  • mr.frankenjet
    Ditto Frank, I have reverse, same vintage
    Mine is from last Christmas and came with Revers......!
  • f4u ausie
    I agree needs Lotsa elevator. To get off grass.. think I have around 120 percent
  • Flamingo
    maiden flight went well
    setup NX8 w/ar10360T+, HRB 6Ah for 5min flight time, battery back with separate wood tray as in previous posts, 110A max, reverse on moment switch w/90% throttle
    she requires 100% elevator for lifting front wheel with full flaps at landing Click image for larger version
    still need remaining decals and windows
    ready for Oppingen airliner meeting
    pic show also my original maxx from BKK to CNX
    Originally posted by Charlie Tuggle
    Viper, you are the smartest dude, lowered the trim setting halfway, lowered throttle cut to - 113, motors spool up.
    If I try setting any other setting on trim or throttle cut the motors stay running, leaving the good settings, will that effect anything.
    again thank you so much.
    I glad you got it to work. Now that you have it working, it might be wise to do another throttle calibration and then re-bind it to make sure it all stays set that way. The re-calibration is to ensure that your throttle responds almost immediately when you move the throttle stick - maybe have about 1/8" free play before the throttle starts up.
    BTW, you'll know the ESCs have reverse IF there is a single yellow wire that runs with the triple throttle wires. The reverse wire will end with it's own connector. The yellow wire is the "signal" wire.
  • Charlie Tuggle
  • Jetfrank
    Greets Frank
  • f4u ausie
    Mine is 6 months old and has no reverse
    .... Who knows when it was actually produced
  • Charlie Tuggle
    Thank you for the help, I will do that, not sure if I have reverse.
    Does it have reverse? Nothing in the description (including the version info) or the description or pictures of the ESCs/ BEC show it.
    You're right, it has no reverse, just OPTO ESCs. I put reversing ESCs in mine and with so many of the new jets coming with reverse of late, I thought it might be something they did for the AL.
    Can someone explain the throttle and ESC wiring setup on the AL37, all controls work and lights but not the motors. Tried setting calibration nothing.
    Thanks Charlie
    If you have a current generation AL-37, it will likely have 2 throttle leads and 2 reverse leads (single wire). "Y" the throttle leads together and plug into throttle channel. (Deal with the reverse leads later if you want reverse.) Try lowering throttle trim to it's lowest position and adjust throttle cut to the proper level (if Spektrum -130), rebind. Now do throttle calibration. If you don't get the proper initial beep tones, you'll have to do the calibration for each throttle separately. IE, unplug one throttle lead, do calibration. Then plug that one back in and unplug the other one and do calibration again. Plug that one back in, power cycle and test throttle action. Hold the plane down.
    Since you have controls the BEC is getting power.
    That narrows it down to the three motor wires going from the ESCs to the motors not being connected or the ESCs not getting the signal to run the motors. Verify the motor wires are connected first,
    Since the BEC is separate from the ESCs that power the lights and receiver and you have that look at the lead from your receivers throttle port (should not be the lead that goes to the separate BEC) to the MCE blue box and make sure it is in the right port there, I think it's marked AUX. If that is right make sure the two ESC throttle leads are going to the MCBE on the other side, also marked AUX.
  • Charlie Tuggle
    Thanks Charlie
  • GliderGuy
    Hi Xviper…Basically what fits. Larger chokes have more inductive reactance, so a large one around multiple wires is fine. If no room, then smaller chokes on single wires will have to do. Think of the wires coming from the ESCs as RF noise transmitter antennas, so keep the chokes as close to the ESC as possible. The motor side leads of the ESCs don’t spray out much RF noise (as I am told). So, you don’t need chokes on the motor leads. However, put them there if you want to.
    Other than that, put small ones near servos that are powered by LONG leads to block noise from getting to the servo.
    It’s like a game of “noise, noise…where can I block RF noise”. The smaller chokes weigh next to nothing. I put them lots of places.
    If you can’t place the chokes right next to the ESCs, then place them as close as possible.
    Any lead from the ESC or BEC going to the RX (throttle, reverser) should have a small one.
    And remember, high current ESCs splay out more noise. Example, I don’t use chokes on my FW P-38.
    PS…Gotta love springtime! Got in 26 flights today / beautiful weather / mix of 80 mm A-10 V2, PJ-50 and P-38.
    To those (ie, GliderGuy) who are well versed on the topic of RF Chokes ............................
    I'm in the process of upgrading my 80mm F-14 with the latest high output fans and reversing ESCs. I'd like to install the RF chokes while everything is easily accessble. On the triple ESC wires to EDF, which is better - to have one small choke per wire or a large one that encompasses all 3 wires? Same for the twin ESC to battery wires - 2 small ones or 1 larger one over both wires? And would the chokes be better closer to the ESC or the battery? Does it matter where along the wire runs the chokes are?
  • GliderGuy
    I have rolled and looped mine a few times. It takes a lot to achieve these "stunts". Needs lots of throw and lots of space and planning. I don't do this anymore. I think it stresses the wings quite a bit, especially now that the plane is quite old.
    I agree. My #1 bird ended up with severely cracked wing foam after a lot of loops, rolls, snap rolls and inverted flying. I eventually stopped flying it due to the increasing wing bending during stress maneuvers. My #2 bird...ran it into a light pole after a few flights...UGH. My #3 bird got a treatment of added carbon spars glued to the top skin on the inside of the wire run channel. This prevented "most' of the wing cracking and flex. Alas...a radio transmitter glitch ended the #3 bird's flying after a dive straight in from 200 ft up.
    So...I am now flying #4 AL37 (just gotta have an AL37). #4 has the same owner added wiring channel carbon square rod spars glued to the inside/top wing skins. It's a frankenbird built from the #1 bird's fuselage and tail feathers but with newly purchased wings and nacelles. I've decided to treat it like a lady and not do any stressful maneuvers. Any wing cracking is unlikely, and I am not seeing any after several months of flying her gently.
  • mr.frankenjet
    Thanks Guys, standby for the flight report
    I did 2 rolls on Saturday first time. I agree doesn't really like it. Doesn't look right anyway
    All the passengers spilled their orange juice.
  • f4u ausie
