3d Printed Part Sets - Freewing F-4D Phantom II
    You can keep the peas, I don't like them so much. LOL
  • themudduck
    Well I thought that my post was simply funny, but I've deleted it to keep the peas. Now everyone will wonder what's up...
    Hey, isn't it exciting that apmech1 has come up with all this stuff? He's keeping my printer very busy. :Love:
  • apmech1
    I did make a block cad drawing (can insert it into every drawing) of the male FW mounting tabs full scale (I add them to the model after i scale the model down) and I have test printed (spiral) the 600 g tank, mk84, suu23, bullpup, walleye, maverick, & rocket pod. And they all attach to the FW 90 F-16 pylon just fine. So I am happy I dont have to re make the wheel every drawing. :)
  • brk6188
    Agree, this isn't an all boys thread in my house
    TMI mudduck. :Silly:
  • apmech1
    Thanks
    Wow, those look awesome! And I love that you have added the mounting tabs that Freewing uses. Makes swapping out loads very simple!
  • apmech1
    MK84
    https://www.thingiverse.com/thing:2870751
  • apmech1
    AGM-65 Maverick
    https://www.thingiverse.com/thing:2870711
  • apmech1
    AGM-62 Walleye
    https://www.thingiverse.com/thing:2870628
  • apmech1
    AGM-12 B Bullpup. https://www.thingiverse.com/thing:2870558
  • apmech1
    Just printed it, they are so small that the overhang doesn't affect it much.
    Originally posted by apmech1
    I am using Cura to create the gcode. What version of simplify 3d are you using?
    Have you seen this?
    https://forum.simplify3d.com/viewtopic.php?t=7899
    I did some checking online and am now printing the outer layer only in concentric (VaseMode). How did you print the section with the mounting tabs without supports?
  • apmech1
    Could you print a replacement nose cone that would change the bird into an RF-4?
    Since I dont have the model yet, I would need the dimensions to scale it to, along with a diagram of the RF-4 nose cone.
  • apmech1
    I have tried to print a part concentric but it still tries to print the inside wall as well. I am using Simplify 3D and what is called Vase Mode. It turns off infill and supports and based on the description of it is supposed to just print the outer shell but what it ends up printing is the inner and outer walls and nothing in between. Do I just have something set wrong?
    Have you seen this?
  • EA-6B Geek
    Any suggestions or requests for 3d parts for these airplanes?
  • apmech1
    After assembling the fuel tank with spiral printed tank sections and the joiner rings with contact cement, no sanding, no filling, no paint or primer my tank comes in @1.9 Oz.
  • apmech1
    I added the flange files to thingiverse. Flange ring 1,2,3 the are in order from front to back. Note, these will only work with spiral or outer shell only prints.
    https://www.thingiverse.com/thing:2852099
    Here's a list of armaments for the F-4. Most of these can be found on Wiki, or Google Images.
    Armament
