  • Av8er278
    Does the F22 have a sequencer in it somewhere that I can’t see or is it built into the blue box?
    chrisk83 developed a support plate for the F-14 nose gear since the plastic retract mount tends to break loose and is difficult to get secured back in place. This plate mounts inside the battery hatch and uses M3x55mm screws and nuts through the retract unit to secure everything in place.
    The F-22 uses the same stock mount plate, and mine came loose again last weekend during an event. So I wondered if the F-14 mount plate support would work here. I'm happy to report that it does! I used M3x50mm screws as the distance between the mount and support plate is not as wide. I could have gotten away with 45mm screws but didn't have any on hand. The extra length of the screws does not interfere with the canopy hatch.
    Here's a link to the support plate on thingiverse:
    https://www.thingiverse.com/thing:4570836
  • Av8er278
    Originally posted by SanExup
    Entropy? Sorry, wise ass comment.
    It’s ok thanks for trying to cheer me up 😂
  • SanExup
  • Av8er278
    Well here I go again. Received my new blue board today and new boards for the wings. I replaced all of it and again when I put landing gear down and unplug plane and turn off transmitter like I would if changing batteries to fly again. I turn on transmitter and plug in batteries gear door closes on gear while still down. So I have to unplug gear door from blue board and use my servo tester to open it up to put gear up. Also with gear up when I plug in batteries gear door comes up which makes doors overlap but when switch is flipped doors open fine and gear goes down. Guess I’ll have to call Motion RC again. If anyone has any ideas I’m all ears. Thanks.
  • gooniac33
    Originally posted by prescott27
    Hello, I am looking to find some guidance on an issue I just had. I've been flying my Raptor for a couple months without issue. After a recent flight, I noticed that the positive leads in the EC5 from battery to plane melted. This broke the connector and I had it replaced. I flew again with a different battery and the same issue occurred, yet it didn't break the connector so I didn't/t think much of it. Finally, the third flight after the first incident, the jet lost power mid air and totaled on the ground. I discover that the positive lead had once again built up heat and melted the connector. I have only heard good things about the EC5 so I am confused as to where this buildup of heat is coming from. Motion RC didn't really provide an answer, they just said that the ESC is very reliable so it is probably not that. Thanks
    Bad solder or a bad connection. EC5 have done over 150amps with my planes and never melt. The one that did melt was a bullet with a bad connection...factory of course! LOL
  • mshagg
    It indicates a problem resulting in the connector being overloaded. A dry solder joint somewhere, perhaps an issue with the motor/fan unit preventing free movement or even the bullet connectors between the ESC and the motor.
    It's unsurprising it did not resolve itself.
    I would pull the entire powertrain and inspect it. Run the motor up with a wattmeter and see how much current is being drawn.
  • prescott27
  • Av8er278
    If all you have is a 6ch radio then yes use the included y cable on throttle.
    No I have a DX9 like you.
  • gooniac33
    Originally posted by Av8er278
    Thanks goonic33. I have the DX9 also. I just got a AR8020T receiver 8ch wasn’t sure if a 6ch was enough. So if I have the 8ch do I still need to Y to throttle? No worries on the order I completely understand I use to work also and know how it is. But I love retirement now. Thanks for the info.
    I've had a Prusa mk3 for a couple years now and love it!
  • downwindleg
    Thanks Pat. What do you think f the new 3D printers BTW?
    I'm sure this has been covered before but 1. where do the little water transfer decals go?
    2. any suggested changes in stock c.g. when you have the afterburner in place?
    1. See this post for what I did:
    2. Maintain the stock CG after adding the AB lights. May require moving the battery forward slightly.
  • downwindleg
  • Av8er278
    I always check with gear down, considering landing is the most critical time in a flight. You’ll get lots of other opinions including it depends on if the gear retract forward, rearward or to the side... in the end checking balance on the ground is just a reference and balance should be determined by how it flies.
    Great thanks Evan for all the help.
  • Av8er278
    When checking CG on the F-22 do you guy check it with gear up or down?
  • Av8er278
    Ah ok well that’s good. But I can’t do that when the door closes on the gear I can’t put gear up. I have to unplug gear door from blue box and use my servo tester to open it up so I can retract the gear. Then plug it back in and close the doors.
    I don't consider it a problem. does the same thing every time so I'm ok with it...
  • Av8er278
    May not fix it... On mine I transport gear retracted and when I plug in a battery the gear doors pop open and then slowly close. The gear themselves don't move.
    Wow sounds like just the two of us have gear problems. Well I hope new blue box will fix it.
