Thanks for the files Steve, and your work to get these mods done. Printing now!
3d Printed Part Sets - Freewing 90mm F-22 Raptor
Steve,F-22 Canopy Frame Modified.stl Here are the .stl files I have created to be able to make the opening canopy mod like I did it. Could the parts be improved upon? Absolutely. I was able to make a slight change to the tab on the underside of Alphas canopy frame to make for a stronger attachment with the pivot arm I designed. I am still learning Fusion 360 and had to have some help from a friend who is more skilled at it than me to make the change to the canopy frame and create the missing inlet cover but we both learned a lot in the process. I will try to put together a mod thread with more pictures and videos to help make it easier for anyone who wants to give the opening canopy a go. I have also included the missing Starboard Inlet Cover below. All together, with the 3D printed cockpit parts, stock pilot figure and a 17 gram metal gear servo the mod added just under 4 ozs. total to the stock canopy/cockpit tub. I did have to shift my batteries (8S) back a little more to get it to CG but it did without much effort.
Steve
many thanks for publishing those files, but the download is not possible. When clicking on one of the files published by Alpha in post #2, a subwindow opens with the choice to save the respective file. In addition, there is an icon left of each file plus the file size. Your attachments look different. When clicking on one of your files, nothing happens. When using the save option via the right mouse button I'm just getting an error message. Did anyone else succeed in downloading these files?
FrankComment
Try these.Attached Files- F-22 Canopy Arm Plate Left.stl (5.0 KB, 27 views)
- F-22 Canopy Arm Plate Support.stl (684 Bytes, 21 views)
PatComment
And here are the picture files I used for my instrument panel. The first is for the 5 main glass panels, and the second is for the glass panel in the center bottom. I didn't like my painting skills on the top center display for the radio settings, so I sanded down the face and used the third pic to show the detail.
What I did was take these pics and copy them to a Word doc. Then I sized them to fit the panel, printed them out, and glued them on. For the glass panels I first put on a couple layers of Minwax Polycrylic Gloss to give them some shine.3 PhotosPatComment
Pat, thanks for posting these images- I'll be using them. :Cool:And here are the picture files I used for my instrument panel. The first is for the 5 main glass panels, and the second is for the glass panel in the center bottom. I didn't like my painting skills on the top center display for the radio settings, so I sanded down the face and used the third pic to show the detail.
TomComment
Finishing the final little details on the F-22 today... I opened the box on December 8th, and had one little delay after another. And of course Christmas and all that entails, as well as a cold and a gout flare-up! But to top it off, I had an intermittent short in one of the wiring harnesses and finally found it!! Glad it was on the ground and not at 100 mph and 200 ft AGL...:Scared: I didn't add lights to the wings, but I did nav lights and strobes and a beacon on the fuselage. It looks pretty cool! Looking forward to a smooth maiden... A pic or two to follow later today. Happy New Year to everyone, and I hope your Christmas was blessed with joy and love and lots of family and friends!!! JerryComment
I just tried to individually upload them to the thread. Never done it before so wasn't sure how it would work. I sent them separately to Pat so how did you upload them Pat? I want to know how to do it right in the future.
Steve,
FrankComment
Will the glass panels and increments actually light up?And here are the picture files I used for my instrument panel. The first is for the 5 main glass panels, and the second is for the glass panel in the center bottom. I didn't like my painting skills on the top center display for the radio settings, so I sanded down the face and used the third pic to show the detail.
What I did was take these pics and copy them to a Word doc. Then I sized them to fit the panel, printed them out, and glued them on. For the glass panels I first put on a couple layers of Minwax Polycrylic Gloss to give them some shine.Comment
Steve,
To attach, click on the button that looks like a piece of paper with a paperclip. It's on the right hand side. Then just choose the files to attach.PatComment
I thought about doing that, but it would have required carving out some foam as there is a solid wall right behind the instrument panel. But I did test it before installing, and yes light will shine through the paper, making them look illuminated.PatComment
Thanks Pat. I did that individually instead of as a group. Not sure how that would have mattered but, live and learn.Comment
Steve,
On your original post it looks like you did the "Post Link" option (which is right next to the "Share Photos" button and also looks like a paperclip) instead of the "Upload Attachments" option which is on the right next to the Advanced Editor and Smilies buttons. Probably too late to go back and edit your post as the forum only allows you twelve hours to do so. But no worries, we have them attached now.
And once again, thanks for creating and sharing these files!PatComment
To give a little more detail about which pictures I used for what, I outlined them in red. For the armament panel (bottom center) I had to stretch it sideways just a bit to make it fit. I'll post up a PDF shortly that will have the correct sizing so that all you have to do is print and cut.3 PhotosPatComment
