Does anyone have an extra drop tank or a pair of drop tanks for the F4 Phantom that they'd like to sell or don't need. I am configuring them to a turbine powered L39 Albatros which did not come with the drop tanks. The scale of the turbine is a little larger, but the Freewing Phantom tanks will work.
Thanks guys!FMS P-51B 1400 mm
Durafly T-28
1875 mm B-17 (lost in midair with FW-190 at Bomber Field)
Flyzone DE Havilland Beaver
Durafly 1200 mm F4U Corsair
Take one step forward two steps back. Removed the masking tape and will have some touch-up to do. Red came out ok put need to paint white back in places. Wasn't sure this would work as it's tedious to mask. Want to keep all the paint per my scale colors and the Callie graphics were a little off. It will be fixed just more detail hours.
Fighter pilot,
I have some extra F4 tanks that Davegee sent me. If you pm your mailing address I can send to you next week.
Best Regards, Rex
Isn't that always the way it goes painting over foam! I feel your pain and frustration. My friends who did cruises on aircraft carriers have told me that by the end of a long cruise, the corrosion detail have roughly painted on the aircraft where the paint chipped off and they look gawdawful in some cases. You're not alone with having to repaint these parts. When you're done, I don't suspect most people or judges would even see what it looks like now.
Hang in there!
davegee
Thanks Dave,
I used the baby powder and it works well but I pressed the teeth mask with a popsicle stick and it stuck to the underneath paint. Goes with learning new ways. The baby powder works great if not in small spaces. Thinking about your 47 sliding canopy and I think a jack screw servo would be best, It is fairly small and gives a direct push/pull open or closing. small enough to fit underneath and not restrict electronics. A 3d slider track with a slider bar would work. The slider could be designed to hook to the jack screw and be part of the turtledeck canopy brace that slides with the canopy.
I guess if the navy had to touch up paint that makes mine more believable, that's my story anyway. LOL
Best Regards, Rex
That's beautiful work, Elbee. The P-47 wouldn't be all that different using a similar rack/pinion idea.Originally posted by Elbee
Corsair: Simple Rack/Pinion, if there is space.
Least amount of moving parts, though probably heavier overall.
A carriage for the canopy base and much trial and error fitment.
All doable depending on your will to do it.
Best, LB
davegee
You never came back but I do. Ground mail looks like $17.55, round up to $20 for gas to take it to the Post Office.
Originally posted by Fighterpilot View PostDoes anyone have an extra drop tank or a pair of drop tanks for the F4 Phantom that they'd like to sell or don't need. I am configuring them to a turbine powered L39 Albatros which did not come with the drop tanks. The scale of the turbine is a little larger, but the Freewing Phantom tanks will work.
Thanks guys!
The High School kids have come thru again. I need to go to school and pick up today. A little gluing to do but pieces are all there. Don't forget to ask your schools if they need projects to learn making 3d parts. The kids get to see finished parts at the final assembly.
So progress is progressing and even using baby powder paint still pulls up requiring touch-up between color lines. Not much but a headache. Best Regards, Rex
After picking up the ladders and tank drop, I tore everything off that didn't look like ladders. sanded, primed, painted silver then a couple coats of hair spray. Next after drying I painted the yellow. Will let this dry overnight then take a toothbrush and water and rub the yellow down in wear spots. Also installed the fuselage mount for the centerline tank.
Best Regards, Rex
Thanks Elbee,
Lots of little things getting done. Going to paint the red on gear doors and stab tips today. Opening canopies are great but the angles of the sills to the fuselage are off in the STL. very tedious but using heat gun lightly I am bending bending to conform, takes time and going slow.
Best Regards, Rex
and it's just 1 small part
