  • paulrkytek
    Originally posted by TangoVector
ID:	315600 It ain’t gonna be pretty…
    I have the same fans and servos and they both work fine. I fly off grass and have slightly bigger mains wheels but with upgraded oleos. Good luck with fitting the big wheel without a bit of re sculpturing or catching the doors or door servos on opening. I gave up on the doors and added small ventrals and landing lights to hide the line of the hole left.
ID:	315607Click image for larger version
Name:	SU35 landing gear view.jpg
  • TangoVector
  • Airguardian
    Have a few of those DMC809 but never got to try them in flight yet... they should be quite an improvement over the stock ones! ;)
  • TangoVector
    Finally had some time to start fixing my planes... I have upgraded the elevon-servos to Turnigy DMC809. They are quite small, but very quiet and with good precision. 3D-printed an insert to keep the servo snuggly in place. Nice to have the printer around, took me 10min to draw one and mirror it, and 1hr to print both.
    The new FMS 70mm 12b PRO's are also in place with 80A ESC:s. All that is left now is the nose-gear changed to Avanti version. Not scale but I prefer good grass capability since the grass is a little tall at the club sometimes.
  • Airguardian
    That would do it too... but balsa may be more user friendly for most :)
  • kallend
    Most importantly, need to glue a balsa wood planck to the front of the battery compartment so the foam that houses the nose gear doesn't break as easily.
    It may even break after this mod, but if you then glue the thing back in with epoxy, it's not ever going anywhere again :)
    I epoxied a layer of glass cloth over the foam at the weak spot.
  • Airguardian
    That's quite overkill... but whatever floats your boat. ( :
    (With the planck on the front end I think it's more than enough)
    Also a good idea to install a velcro more to the rear so you can secure heavy batteries (which need to go aft) properly.
  • radfordc
    This is what I did. Click image for larger version
  • Airguardian
  • radfordc
    Originally posted by aamz13
    Good to see it operate on grass. The field I am comfortable for maidens is a grass field. My yak 130 is put together, F-22 is next then its time for some vectored thrust on the SU-35. I will have lots of questions for sure
    Thanks again
    I made several modifications to accommodate grass ops: larger nose wheel (58mm vs 45mm original), 3mm plywood spacer under the nose gear retract unit, gear strut braces to help prevent strut bending.
  • Airguardian
    And remember to reinforce the nose gear as suggested! ;)
  • Airguardian
    It is grass capable but it may require some tweaking on your end to operate from grass.
    Test as is, and if you have problems, come here again... it's been covered extensively in RCGroups and I suppose here too...
  • aamz13
    Originally posted by radfordc
    First flights today. All went great.
    https://youtu.be/2GXn0copBzM
    Thanks again
  • Airguardian
    Still my favourite foamy... just can't beat it!
  • Airguardian
    Happy Friday y'all!
  • Airguardian
    Enjoy! ^^
  • T- Elbert
    Here are some nice shots of the su-35’s from my local club.
  • Airguardian
    FPV action begins on the second flight!
  • Airguardian
    Congrats Charles!
    The second landing was very smooth, looks like you have her dialed in! :)
  • radfordc
