Official Freewing 64mm Lippisch P.15 Thread
  • JayP
    And one more, complete with touch n go off grass
  • JayP
    Got a couple decent videos of the little p15 today.
  • thumbs
    Ha funny. My biggest planes are 30" except the Dora at 33". I even fly a little 15"er. Now that you have to keep in close. LOL Thanks heavens for stability controls.
  • themudduck
    Originally posted by thumbs View Post
    LOL I really cant rip this thing around. Most of the videos show the Lippy at full throttle ripping up the sky. I don't have the room for that. I need it to fly slow to medium speeds. How do you find it does at those speeds? Im glad Exviper clued me in on the reflex and got me to be able to get it programed in my DX.
    thanks for chiming in.
    Hey there,
    Well I guess you certainly won't want the 4-cell. I think it flies just fine at lower power settings, and it glides very well. I would suggest the 1500 3-cell, and with this lighter battery you should be able to cruise around at half-throttle easily. Its a small plane and it gets really small in the air in a hurry, but if you fly it closer in at lower throttle settings, you'll be happy with it I'm sure. With low power, you may find that you can leave the reflex in or experiment a bit with that. When launching you do need a higher power setting to get it going, once its flying you can throttle back.
  • thumbs
    [QUOTE=themudduck;n254511]Hey Thumbs, I've been watching the conversation... I thought I'd jump in, I have flown the Lipp with the 2200 and it does fine, but makes the plane considerably heavier. It flies better with a 1500 or 1800. I use the 2200 when its windy, the extra weight seems to help it cope a little better. I find that when I'm using the 2200 it doesn't seem to provide a great deal of additional flight time (I have to use more throttle probably because of the extra weight).
    The reflex trick certainly works.
    Thanks. As we were talking about above I just got a Dora with a 3s 2200 battery. I was kinda hoping I could share some batteries between the two. It does make sense the 2200 needs more power for flight. Again I have a few 3s 1500's I may just try. Exviper stated they may not work well considering the sag. I'm just trying to get some commonality to my batteries. And being able to charge a couple of batteries at the same time rather than having to go through two charging cycles for two different capacity batteries. Kinda gettin out of hand. LOL I really cant rip this thing around. Most of the videos show the Lippy at full throttle ripping up the sky. I don't have the room for that. I need it to fly slow to medium speeds. How do you find it does at those speeds? Im glad Exviper clued me in on the reflex and got me to be able to get it programed in my DX.
  • themudduck
    When I have a flying buddy available, I have him throw the model at about a 60-degree "up" angle for the launch - and by the time the plane levels out after it's "dip", its flying fine. So that's another technique you can try. Of course it helps if you have a buddy with a good arm!
    By the way I've also flown this plane with a 4-cell 1800. It scoots like a bat outta hell.
  • thumbs
    This is the way I have it setup on my DX8 for reflex. Mix 1 for the Gyro on the Ger R knob..Idono maybe this will help someone.
  • thumbs
    Crap. I edited my last post but it didn't edit. What you said is exactly what I did and it works. I tried to edit the post to let you know. When I throw switch a the box in the elevator bar moves and the elevator on the plane is raised about 3*. Everything else works fine. I tried to let you know what I did but again it just didn't go through. Sorry about that
    I had to figure what the heck was goin on. Then I realized what the problem was. At least now I can dial in the reflex in the P15 if I get it. I think Ill leave it on the 190 and not use it unless I have to. I should probably take a pict of the proper setup and post it in case someone is reading this thread. It may help them set the DX properly, or at least the way I did it.
    Ha no offense about the old. Got ya beat by three years though. LOL I like figuring these things out if I can. Keeps ya thinking. I learn better by figuring it out. The problem with the manuals is the assume you know something maybe ya don't. Also, in my case, they never address what i am trying to figure out. I run into that all the time. The internet is my resource. There is no one around I know of that flies, no hobby shops, nothin.
    Well still waiting for some decent weather. If its not windy its raining. Supposed to be 15 to 20 tomorrow.
    What battery do you find works the best in the p15? Do you think the 2200 Admiral would be a good choice or to heavy?
    Anyway again thanks for all the help.
