and close them the same way, using the spring to keep them closed yet will still actuate as ailerons. That would be my idea on that. Because if I had given them that second servo operation I know the rudders would do that as wellComment
Close up of my drag rudder system, my thinking is, if you were to use standard aileron hinges this would easily work on the A10 setup you're wanting to do. It'll be interesting seeing your results.2 PhotosComment
Thanx for the close up RM, gives me an option. Won't know more whether decelerons will be an achievable mod until I actually have the beast in hand.Warbird Charlie
Just ordered blue prints for an 82" Horton 229. I'll probably have them reduced a bit. rifleman..you're an inspiration!!!;)DocComment
OV, a buddy and I were talking about it, he was thinking use a crow mix with it. So seems like alot of options and possibilities exist. I hope it works, that would be awesome! Doc, make it large and proud my friend! :DComment
Doc, if you build with foam, Lowe's has 4x8' sheets from 1/4-3/4inch thickness. Home Depot has similar foam only pink instead of blue to a full inch thick. Also 4x8'. That's why this foam has become my go to building material.Comment
Now ready for testing and tuning. Taxi test was great. Moment of Truth, this Sunday, fly or die!Comment
