    I agree the B-2 is a very distinctive cool plane.
    I'm still the only one that has flown one at our field. Usually when a new plane, especially an EDF comes out there are 10-15 of them by now...
  • GliderGuy
    I still haven't put any more flights on mine... I moved on, latest build is another FW 80mm F-14 with the MiG-29 power system. It's way more fun...
    Hi Evan…
    Thanks for the feedback on the spin.
    But, But….the B-2 looks sooooo cool in the air!
    I understand. Since installing a gyro, the PJ-50 is now my favorite all-around. Great performance, sips battery power, pretty good acrobatic ship, and the best “windy day” bird I own. (Now there’s a switch in opinion from when I was about to give up on it….prior to adding the gyro.)
    I did, reported results very early on, I think my first day out with my B2. Didn't work for me, just keeled over into a nose dive. I didn't try many times and someone may get it to do it. I was just curious and when It didn't work after a couple tries just gave up. It does a really nice stall turn or hammer head, depending on what you call it.
    Question: Had anyone tried to spin the B-2? Or…for that matter any tail-less flying wing?
    She seems to have ample control authority to do a normal stall-spin entry (full up elevator <and hold it> at the stall followed by the application of full rudder). Not gonna apply aileron….it risks overdriving the drag rudder servos. Just a classic elevator/rudder spin.
    At the risk of being repetitious, MANY more flights in light wind (typically early morning) and no turbulence conditions have been made with 100% success. This is the key to enjoying the B-2. In these conditions, landings are a non-issue and easy to do using the techniques described in my prior posts.
    I am not gonna push it. When the conditions change, I put her up and fly other birds. Flying the B-2 is a HUGE amount of fun, but only within restrictions on the conditions. Too risky otherwise!
  • GliderGuy
  • GliderGuy
    Heads up….
    A main gear stopped retracting fully. Close inspection ruled out the servo. The truck rotation was acting draggy. The application of dry lubricant solved the problem. You may want to consider getting ahead of this on your B-2 and lube your trucks’ pivot points.
    For those of you who have stated that you are hesitant to fly your B-2, restricting your flying to light wind days is a good solution. I’ve not had ANY problems with landings on light wind days….enjoying flying the B-2 and confident that the landings will be non-events. You may want to reference my prior posts on the technique I use to land it consistently successfully. #1134 and #1136
  • avanti127
    ALL-NEW Freewing B-2 Spirit - Page 88 - RC Groups
    Look at posts 1310-1333....
  • GliderGuy
    Update to posts #1106 and #1134….
    Many more landings since #1134, and I am learning still.
    Here’s what I am figuring out. There is a cadence one develops for landing the B-2. Prior to figuring out the cadence, you are likely gonna not make some good landings (mess up a nose gear servo or two).
    However, if you’ll force yourself to only fly in light winds, you can practice enough to develop your cadence without destroying too many nose gear servos….maybe none at all.
    Yesterday, I flew in 7 mph winds but it was not smooth air. In my prior posts, it was stated that if the gyro is moving the controls more than a little = unsafe to fly. The controls were jiggling a lot, on the first flight yesterday. Sure enough, near the ground a wing dropped before either me or the gyro reacted. This almost resulted in another damaged nose gear servo. Luckily…only a slight bend resulted in the worm drive gear, and the nose gear still retracts OK.
    While you are learning the B-2, stick with calm or light winds and non-turbulent conditions.
    So, once you develop the cadence (this takes practice), every landing will be a success and made with confidence (in good flying conditions) AND you can start really enjoying the B-2.
    I know….one may ask why put forth the effort?! I consider RC flying a challenge. The B-2 deserves the effort. She’s so unique and fun to fly.
    Caution: Until you practice enough to develop the landing cadence, you will be dollars (and ego) ahead to fly her only in near perfect conditions.
    Example: Not to brag, offered as proof of what I say….each of the 10 landings made this morning were perfect and with no heart rate increase. TONS OF FUN!