    You have to tell the TX what "A" is controlling (or not controlling). In your case, you want switch "A" to affect AUX1 but you haven't told it that yet. Normally, AUX1 is for flaps and that's controlled by that long switch on the front of the TX. On my DX8, that's switch "D" by default. If you are going to use AUX1, you have to tell it what switch you want to control it. You are using switch "A" but that's normally for gear, which you are using the knob to control (according to the picture you put up). You are getting all your switches and knobs and ports all jumbled up. The TX can't figure out what you're trying to tell it to do. You need to go into port assignment and switch assignment to straighten all that out. Aren't you using the knob to control the gear channel to control the master gain on your gyro? You have to tell the TX NOT to use switch "A" for gear in that case because right now, it seems you are commanding the gear channel with BOTH switch "A" and the knob. That's confusing the heck out of the TX if you try to use switch "A" for something else.
    It might be helpful to read the manual for the transmitter to understand what all that means. In essence, you're jumping several steps ahead without learning the steps you jumped over. It's somewhat hard to teach you all the steps over the internet. It's something that must be learned by reading or by trial and error or by another person in your presence who knows what to do when told to "do a mix for reflex and put it on a switch". Then that person can actually show you.
    For now, it might be better to just count the ELE trim clicks when you get ready to launch the plane. Then unclick it once the plane is flying. I hope I'm not offending you by insinuating that you are "old" (as you already stated). That's not my intention. I'm 70 years young myself.
  • thumbs
    Having trouble getting the reflex to work on myDX. I think I set mine up like the picture you took above. The difference is my gyro is in mix 1 so I am trying to program it in mix 2.
    I go to Mix 2,
    Aux 1 elevator, rate 0%-----25% offset 0%
    then I trie to set it up on switch A
    When I flip the switch the box in the Ger moves from -100% to 100% Nothing moves in Aux 1
    When I plug the receiver in the elevator does not put in the reflex. I know I am doin something wrong but there must be a step here I am missing. Again when I flip switch A the indicator in the Ger bar moves not the one in Aux1. It may have something to do with the 0% for the bar on AUX 1. Idono thanks
  • thumbs
    Yeah I was watching a video about the hand launching of the P15. The guy said the same thing about the reflex. I think he trimmed it into the elevator. He showed the trim on the plane. Not much like you said just a couple or so degrease. I can see it would be much faster and easier to program it into the mix. I guess I could just hold a couple of degrees into the elevator but that would be hard to duplicate each flight. I'll try it again tomorrow to try to program the DX. I am hoping and waiting for better weather to get out. If no very windy its raining. LOL I won't be flying the Dora as of yet. I want to some flight time in before that. Haven't been flying for a month or so.
    That little tailpipe piece is just straight, not angled up. When you get this plane, you'll notice that the exhaust tube is not uniform in thickness, top to bottom. That difference in thickness causes the exhaust to go down, which is in effect, producing down elevator. That plastic is just enough to deflect some of the exhaust back up or at least, reduce the amount that goes down.
    The 3 degrees is a guess. You may find it needs more or less based on your launching technique.
  • thumbs
    Ok I kinda get the idea. Not sure right now how to program in the 3 degrees as of yet. I plan to hand launch the Dora. The vast majority of my planes are hand launched but they are all much lighter than the ones we are talking about here. Just for the heck of it, and to get a feel for the power, I held the Dora vertically and gave it full throttle. Although it would not vertically clime out of my hand it did become about neutral hanging on the prop. As I recall some people are launching the Dora "underhanded". It seems to have enough power to pull out given a reasonable push. The P15 is a different story it seems. I am listening to you when you tell me about the pros and cons of the P15 but that thing is so darn cool I can't help but want one. I think my fields are large enough to fly it. If not there is still plenty of farm land around to get permission to fly.
    The mod to the exhaust is that just a straight piece of plastic or is it slightly angled up. Does just a little extra length at the bottom of the exhaust do the trick by itself? I'm at 465' ASL here not quite so thin as where you are.
    I kinda like hackin around. LOL I may just try to put some reflex in the Dora. Maybe not to fly her that way but just to see if I can do it.
    First attempt was a failure. Actually it cut even my gyro off until I unplugged it and plugged it in again. On switch A where the gyro used to be in the gear mix the switch still moves the gear meter or gain but nothing happens. It works find using the R Knob though.
