Good to know, thanks but I have a few more comments/questions:
1) For the nose gear door board Do you just plug the nose gear retract servo and door servos into it and it acts as a sequencer? Isn't it this one? https://www.motionrc.com/products/fr...ard-107d007001
I'm essentially wondering if i can use it without the "black box" and it sounds like I should be able to from what you're saying
2) I'm glad it has light outputs, I plan to use lights eventually
3) I will be using the open channel for nose wheel stabilization or thrust reverse depending on what is needed more
4) What batteries have you used and what are your thoughts on the best size of you have flown it?
5) No soervo reversers needed for this, just wye's, correct?
