Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
    The mold prices on the 80mm are astronomical. Trust me, it's not like Freewing doesn't want to release an updated 80mm version. Personally, as much as I would want a 80mm with all these upgrades and latest tech, I am happy they are at least offering something that still gives you similar presence with a less-taxing wing load and more aerodynamic wing. I want one!
  • JamesonC
    Already asking for a V3...
    He'll get it before I get a V2 80mm.
    Originally posted by stitch
    Well was wanting one but not red, hoping they do this one with improved foam on leading edges around battery hatch like they been doing on there other planes. For that price I pass!
  • stitch
  • Quickstopdf
    Originally posted by freakbrother
    Why a V2 so soon after the initial release? Meanwhile the 2015 version of the 80mm, which could really do with a makeover, continues.
    Does the new wing fix the tip-stall issue? If so, can it be retrofitted to the V1?
    Yes! New wings can be retrofitted according to Wes on the video
    My opinion is that the 64 hasn't sold well (for the reported wing tip stalls maybe) while the 80 is still selling well. I'm waiting for a V2 80 with 2150's, 100A reversing ESCs and the rescue decal not upside down.
  • JamesonC
    A V2 of the 2024 released 64mm F14 instead of the 2015 released 80mm F14........someone make it make sense!!! Please do the V2 twin 80mm F14 already!!!!
  • freakbrother
    V2 has arrived! The finest flying foam EDF F-14 on the market. Click the link below to see what the hype is all about!
    Get yours ASAP, these puppies will not last, guaranteed.
    Freewing F-14 Tomcat Twin V2 64mm EDF Jet - PNP
    Buy Freewing F-14 Tomcat Twin V2 64mm EDF Jet - PNP online at Motion RC. Order online with fast delivery.
    Freewing F-14 Tomcat Twin V2 64mm EDF Jet - ARF PLUS
    https://www.motionrc.com/products/fr...plus-fj11421ap
  • EDF-Jetpilot
    Traumhaft schön!
    Congrats on the flights!
  • EDF-Jetpilot
    Meine F-14 Twin 64mm habe ich nun am vergangenen Samstag eingeflogen. Der Jet fliegt sehr gut, aber bei voller Spannweite ist er anfällig auf Strömungsabriss, wenn man den Landeanflug zu langsam macht. Ich habe diese Eigenschaft hoch oben ausgiebig getestet und habe Respekt, so zu landen. Ich lande den Vogel immer in der Mittelstellung der Flügel, ich habe die Schwenkflügel auf einem 3-Stufen Schalter und kann 100/50/0% Schwenkstrecke einstellen. In der Mittelstellung der Flügel, also halb gepfeilt, kann man die F-14 wie eine F-16 wunderbar landen und braucht keine Angst vor Stall zu haben, auch braucht man so die Klappen nicht, da man angestellt reinkommen kann. Geht auch bei Wind sehr gut!
  • EDF-Jetpilot
    I would first calibrate the ESCs, assuming you haven't. The only other possibility is maybe one of the ESC servo connections is in backwards.
    But pretty sure it's ESC calibration.
    Hey Evan... es hat geklappt, nun laufen beide EDF's, dir sei Dank für den Hinweis.
  • EDF-Jetpilot
    Danke für den Hinweis, das habe ich noch nicht gemacht.... häufig sucht man gleich zu weit. Das könnte wirklich das Problem sein, ich werde schauen.
  • EDF-Jetpilot
    Ich habe Gestern in meiner neuen F-14 64mm den Empfänger installiert und nach dem Binden festgestellt, dass der Motor rechts keinen Muks macht, linker Antrieb ist in Ordnung, der rechte geht nicht. Kennt jemand den Grund oder hatte das auch? Ich muss jetzt rausfinden, ob es am Regler oder am Motor liegt.
    Understood.
  • EDF-Jetpilot
    You got the 80mm not the 64mm....
    oh aufgepasst.... das Foto ist die 80mm ja, aber ich habe die 64mm gemeint, die habe ich auch mit 2 Piloten bekommen, nur gerade kein Originalbild dabei gehabt. ;-)
  • EDF-Jetpilot
    Genau, ich spreche hier immer vom im Thread hier offiziellen twin 64mm Version. Sonst drücke ich dies klar aus. :-)
    Originally posted by EDF-Jetpilot
    neue Lieferungen inkl. RIO
    Bei meiner Lieferung von vor 14 Tagen (Schweiz) ist der RIO, also der "zweite Pilot" auch dabei... das hat mich sehr positiv überrascht!
