Freewing 90mm F-16 - Thoughts anyone?
  • Scale Master
    X USAF Pilot, Commercial IFR Jet Rated
    • Apr 2019
    • 86
    skip
    • Scale Master
      • Apr 2019
      • 86
      Custom opening canopy mod
      • Scale Master
        • Apr 2019
        • 86
        Operational Canopy Mod Video
        • Scale Master
          • Apr 2019
          • 86
          Retract Test with Centerline Tank
          • Scale Master
            • Apr 2019
            • 86
            Decided to go with the X-45 instead of the heavier gas guzzling K-45
            • Aussie1
              Mainly turbine jets!
              • Feb 2019
              • 78
              • Adelaide South Australia
              Scale Master, great conversion! There are a few FW F16's now flying on a micro turbine, and the X45 is the most perfect choice. The latest issue of RC Jet International has a very detailed conversion of this jet to K30 power and it flys great. This video shows just one of them out there.
              • Scale Master
                • Apr 2019
                • 86
                https://www.youtube.com/watch?v=suD5jtguUqM
                Thanks Aussie1
                • Aussie1
                  • Feb 2019
                  • 78
                  Scale Master, I found a video of the F16 conversion that was in RC Jet. I had the HSD F16 with a ACE60 turbine and while it flew OK, it was heavy and a bit under-powered, so I think that your conversion will be the best way to go, for a foam F16.
                  Even a thrust vector version!
                  • Scale Master
                    • Apr 2019
                    • 86
                    https://youtu.be/q-7BT2OE2qg
                    Yeah I would agree, as the FW F-16 is about 10lbs when you have the jet set up on a 8S 5000mAh packs so this bird will be a little bit better than 1:1!
                    • Charlesr
                      Expert pilot
                      • Nov 2018
                      • 6
                      Anyone thought of putting a down mix on low throttle activation via flap switch
                        • 5401
                        Can you explain what you mean? Down what? Flip the flaps and it reduces throttle?? Down elevator with flaps? But why throttle too?
                        • gooniac33
                          The Original Gooniac
                          • Jun 2016
                          • 1047
                          I haven't needed to use down elevator with full throttle. Is there something in your exhaust? That can tend to do this...
                          • Tronn
                            • Jun 2019
                            • 10
                            Has anybody tried the latest version of grass? I am worried it does not have enough power for take-off on grass?
