View Post
Official 64mm Freewing Banshee EDF Sport Jet Thread
I'll ask again ....................................... Which channel did you plug the reverse lead into? Depending on which channel you used, you may not have to set up the switch. It may already be set up by default. It simply may be in the wrong position. Oh, and what radio are you using?Originally posted by morganjw1 View Post
Thanks for the info. I did have both plugs in different channels but had not set up a separate switch for reverse as I had not planned to use it due to our runway being very long. I plan to set up the switch today when I have a chance. Thank you for the info.
I had channel 5 open (usually for gear) so I used that for the reverse plug. I have all of my other planes throttle cut set up on the A switch and thats what is showing defaulted to. I'm thinking I just need to go in and set up a different switch.Originally posted by xviper View PostI'll ask again ....................................... Which channel did you plug the reverse lead into? Depending on which channel you used, you may not have to set up the switch. It may already be set up by default. It simply may be in the wrong position. Oh, and what radio are you using?
Then your reverse has been defaulted to the channel 5 gear switch. If you are also using that switch for throttle cut, then that is a conflict. Generally speaking, Throttle Cut is assigned to switch H on Spektrum. Put your TC on switch H and I'll bet your gear switch will be dedicated to only reverse and you will get normal thrust back in one of the positions. If you have only a 6-ch RX, then assigning reverse to another switch may not be possible because you've taken up all the channels. Switch H is usually for throttle cut and thus, does not use up another channel, leaving ch-5 free for only reverse. If you don't want to use reverse, then you'll have to play with the servo travel on that channel so both switch positions does the same thing - ie, forward thrust and NO reverse. You still can't use that same switch for both reverse and TC.Originally posted by morganjw1 View Post
Got it. I'm going to work on it later today. I really appreciate the info.Originally posted by xviper View PostThen your reverse has been defaulted to the channel 5 gear switch. If you are also using that switch for throttle cut, then that is a conflict. Generally speaking, Throttle Cut is assigned to switch H on Spektrum. Put your TC on switch H and I'll bet your gear switch will be dedicated to only reverse and you will get normal thrust back in one of the positions. If you have only a 6-ch RX, then assigning reverse to another switch may not be possible because you've taken up all the channels. Switch H is usually for throttle cut and thus, does not use up another channel, leaving ch-5 free for only reverse. If you don't want to use reverse, then you'll have to play with the servo travel on that channel so both switch positions does the same thing - ie, forward thrust and NO reverse. You still can't use that same switch for both reverse and TC.
As some may know I put a Arrows 6S fan and a different ESC in mine when I first built it. Free Wing came out with a series of new fans and the Banshee got one, the lowest power on of the series. These are really 65mm where the older fans were 63mm (it makes a difference) Anyway the new series had a low and high power outrunner and a low and high power inrunner.
I ordered the new high power 2500kV inrunner and upgraded sprung gear from RC Castle and got them today.
Numbers… stock low power 4S out runner was 57A 870W 990g thrust
The Arrows 6S was 49A 1135W 1290g thrust
Now it's 75A 1670W 1590g thrust
70% increase over stock. 50+g heavier.
The new gear are very nice but add another 27g.
- Likes 2
We have Banshee 6S upgrade power systems on the way for anyone who wants to make their Banshee insane! Specifically, we have a 2949-2300Kv motor with 12B fan which requires an upgrade to a 50A ESC. For those that want true Banshee insanity we have a 2949-2500kV motor with 12B EDF which requires an upgrade to a 60A ESC.
Caution to those going to the fans Tom just posted about. First they are 6S fans and the stock Banshee ESC is up to 4S. A 6S capable ESC is mandatory.
Second the 2300 draws a maximum 42A OUT of the aircraft. It will draw significantly more in the aircraft and a 50A 6S ESC should be fine but the 2500 in my Banshee is drawing just under 75A on a fresh charge so I suggest more than a 60A 6S ESC.
No plans for a PNP 6s version of the Banshee?Originally posted by Tom View PostWe have Banshee 6S upgrade power systems on the way for anyone who wants to make their Banshee insane! Specifically, we have a 2949-2300Kv motor with 12B fan which requires an upgrade to a 50A ESC. For those that want true Banshee insanity we have a 2949-2500kV motor with 12B EDF which requires an upgrade to a 60A ESC.
I had not planned on a 6S PNP Banshee. The original goal was to make a great flying sport jet which is easy to transport and reasonably priced. A 6S version does not change the "easy to transport" part but it does change the price. That said, if it is something all of you want, I can make it happen. At this point, it would be a post new year holiday project. Freewing is already going to be very busy until they shut down for their holiday. After their time off, they will be back in Feb which means it would be spring before we see it. It should be fairly easy to add a second version if the demand is there from all of you.
"If you build it, they will come."Originally posted by Tom View PostI had not planned on a 6S PNP Banshee. The original goal was to make a great flying sport jet which is easy to transport and reasonably priced. A 6S version does not change the "easy to transport" part but it does change the price. That said, if it is something all of you want, I can make it happen. At this point, it would be a post new year holiday project. Freewing is already going to be very busy until they shut down for their holiday. After their time off, they will be back in Feb which means it would be spring before we see it. It should be fairly easy to add a second version if the demand is there from all of you.
Question for you guys. If we do a 6S version, should it have the basic landing gear or upgraded shock absorbing landing gear with trailing links (which again makes it more $$ so think about your answers carefully)? We can always add shock absorbing landing gear as an optional upgrade instead of including it as well.
- Likes 2
I think make the whole plane a "high performance version" much like you did with the 70mm Bae Hawk and F16. Include the highest power 6s system and the trailing links. As long as you don't creep too close to the Vulcan price, I'd be in.Originally posted by Tom View PostQuestion for you guys. If we do a 6S version, should it have the basic landing gear or upgraded shock absorbing landing gear with trailing links (which again makes it more $$ so think about your answers carefully)? We can always add shock absorbing landing gear as an optional upgrade instead of including it as well.
I agree.
I really like my 2500 6S inrunner powered Banshee with upgraded gear but I am pretty sure there are few (maybe just the two I bought the parts for) flying like this....
