It looks like you have the wing ailerons mixed with the tailerons? Will this work? When you move the Tx stick left/right you will get Aileron movement and Tail movement. But, when you move the Tx stick up/down won't you get Tail movement and Aileron movement?
For my Su-35 the wing surfaces act as flaps, not as ailerons. The tailerons with TV provide plenty of roll and pitch authority.
Not looking to do anything crazy like have each control surface have its own channel. Was wondering if I can make a 6 channel receiver work…. Was thinking this setup. Let me know what your guys thoughts are. Was just going to Y connect the TV with the tailerons and rudder.
1. Throttle
2. Aileron
3. Taileron 1/ TV (Pitch)
4. Rudder/ TV (Yaw)
5. Gear
6. Taileron 2/ TV (Pitch)
I think this will work… my biggest question is, is it hard to take-off and land with the TV on?
Probably will... but I'd recommend against it. You will add weight that detracts from the overall performance.
If you really feel like reinforcing something apply some epoxy coating to the forward end of the ducts, as those will likely see some abuse at some point in the jet's life and they are a pain to repair.
Or, if you want to go overkill... glass them.
I once WBPU coated with 18g/m2 one of mine... my second airframe. Looked gorgeous but took me two weeks and the jet only lived 72 flights (radio link failure and full send lawndart crash). Didn't feel like it was really worth it. I enjoy it much more by keeping it light and powerful.Leave a comment:
Do you guys think applying a coat of minwax on this jet will stiffen up the airframe? Or is it even worth it?Leave a comment:
thanks for the tip , it seams like a nice Technic to practice next time.
you should be mentioning sagrada familia ! :)
Its almost 20 years since I took my son to see Casa Mila ( great balconies ) and La Sagrada Familia, I wonder if it will be finished by 2026 ?My lil' tip about weathering. Don't use black for panel lines, but just a darker grey.
Ideally you do it as pre-shading, and then overspray with a lighter grey tone. You can then control the final result by adding more or less over-spray.
I'm from Barcelona so I know Gaudi ;)Leave a comment:
Is this you?
well, is everyone here is an architect ? because when i'm talking to my friends about those people they dont know what the h*ll i'm talking about :D
i think it will all come to that its a personal preference . i appreciate minimalism as much as i appreciate details ,but it depends on the subjectLeave a comment:
Exactly. Its whatever floats your boat or gets you flying.
Less is more but then Gaudi and Frank Lloyd Wright are more complex and interesting to look at so I suppose it depends on what you want to achieve and how you want to see it. My paint schemes become more complex and interesting in direct proportion to the number of times I inadvertently modify the shape of the model .
"Less is more" - Ludwig Mies van der Rohe.
Overdone panel lines shout out "I am just a toy".Leave a comment:
Don't overdo it. Subtle is better than overdone. Most real planes, even military, are well maintained. Take a look at a real one, the panel lines are hardly visible except over hatches and inspection plates.
thanks man i'm working on the weathering and metal sheets effects now
hahahaha u got it right into place ))
i did but since i painted it before checking the nozzles , i had hard time seeing the marks ( it was covered by paint )
