Hi Radar-Guy,
Great job on the mods. I agree MRC should offer a grass operations upgrade kit.
She flies SLOW very well. Don’t be afraid to float her in. You were screaming fast!
Try this….assume 10 clicks from bottom is mid throttle
Reduce to about 25% power on downwind (still a lot of power)….don’t fear. About 5 clicks lower than mid-throttle at this point.
On base reduce 3 more clicks…to about 10% power. Stay with this setting until over the threshold. Plenty of power still for a gentle descent at 10%!!!! Don’t fear! Note you will need to hold a little up elevator as you reduce power. If she tries to settle in early, add a click or two of power if needed.
Go immediately to zero power over the threshold. She will glide into ground effect so slowly as you hold her off.
Using the above I used 1/2 or less of a 200 ft area including the roll out on pavement. She can land short. On grass, the roll will be sooooo short.
In strong winds you may want to reduce only 4 clicks from 50% for downwind then reduce 2 more clicks on base leg.
SLOW THIS BABY DOWN….you were way way faster than she needs.
Glad no damage. Think BIG WING = lots of lift = can fly slowly
-GG
-GG
