Great !! Glad to hear this. Got mine ordered and waiting to come in.
Official 64mm Freewing Banshee EDF Sport Jet Thread
Loving this Banshee with FPV. Had a 10-12 mph headwind this morning, but had to try out the Banshee again !!! Took out the 25 gm. nose weight, and had to place 2300 4S battery all the way forward. Practicing take offs and landings as i'm new to EDF. (126) Freewing Banshee FPV Cisne Il. 10-22-22 - YouTubeComment
This post is for Evan D. I read where you said the CG lines are nose heavy and that you balance it about 5/8" back of the lines. Is this for a 6S system or is it the same for the 4S system?Comment
I show the very slightest bit of up. I have mine set up in modes where I have separate trims depending on flap position. It's not a standard flap mix or setting in the flap menu. From no flaps to max I see a 2 digit increase in the number in my servo set up screen, I doubt the elevator is even moving.Comment
Had a brief break in the UK weather yesterday and managed to maiden the Banshee.
Started off with CG on the marks, but she wanted to nose down. Moved it back slightly and she flew very nicely, not super fast, but very steady in flight. It was perfectly calm.
Here's a brief video, nothing fancy, just feeling her out. Flew around six packs in total.
Greetings all. I just received my Banshee and it's my first edf. I have her all assembled and have run into a problem with thrust. When I advance the throttle all I'm getting is reverse thrust. I have not set up a switch for reverse thrust yet as I really had not planned to use it at first. I'm using a Spektrum AR620 receiver with a Spektrum NX8 transmitter. Am I doing something wrong or have I plugged something in wrong?Comment
Did you plug in the reverse ESC lead into the RX? If so, which channel did you plug it into? And what switch is associated with that channel? You may not have set up a switch for reverse, but depending on which channel you plugged it into, it may be defaulted to a switch anyway. Find out which switch that might be and flip the switch and see what happens.Greetings all. I just received my Banshee and it's my first edf. I have her all assembled and have run into a problem with thrust. When I advance the throttle all I'm getting is reverse thrust. I have not set up a switch for reverse thrust yet as I really had not planned to use it at first. I'm using a Spektrum AR620 receiver with a Spektrum NX8 transmitter. Am I doing something wrong or have I plugged something in wrong?
According to the manual, if you didn’t plug the reverse lead into the RX, the throttle shouldn’t work the way it’s supposed to.
(PS. I do not have this plane, just read the manual. My experience with reverse stems from other EDFs where I’ve added reverse.) Hopefully, someone who has this plane will respond to you.Comment
