Official Freewing 70mm F-16C Falcon V2 Thread
  • gooniac33
    Originally posted by kenelder
    There was no wind at our field today. I obtained some interesting info: my GPS is telling me that a high alpha pass (30 to 40 deg angle of attack) using thrust to hold altitude is at 20 mph (sometimes 19 or 18)!!! It sure looks slow and majestic. Yet plenty of power to accelerate vertical from a slow pass like that.
    Completely stable with full UP elevator, pretty amazing. I’ve mixed additional UP on a switch for assisting in landing, touches down on the mains and tail cone. Awesome plane! Still rolls a long way, got to tighten up the axles a little bit.....
    Nothing cooler than a super slow high alpha pass just inches off the deck and seeing the dust blow away as you travel down the runway. It is one of my fave things to do!!! Mine is a lil heavier so I was able to get a 23mph High Alpha pass with no wind. With wind the passes were at barely 13mph ground speed....
  • kenelder
  • gooniac33
    my flights from last weekend...and the week before.
  • gooniac33
    Originally posted by JohnVH
    Great flight, with a bad landing
    You are being way too hard on yourself!! Landing was good! Just gotta get used to the way it lands so that the speed will be a lil lower. this plane does not like to turn on the ground with any kind of speed...
  • Ron1950
    hey Urrl where ya all get a lake? lol as I recall there are lakes in markem park but not at the flying field :)
  • JohnVH
    All you had to do it just taaaap the brakes alittle lol the landing was spot on, you just have to work on the taxiing after words.
    Im going to add brakes, anyone know what diameter the axles are?
    LOLLOLLOL Yeah, I could say something, but I will pass!!
  • JohnVH
    You need to rethink your definition of bad landing mister. That wasn't a bad landing. I could show you a bad landing! LOL LOL
    Haha! Maybe so!
  • JohnVH
  • urrl
    Thanks Prowler.
    My morning flight
  • Prowler901
    Beautiful flying urrl! And, beautiful place to fly. I hope to maiden mine very soon.
  • urrl
    Friday morning flight
    Yeah maybe the clear was bad from the factory?
  • Boots Whirlygig
    Originally posted by Hardway
    Ace Hardware standard stuff.... Good paint really, I have painted over the white with the red and blue, and other combos... No wrinkling, runs, creeps, etc. So then the clear should have been compatible, right??
    You sure would’ve thought. Hey Rustoleum, what gives!?! Maybe too wet of a clear coat? Just don’t know. Shouldn’t have happened in my mind.
    Hey, but the canopy is moving along. Just have the little gray fuselage corners to do!!! :Cool::) (also, the 1600mm Spitfire is calling me.....:Sweating:)
    Give me a few minutes and I will post pics of the paint. They are rattle cans from Ace Hardware. I tested all of them on an old A-10 wing, Put it on really heavy (color coats) to check for gatoring, and then clear coated it with gloss and matte about 10m after the color had gassed off and started to get tacky... So the base coat being dry was not an issue. It had been on a couple of days from spraying the vertical stab to clear...
  • Boots Whirlygig
    This is my #1 fear when contemplating a repaint, finding an incompatibility ON the project. Please tell us WHAT paint and clear coat you used. Maybe the color coat wasn’t dry? That really sucks.
