Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
  • ArmorBolt
    • Dec 2020
    • 72
    Did Chris and the Motion team mention which turbine size (X40, or SW80) they will make the F35C for. I know that the Zeus is only for X40. Thanks.
    • ArmorBolt
      • Dec 2020
      • 72
      Ok, I found some clue and answers from the FreeWing Youtube release video.. https://www.youtube.com/watch?v=_PnuHOUVBw0
      • Turbine Version Notice
      We will launch a dedicated turbine variant. The aircraft in the promo video is fitted with Swiwin SW80B turbine engine: 83 mm diameter, 200 mm length, 800 g weight and 8 kg max thrust. It is equipped with a 1800 cc double-layer flexible fuel tank and dual 6V/8.4V circuits. Turbine version testing is still in progress. This airframe is compatible with engines of different thrust levels. We will continue tests on SW55, X45, X60 and other turbine models.
      • Shaun Evans
        • Apr 2021
        • 125
        • California, USA
        Duplicate
        • Shaun Evans
          • Apr 2021
          • 125
          • California, USA
          Duplicate
          • Shaun Evans
            • Apr 2021
            • 125
            • California, USA
ID:	451664 Who can guess what this is?
            • f4u ausie
              • 1240
              • Melbourne
              These r now available on AliExpress
              • Shaun Evans
                • Apr 2021
                • 125
                • California, USA
                My guess is that the best overall pick for a turbine will be that X60. That's what I'm planning. Same vertical and speed performance as that SW80, but lighter and way better fuel economy.
                • Robertorende
                  • Mar 2021
                  • 9
                  Originally posted by 3D-Seth
                  680KV is correct.
                  On the first prototype Chris and I tested, I had my timer set to around 3:30 on 6S 5000's. Mind you, I have my timer set as a "time to prepare for landing" timer, not a "need to be on the ground now" timer, so actual time is around 4 minutes on 5000's. 6000's of course will be better, but it obviously will vary person to person depending on how long you hammer the throttle 😅
                  I can't speak for Chris, but at events I usually set my timer for 10-15 seconds less just to allow more room for a go around for traffic or various other reasons, but I believe he mostly flew 6000's at the event.
                  Seth
                  • Robertorende
                    • Mar 2021
                    • 9
                    Si sa la data di uscita?
                    680KV is correct.
                    Seth[/QUOTE]
                    • Robertorende
                      • Mar 2021
                      • 9
                      Si sa la data di uscita e se ci sarà un preordine sul sito EU?
                      • 3D-Seth
                        • Mar 2023
                        • 35
                        Exact ETAs are always a bit of a moving target with container shipping, customs inspections etc. but here is where things stand right now:
                        • US: We’re pretty close! Only about a couple of weeks out. We don't have an official pre-order set up, but definitely hit the "Back in Stock" notification button on the product page so you get pinged the second they arrive and can get your order in.
                        • EU: EU orders actually ship out from the factory at the exact same time as US stock, but they’re taking a lot longer to arrive. Because of the ongoing conflicts in the Middle East, ships are having to bypass the Suez Canal and sail all the way around Africa. That adds roughly 3,500–4,000 miles to the trip and ties up vessels everywhere, so things are pretty backed up on the Europe side, with no immediate end in sight. I unfortunately don't have a good ETA for you, as it would probably change by the time it got closer anyway.
                        Stay signed up for the back in stock notifications to be notified when they arrive!
                        • 400driver
                          • 58
                          Both F35 s arrived, my friend unboxed his today and was a bit dissapointed with the fuselage join. I will look at mine next week as I am away. Will post a picture on my return.
                            • 8819
                            You got them already??????? That join is pretty ragged.
                            • EDF-Jetpilot
                              Jets are a lot of fun
                              • May 2024
                              • 136
                              • Aarburg, Schweiz
                              Oh dear, that's not good! Is this a pre-production model or a prototype? What's the overall quality like?
                              • JA1170squad
                                Occasional Rivet Counter.
                                • Jul 2026
                                • 46
                                • United States Of America
                                How much are they . They seem like a very good jet and a lot of fun
                                • EDF-Jetpilot
                                  • May 2024
                                  • 136
                                  • Aarburg, Schweiz
                                  Motion RC
                                  https://motionrc.com › products › freewing-f-35c-lightni...
                                  The Freewing F-35C Lightning II Super Scale 110mm EDF Jet is the largest model Freewing has ever produced, and it delivers the scale fidelity and features ...
                                  $ 989.00 · Nicht auf Lager · 4.6(8) Freewing F-35 110mm
                                  • 400driver
                                    • 58
                                    I was in China for work so picked it up in Shanghai. I will double check the other one when I get home Sunday. Also picked up the new Typhoon. Super excited.
                                    • 400driver
                                      • 58
                                      These are production run not pre production. Let’s hope it’s a one off.
                                        • 8819
                                        FNRC featured an unboxing video almost 2 weeks ago. They have been selling production models in Taiwan for a little while so yours is likely the "real" thing.
                                        • 400driver
                                          • 58
                                          Back home snd checked to see if my F35 had a poor join as the one above, It was fine! No issues, its a big bird, not sure when I will get it built as brought back the new Typhoon 8S and have the Mig 29 TV waiting for my next trip back to China. I just hide them on returning home so the BOSS does not see them.
