  • This is for the guys who already have received there F4. Does it like a heavy or light battery?
    Meridian Aeromodelers
    • Originally posted by Torkrollin View Post
      I always default to heavy on first flights.
      • I am going to fly it with Roaring Top 6250's and go with it a little forward of the CG in the manual to start with.
          Ryan had some good advice based on his experience back in post 849.
          • Alpha,
            Still waiting for the 3DPUP stl files
            • Originally posted by bandit View Post
              Alpha,
              Me too...now that I have a printer. :)
              • Received mine last night. No issue with assembly and it’s now ready to fly. Just for kicks, I recalibrated esc since the motor didn’t start spinning until about 1/8 stick.
                Only my second EDF. After the A10, I had the F4 ready in 1/3 the time. Seems all the motion jets follow the same method in assemble.
                John
                • I know this isn't going to get past the scale police but I like it...
                  I've always loved the scale nozzles of the F-15 and when I saw the first pics of the F-4 I thought they might work on it.
                  Click image for larger version  Name:	20180320_170317865_iOS.jpg Views:	1 Size:	108.5 KB ID:	124172
                  Click image for larger version  Name:	20180320_170332522_iOS.jpg Views:	1 Size:	119.7 KB ID:	124171
                  I pried the plastic nozzle covers off with a pick then cut the foam on the stepped edge which is just slightly larger than the diameter of the F-15 nozzles after you remove the fuselage end (see pics). After cutting the foam off I cut a slot around the edge to allow the lip of the new nozzle to fit in then glued inside the slot and around inside the nozzle.
                  Click image for larger version  Name:	20180320_170134414_iOS.jpg Views:	1 Size:	114.4 KB ID:	124175
                  Click image for larger version  Name:	20180320_170357723_iOS.jpg Views:	1 Size:	110.7 KB ID:	124176
                  Click image for larger version  Name:	20180320_170709576_iOS.jpg Views:	1 Size:	108.7 KB ID:	124173
                  Click image for larger version  Name:	20180320_172657959_iOS.jpg Views:	1 Size:	125.1 KB ID:	124174
                  Click image for larger version  Name:	20180320_203619564_iOS.jpg Views:	1 Size:	115.3 KB ID:	124169
                  Click image for larger version  Name:	20180320_203523357_iOS.jpg Views:	1 Size:	124.1 KB ID:	124170
                  Click image for larger version  Name:	20180320_203542590_iOS.jpg Views:	1 Size:	93.4 KB ID:	124167
                  • Thanks MRC for getting my new main spar out so quickly !! Adding the Hyperdyne LED A /B strips inside exhaust nozzles and runnIng wires up channels I made to vertical stab cavity before I glue empennage on then y’ing them to single controller should look great I’ll post some pics
                      That looks great!!
                      • Guys, as you should with all models be sure and pull the fan and check the ESC wires.
                          Tired,
                          kind of new to EDF, other than making sure wires are connected and not making contact with fan, any other pointers? I did pull hatch cover and didn’t see anything alarming, followed by a spool up.
                          John
                          • Here's what I found when I pulled the battery hatch on mine. OOPS
                            • Originally posted by john2kx View Post
                              Tired,
                              John
                              On occasion, the plugs from the motor will barely be seated to the ESC wiring. I use color coded heat shrink on all three leads (after a rotation check) to secure them on all my models. Also, checking the ESC mounting is important so nothing moves out of the airflow or gets sucked into the fan. I have had the motor and fan units have loose screws too, so check them and the fan to motor screw as well...
                              • Originally posted by bill34207 View Post
                                Case in point for ESC mounting!! :saywha
                                  Tired,
                                  John
                                  John, Hardway nailed it:Cool:
                                  • I dare say either this or the 80mm A10 will be my first eff in 8 years since I last bought a few while stationed in Germany
                                    • :Straight-Face:
                                      Mine was the same way but it’s all good now :Cool:
                                      • Center drop tank mod, I put a center drop tank on my A-4 so I had an extra tank.
                                        • Hey TiredIron, I think those transplanted turkey feathers look great. Saw these today in Michigan. The transplants are more impressive.
