  • salali
    I finally re-maiden my SU-35 after installing FMS Pro fans. Wow! What a difference. I was able to take off in half the distance from a grass field. In the air, amazing thrust! Thanks Airguardian for recommending. I didn’t try TV but am planning for the next flight.
    What rates are recommended as a good starting point for TV? I cure toy have everything to 100%.
    I bought this pre-owned so it’s not in the best condition but she’s still photogenic.
    I really hope this is a re-release soon.
  • fredmdbud
    Ready for it s debut at the field.
    2nd life of a wear-and-tear “FrankenFlanker” (mix of grey and desert fuselage parts) to a Test Pilots livery.​
  • kallend
    Originally posted by fredmdbud
    If they do come out with a new version of the 70mm Su-35, it will most likely be made of EPO, not EPP. This will result in a heavier plane - that's what happened when they re-did the F/A-18E with thrust-vectoring (V2). On the other hand, they would upgrade the EDF's to in-runners.
    The recent offerings also seem to have a lot more injection molded plastic parts ,which add weight. Example, the 70mm F-35 V3, which comes out heavier than the 80mm Mirage 2000 although both are EPO.
  • fredmdbud
    New livery in the works ...
  • fredmdbud
    Originally posted by SanExup
    They did kind of hit a sweet spot with the SU.
    If they do come out with a new version of the 70mm Su-35, it will most likely be made of EPO, not EPP (correction: EPS). This will result in a heavier plane - that's what happened when they re-did the F/A-18E with thrust-vectoring (V2). On the other hand, they would upgrade the EDF's to in-runners.
  • Airguardian
    Agreed. I hope they make a bigger one but keep the weight in check!
    In the meantime, I come with new exciting Flanker goodies for y'all to enjoy, hehehehe...
  • SanExup
  • kallend
    I did get to see one in the flesh the other day.
    I kept thinking, I wonder if they would ever do a new Su35. Twin 80s.
    If they do, I hope they don't make an overweight pig like some of the recent offerings.. . . .
  • SanExup
  • kallend
    I bet the owners pool is shrinking since replacements aren't available.
    Flew mine 2 days ago. Friend had his cell phone.
  • SanExup
  • Airguardian
    You guys are all too silent!
    :zipper_mouth:
  • Airguardian
  • Airguardian
    I think I outdid myself with this one...
  • Airguardian
  • paulrkytek
    SHARP SU35M
    Modified the canopy for a more conventional jet look:-
Name:	SHARP SU35-2.jpg
Name:	SHARP SU35M-1.jpg
  • Airguardian
    Congrats!
    Nice success! :D
    She's now officially become Sharp-35 !
  • paulrkytek
    Sharp Nose Su video
  • Airguardian
  • Airguardian
