  • TwistedGrin
    I ordered up:
    Two Nose Wheels:
    BenchCraft 55mm (2.2") x 15mm Treaded Ultra Lightweight EVA Foam Wheel for 2mm Axle
    BCT5016-098
    Two Main Wheels:
    BenchCraft 64mm (2.5") x 24mm Treaded Ultra Lightweight Rubber PU Wheel for 3.1mm Axle
    BCT5016-077
    Two Main Wheel Struts:
    Freewing Stinger 90 Main Landing Gear Strut
    FJ305110811
    Two Main Wheel Axles:
    Freewing Stinger 90 Main Landing Gear Wheel Axle
    FJ305110812
    Two Main Strut pins (Just in case):
    Freewing Stinger 90 Main Landing Gear Connecting Pin
    FJ305110810
    I have not dissasembled the main retracts to see what size the main strut pins are....betting they are 5mm. If they are the 90mm Singer struts may need drilling out for 5mm.
    Will report back on what parts interchange or need cutting drilling......
    Hoping to have good luck as a couple pilots have reported with thier own hacks for Grass Operations (Short nap well manicured grass runway)
    TwistedGrin
  • Radar-Guy
    Another option for people owning a lathe
    Hallo, gratuliere zum Maiden auf Gras! Vielleicht ist es auch möglich, nur mit dem Bugrad den Anstellwinkel zu erhöhen? Grüße, Bernd Danke, Bernd! Bei mir war lag es auf jeden Fall am Rollwiderstand der Hauptfahrwerke. Da aber jede Graspiste anders ist, empfehle ich erstmal einen Testlauf...
    OK, negative on the Corsair mains as well as they are 85mm tires and the max I can use is 60mm. I may do what Frank did and go with T-45 mains and the "frankenstrut" and 50mm nose wheels.
    Originally posted by Radar-Guy View Post
    Not just some foam….
    OK, so negative on the Mig-29 retracts. I wonder if the Corsair mains would work. I need to find some measurements as I don't have one.
  • GliderGuy
    Originally posted by primodus22 View Post
    Has anyone snapped the nose gear strut yet?
    I bent the worm gear in the nose gear servo….replaced the servo. Tried to save a bounced landing. Bad choice!
    Should have added power and gone around.
  • Radar-Guy
    Originally posted by crxmanpat View Post
    I think I'm going to investigate whether or not the Mig-29 mains could be used as a replacement for grass ops. May require the removal of some foam (hopefully at the mold marks) but should allow the gear to be fully enclosed in the well with the doors completely closed. I flew my Mig off the grass for the first time last Saturday with no issues, so hoping this will work for the B-2.
    Click image for larger version  Name:	D8976EBE-69C4-4421-9A67-BE0721DB1984.jpeg Views:	0 Size:	65.3 KB ID:	344391
    Click image for larger version  Name:	94AF2EE5-AFEB-4FB6-BF9B-FA35F5DE6EAD.jpeg Views:	0 Size:	59.6 KB ID:	344392
    Originally posted by okcrcpilot View Post
    Take the battery hatch or one of the EDF covers to HD and they will be able to do a perfect match. The paint will be latex and will hold up quite well.
    Roger, that was my next step...
    Originally posted by Colorc View Post
    The servo cover is on the top of the wing. The screws are painted making it blend right it.
    Oh snap! Thanks!
  • okcrcpilot
    Originally posted by Aros View Post
    Hey folks, been gone for a few days, I apologize if I missed the post somewhere but does anyone have the dead nuts paint match numbers for this bird (or DC - Darn Close) I can take to Home Depot or Lowes? She's acquired some slight hangar rash already just from trying to get the clams set right for flight. Much appreciated!
    Why ask that way, do you expect it to snap? DO you have a B-2 that this has happened to?
  • primodus22
  • jasmith41
    Originally posted by Hugh Wiedman View Post
    Nice work Icarus the 2nd , not only did you get off grass in a short distance, it was WET grass, so kudos to Radar-Guy for the mods.
    For those of you interested in B2 historical information, the Smithsonian channel has a series called Air Disasters (great program which sums up my flying skills). This year one of the episodes is called "Stealth Bomber Down", from Season 17 (current), episode #3. It's well worth the view. It details the take-off crash of the Spirit of Kansas from the Guam airbase in 2008 which shut down B2 operations for several months and potentially could have ended the B2 program. There is outstanding real videos, interviews, analysis of the crash to determine the cause and insight into the most sophisticated aircraft in the world, which was quite fascinating to me (especially when you find out what brought it down). Also learned that the $44 Billion B2 program had 21 bombers in total (not sure if that's still current) and initially had 300 hand picked pilots in the group, the best of the best. Each B2 was named after a state, except two which were designated as the "Spirit of America" and the "Spirit of Kitty Hawk". I won't spoil it for anyone interested in watching it, so you'll have to see it for yourself, which IMO is well worth it.
    'great program which sums up my flying skills'... LOL You've never seen me fly before... you got nothing on me...
  • Icarus the 2nd
    thanks!
  • Icarus the 2nd
    Originally posted by viper1gj View Post
    Does anyone have a Home Depot touch up paint code color match for the B-2 paint?
    I made a mix with Tamiya airbrush colors:
    You need Tamiya XF-54 and add a little Tamiya XF-19 at a 20/1 ratio
  • Icarus the 2nd
  • Icarus the 2nd
    Originally posted by Warbirdfan29 View Post
    Well done G. !! :-) Kind Regards Jörg
    thanks a lot !
  • Colorc
    Also, does anyone have any idea how to remove the servo arm on the servo for the clam shells? There's no servo cover you can remove there and there's no tool I own that can get into that small area to unscrew the broken arm. Any ideas would be greatly appreciated!
  • kallend
    Originally posted by mshagg View Post
    It's worth reading the A3S3 V2 manual if you want to understand some of the settings in a bit more detail - the E52 manual skips over a lot of it.
    Link: https://www.hobbyeagle.com/manuals/A...al_v2.0_en.pdf
