  • harleymon
    I was just trying to keep things simple for my landings
    Why disable reverse thrust?
  • harleymon
    Hi all - I have Avanti S V2. As you know this is a little different beast than the V1 which I also owned.
    I attached my esc settings for the V2. Wanted to see if you agree with what I have. Thanks !
  • OldnBold
    Originally posted by kenbry
    Here’s my painted Avanti.
    What kind of paint do you use? Do you paint right over the original surface. What if any prep is needed before painting?
    Thanks,
    Waid
    My FW 80mm Avanti may be on the shelf for a while. Got the 90mm FMS Avanti. With TV nozzle. Set it up following Jon (2-Bros) advice and with the TV, it does some incredible things. Easy knife edge, high alpha, flat spins including inverted, head over heal flips continuously until too low, blenders, etc. Without the TV, it's just another Avanti. Using the 10 channel AS3X Plus with nose wheel gyro and 4X TV gains with extremely high rates.
    Balanced 25mm behind manual recommendations, it climbs doing the 45 degree inverted test, but damn, it's a blast to fly there. Using an SMC HiV 5900 for 5-6 minutes depending on routine.
    Built out the cockpit with 2 "Clint Walker" size pilots and applied 4 coats of clear gloss exterior Spar Urethane for durability. She's a sweet ride! :call_me:
ID:	410815 Click image for larger version
ID:	410816 Click image for larger version
  • kallend
    Originally posted by Jnohsey
    Looking at getting this and wonder which spektrum receiver would you recommend?
    Thanks
    AR8360T. Has enough channels for separate nosewheel steering and thrust reversing. AR8020T if you have an aversion to gyros.
    I use Orange in most my aircraft. Their DSMX 6ch and up have two satellite ports.
    I've been using Lemon rx's with my Spektrum radio for years and have had great success. With the Avanti, I'd like to have a rx that I could hook two satellite receivers to. One to run under the battery tray and one to run to the forward edge of the battery hatch, placing the rx itself just behind the battery hatch. Any suggestions??
  • Jnohsey
    Thanks
  • kallend
    Originally posted by StevenR
    Anyone have the STL file to 3d print the front landing gear brace? For the Avanti V2
    Check this guy:
    What the heck are you talking about?
  • Arkariansoong
    It's going to suck not being able to get parts.
  • StevenR
  • paulrkytek
    It breaks my heart to have to say this and causes no little amount of embarrassment as well. I lost my brand new Avanti due to a stupid mistake on my part. In an old guy moment, I placed the receiver right beside the battery. I know I know, as I hear the collective sigh!!
    Of course, at some point, I lost connection and she augured in, expensive mistake.
    So, what I'd like to see, for my interest and I bet several others as well, is just where you guys have placed your rx's for best results.
    This is my rx layout, needs some foam cutting. RX location is at front of canopy, need to cut some foam level where the rx goes. ( Zoom in to canopy top on stbd wing to see hole through tinted canopy. One ariel points forward, the other ariel upwards into cut hole. The little plane is my scratch built 630mm edf with 40mm 12 bl 4s XFly edf and gyro with auto level which I have been using for hand launch at our main field which is still too wet to cut the grass short enough to cut and roll !!!
    Click image for larger version  Name:	Avanti ariel 3.jpg Views:	0 Size:	98.8 KB ID:	403715 Click image for larger version  Name:	Avanti ariel 2.jpg Views:	0 Size:	94.7 KB ID:	403716
    Click image for larger version  Name:	Avanti ariel 1.jpg Views:	0 Size:	33.9 KB ID:	403717 Click image for larger version  Name:	630EDF photo 2.jpg Views:	0 Size:	82.4 KB ID:	403718
    Click image for larger version  Name:	630edf fod guard.jpg Views:	0 Size:	56.2 KB ID:	403719
    Mine is under the battery tray but I have long coax antennae with one going forward to the very front of the battery area and one aft to the very aft and a satellite under the hump aft of the canopy.
    Sorry about the loss.
  • Icarus the 2nd
    Here's a video I made at a recent EDF meeting in Germany.
    A military Avanti
  • Viper1
    There's one sure way to know...send it up
  • 9676neidy@gmail.com
    I have the arf + in red, was given the eflite delta v32 80mm. I realize it's only a five blade, but do you think it would be fine?
    That my friend, is OUTSTANDING!!! :clap:
