New project... Boredom is a curse... Lol
  • mr.frankenjet
    Eat, sleep, FLY FLY FLY !
    • 448
    • Virginia, USA
    nice work ! :pop
    rc flyin addict
    • Boots Whirlygig
      • 560
      • Granville Ohio USA
      Genius. :Cool:
        Aaaaahhh very simple setup really, joining 3 pushrods with a wheel collar 2 to both control surfaces and one back to the servo. Added an easy connector to the servo arm no set screw. Leave space behind the easy connector for it to slide back when it's engaging the opposite rudder but add a brake spring from a RC nitro car to keep tension on the rudder when closed and you have a poor man's setup for a drag rudder system. :)
        PS don't forget to solder the joint of the pushrods as well for extra security.
        RM.......actually was looking for you to show a close up pic of this setup. Do they also function as ailerons too??
          Oh sorry and no these don't these are just outboard rudder systems. Single servo. For what you want I would think you could have a spring loaded surfaces that can be switched activated. and would require two separate servos. I have no doubt can be created to work together as you could run the stock servo as your ailerons and set this system up mid surface and open and close them the same way, using the spring to keep them closed yet will still actuate as ailerons. That would be my idea on that. Because if I had given them that second servo operation I know the rudders would do that as well
            When I get home I'll take pics of what I mean, just run really short control horns.
              Close up of my drag rudder system, my thinking is, if you were to use standard aileron hinges this would easily work on the A10 setup you're wanting to do. It'll be interesting seeing your results.
                Thanx for the close up RM, gives me an option. Won't know more whether decelerons will be an achievable mod until I actually have the beast in hand.
                • doctormike
                  HobbySquawk Moderator
                  • Oct 2013
                  • 1260
                  • Santa Fe NM
                  Just ordered blue prints for an 82" Horton 229. I'll probably have them reduced a bit. rifleman..you're an inspiration!!!;)Doc
                    OV, a buddy and I were talking about it, he was thinking use a crow mix with it. So seems like alot of options and possibilities exist. I hope it works, that would be awesome! Doc, make it large and proud my friend! :D
                      Doc, if you build with foam, Lowe's has 4x8' sheets from 1/4-3/4inch thickness. Home Depot has similar foam only pink instead of blue to a full inch thick. Also 4x8'. That's why this foam has become my go to building material.
                        I also added a small wire strut to prevent prop strikes
                          And I'm scratching that, found a way to make it retractable
                          • doctormike
                            • Oct 2013
                            • 1260
                            • Santa Fe NM
                            Is the pink and blue the same kind of foam? Doc
                              Yeah, the only difference is the company brand name. The actual foam is identical
                                Here's actually 2" thick board. http://m.homedepot.com/p/Owens-Corni...-45W/100320352
                                  This is what I used https://m.lowes.com/pd/STYROFOAM-Com...ge-R-4/3125297
                                    https://youtu.be/buCsC42LvLw retractable tail wheel complete
                                      Now ready for testing and tuning. Taxi test was great. Moment of Truth, this Sunday, fly or die!
                                        Gonna test fly then finish it up after I know she'll fly well.
                                        • Boots Whirlygig
                                          • 560
                                          I like the scale retractable tail wheel!