    Got in a few more flights on the B-2 this weekend at Warbirds Over Texas. 10 flights so far and only one occurrence of the bounce, which was recoverable and damped out. Moving the nose gear forward and reducing the AOA a from stock may have helped make it a bit less prone to this issue.
  • GliderGuy
    As an update to my post #1106, I have developed a consistent landing technique. Many landings have been made since that post and no bent nose gear servo.
    1) Light winds only….less than 5 mph. If you see her gyro twitching the controls more than just a little on a fly-by, it is TOO windy/gusty for landing safety and without risk.
    2) Get her into ground effect 6 inches or less and do everything in your power to hold her steady / slowly inch down and DON’T let her touch down. As she slows, you will end up on most landings with full nose up elevator as the main wheels touch…just like a full scale Piper Cub tail dragger landing.
    3) When she finally touches, she’s done. Sticks without bouncing.
    4) Minimize any cross wind amount.
    I am using an Admiral 6000 which sits about an inch off the tray to the rear like James’ video.
    In light winds, you can do the above consistently. She’s easy to land and control in ground effect.
    I enjoy flying the B-2. However, only on light to calm wind days. Doing otherwise risk$ a busted nose gear servo or worse (cartwheel, etc.).
    Edit: 06/11…Got out at sunrise to beat the HEAT advisory and to enjoy almost calm winds. Made 7
    B-2 flights before the wind began to blow. No landing issues at all using the above technique. It works!
  • jasmith41
    Originally posted by kallend
    It should be self evident but having one gyro (E52) feeding another (Assan) (or vice versa) is not going to be successful in any context.
    I've seen people with an AS3X/SAFE receiver connected to a Eagletree gyro and wondering why they were getting weird results.
    Even i know that would be problematical...🤣🤣🤣
    Took my B-2 out to Bomber Field for their warbird event this weekend, and won the award for best electric aircraft! Also got a few beautiful in flight photos courtesy of Lee Ray. Really enjoying how well this models floats around at low throttle.
    I might be able to put all this plan into action, but I think I'm faced with the grim reality that even with a steering gyro, it will probably be confounded by the ruts and bumps in our very rough runway. After my last flight where my plane hit a bump on the takeoff roll and launched into the air prematurely, almost losing it, I don't think the gyro would have done much good. I think I might fly it a few more times from this runway, but after that, the chance of losing the airplane is too great to risk if and until I can find a better place to fly from.
    Do thank you for all the effort with this gyro, though.
    davegee
  • kallend
    The drawing in post #1123 has been revised.
    Originally posted by davegee
    Thanks, XVIPER! Once I get my Y cable hopefully next week sometime in the mail, I'll use this diagram to try and put the cables all in the right places! I'll keep you posted how it goes.
    Best,
    Davegee
    Just for the moment (until you get the Y), just don't plug in the lead that goes to the E-52 (upper part of Y). Only connect the lower part of the Y just to check everything out on the Assan and steering direction. Your air rudders (drag rudders just won't respond to rudder input. Once you get the Assan working correctly, you can go back and wait for the Y.
    The receiver goes to the gyro and then to the control board…
    Right. The line I drew from the RX to the control board (upper part of Y) should go to the E-52. That part shouldn't change. It's only a mistake in my drawing.
    Do the Y out of the receiver. One side to the Assan and the other to the male to male and into the gyro. The steering servo plugs into the Assan.
    NOTE: I failed Art 101.
    As you can see, the steering servo no longer connects to the control box but goes directly to the Assan. The Assan gets the steering input directly from the RUD channel of the RX via a Y. The nose retract lead gets pulled out of the control box and hooks directly to the Assan. You then need a patch lead (or short extension) from the nose retract pins to the Assan.
    Best,
    Davegee
    Click image for larger version  Name:	IMG_4112.JPG Views:	0 Size:	78.2 KB ID:	347566
    Drawing has been revised.
