Here's what needs to be added to make a real Slovak AF '0921':
1. "Bird Slicers" (4) aft of the radome, 2. Antennae aft of the cockpit, 3. ACL on the spine and under port engine nacelle plus two more landing lights 4. False canopy decal (or is it included?) 5. White tail light on port vertical stab
MRC, may I ask again for close up shots of the cockpit section?
Thanks
Frank
Some people swear by the others don't care for them.
There is no one size fits all.
I'm not a fan.
Mike\"When Inverted Down Is Up And Up Is Expensive\"Comment
Hey Pilot Jum and welcome to Hobby Squawk.
We have been flying it with an Admiral 10 channel RX with a satellite and a hobby eagle gyro. There is a ton of space inside to really mount your electronics how you wish, but we went like this
Hope this helps!
Thanks
Frank
The cockpit is entirely plastic except for the headrest. Like any other darker painted EPO aircraft, if she sits in the sun too long, you'll get gatoring. It was unavoidable on our end though as it's been 95 degrees steady here in GA and when you got to get pictures of a model, they always look the best in full sunlight. Hard to run it under cover when your groovingComment
Thanks, James! Good to hear that most of it is made from plastic. I’ll start working on a 3DP seat/headrest. The box behind the seat with all these circuit breakers will be another subject. I’ve got the BH Fulcrum here (which is about 10% larger) for measurements.
With a large and expensive jet like this, would anyone recommend a dual-receiver setup for redundancy? Most of the large scale guys at my club do this. Also, I've had bad luck with the blue junction box in the past. I see it's being used in the MiG-29 as well. Hopefully they're reliable now.Comment
It's really a personal choice.
Would I go out and buy a dual receiver setup just for this? Nah.
However I wil definitely run more than one satellite and have a dedicated rx pack in this bird.Comment
Interesting thought on the rx pack? You think servos can run 2s Or a separate BEC stepping down voltage?Comment
I am so looking forward to receiving this Beauty.
Great design Alpha. Maybe while we wait you can do a video on how she is made.Comment
On the Spare Parts page it says the ESC package comes with an 8A BEC. Probably the same one currently used in the other twin 80mm power sets. I've never had a problem with them on other jets.PatComment
Independent rx packs are very common.
NiCd/NiMh and 2s LiFe packs are no problem for standard voltage servos and components. They don't run at peak voltage at all times.
Regular 2s Lipos would need some type of regulator.
Easy answer, just stick with LiFe packsComment
:muscle:.
The livery is perfect, the model is gorgeous, ordinance is great, OEM mods coming. What's not to love? Best, LB
