    I'm sure people will, they just got in stock on Motion Friday. Mine hasn't even shipped yet. At least I got a couple of the reversing ESCs before they sold out.
  • Ron1950
    anyone tryed the new 2150kv fan from the new f9f yet in the avanti?
  • WarbirdFan66
    and here also the AVANTI-M build video...if you enjoy that kind of thing....
  • WarbirdFan66
    Originally posted by Superglide09
    How do I get the motor cover off the fuselage on my Avanti. Very tight fit any suggestions
    ya, i had the same problem, in the end i used two screwdrivers which i put into the plastic holes of the cover, and carefully pushed them slightly outwards to get a grip on it, then slowly moved the cover out of the fuse...a bit difficult but i did it without any damage...and because i did a rework on mine i put some fake flare dispenser on the cover which double as hand grips, so its super easy to remove the cover now
    Make sure all your connections are correct, RX to the board and servo wires to the board. Probably one in the wrong slot or upside down.
  • Superglide09
    All of my control surfaces work except the elevators. I have no clue how to resolve this issue. Can anyone have any idea how to fix this. This is my first jet it’s the 88mm Avanti.
    Originally posted by WarbirdFan66
    i just finished my Avanti-M rework, so here a few pictures...
ID:	378837Click image for larger version
ID:	378838Click image for larger version
ID:	378839Click image for larger version
    OUTSTANDING!!!
    After taking out the screws I lightly screw two drywall screws in the holes to grab the cover and gently pull back and forth.
  • Superglide09
  • WarbirdFan66
    They are starting to put the new fan in other planes but not the ESC or gyro.
  • Topdogzrc
    So given the release of the Cougar, I wonder what upgrades the V2 Avanti will have.
    Do you think they'd install that new power system, include the quick release wing mechanism, and a gyro as well? Besides the new color scheme of course. I wonder when the V2 will be released too, hopefully this summer
    Great way to end the day here
  • kallend
    Click image for larger version  Name:	20230423_111940.jpg Views:	0 Size:	156.5 KB ID:	376176
    That's a thrust ring in the exhaust.
    Had my Avanti out today and she flew great even in the wind. Did some experimenting with speeds flying into a head wind, I found at 1/4 throttle she was still flying straight and level. Landed with one click of throttle and no flaps. She still had a bit of a bounce, no biggie. Hard to believe how long I've had this bird!
    That's not his Avanti. I'm trying to clarify what he made for his Avanti.
    I'd call what you show a "thrust tube".
  • kallend
    Originally posted by tcb2185
    All ready got that printed. I also did the rear thrust ring.
    What is the "thrust ring"?
  • tcb2185
    Double posted for some reason.
  • tcb2185
    I gotta admit this thing is bigger than I thought. Adding as3x to it.
  • tcb2185
    Originally posted by Mark 2
    The decals tend to lift, be prepared to stick them back down with a thin smear of FoamTac or similar.
    Put a brace behind the nose gear leg, there are 3d printed ones or you can make up something out of balsa and plywood.
    Apart from that it’s a great jet.
    Or coat the airplane with Minwax water based gloss to seal down decals, works every time.