    Ok Ill see if I can fine it and figure how to get it programed. I think the gyro is programed into the gear. All this is new to me. LOL Anyway will the Dora benefit from 3 degrees of reflex programed into the mix?
    Is that why I see the P15 dip when it is hand launched on the youtube videos? I know part of it is the low air speed and basically stalling until the dip where it can gather just that little speed to get the lift.
    You can pick any unused switch to do the reflex. Just make sure it's not assigned to something else. If it's a 3-pos switch, just skip over the middle position.
    HINT: This is for my Lippy. I use the gear switch, but you could use (eg.) AUX1 or AUX2 and choose any unused switch. Just assign the switch to AUX1 or 2.
    The dip is caused by a couple of things. 1. It's doesn't have enough airspeed in the beginning so it falls. 2. The holes in the bottom of the plane act like a vacuum cleaner and suck the plane down at low airspeed and high air intake. I've modified my exhaust with a piece of overhead projector plastic to direct the exhaust upward so as to push the tail down when in flight. This counters the vacuum effect on the most part. The reflex also helps to keep the nose up when launching.
    I don't know if I've posted this video here but anyway ..........................................
    You can see at .04 seconds into the video, I flipped the switch and both elevons went up a little. You can also see the small piece of clear plastic on the bottom lip of the exhaust hole.
    As you see, it still took a dip before it flew. I'm at 3500' elevation.
    In answer to your question about the Dora using some reflex on the launch. That depends on how you throw it, if you throw it. Most prop planes don't need reflex on a hand launch. Torque roll on a hand toss is more of a problem.
  • thumbs
    I will have to get back to you on the reflex thing. I have no idea. I get the idea of a bit of up trim at the beginning then backing off in flight. Is that done with the trim buttons.or is that on a switch? What I mean is give it a few clicks of up trim get er up to speed then click to adjust for level flight. Is that how its done?
    You can do it with trim but that takes so much longer to undo. 3 degrees of reflex (UP elevator) is a lot and as the plane starts to gain airspeed, that trim has to come off quickly. I used to count the number of clicks of trim I put in so that I can quickly count the number of clicks to take it out. Now, I put it on a switch. In the case of the P.15, it's a mix that's put on the gear switch. As I said:
    PS. Hand launched planes like the P.15 can really benefit from about 3 - 5 degrees of "reflex" programmed to a switch for the launch. Get it flying and flip the switch to turn off the reflex.
  • thumbs
    Thanks again. As I get deeper and deeper into the muddy waters of the hobby I learn a lot of what not to do.LOL Flying my little homebuilts really don't have any specific needs. Getting into these bigger heavier more powerful planes creates a fast learning curve. Anyway, if I decide to go the P15 route I have to try to consider the costs at least at the beginning. Thats why I was trying to be able to use one battery for both planes. I will be using the Admiral 3s 2200. I will be gettin a battery with the P15 so I will have two I can interchange with the two planes. The Zippy batteries are 3s 1500"s 35C. I wanted to use them until I could get a couple of batteries more suited to the needs of the planes. I guess the better way to go is to use the Zippy's in the Dora and save the Admirals for the EDF. Although I don't know about the ability to get the right CG on the Dora with a lighter battery.
    I have no idea yet as to how I may go with this EDF thing I may even wait a while. Who knows LOL
    The recommended battery for the P.15 is a 3 cell, 1000 - 2200mah. The P.15 needs good airspeed to start flying. If you use low C batteries and if you can't do a really good, fast throw, you'll end up throwing it into the ground. It won't have sufficient thrust if you do a "girlie" throw. Zippy batteries are "OK" but it depends on the "C" rating. Low C Zippies don't perform well for EDFs. Zippies sag very quickly and can't keep up when demand is high.
  • thumbs
    Wondering how the P15 flies on a 3s 2200 battery? The reason I ask is I have a Dora that uses that battery and it would be nice to be able to use these batteries in either plane. I have a few 3s 1500 Zippy batteries I could use in the P15 but a longer flight time would be nice.
    There is only 2 UMX (Ultra Micro) jets on that page. The rest are not.
