When I move the sticks on my controller, only one aileron or elevator move. Any fixes?
Official Freewing 64mm EDF F-22 Raptor Thread
That was my first thought too. The cables need to be connected with a Y cable and the Y plugged into the receiver. It sounds like you only have one side plugged into the receiver for both aileron and elevator.
You need to connect the left and right aileron with aY and same for the elevator, then plug the cable into the receiver and you should be fine.Comment
So I just bought my aircraft and the ailerons aren't working properly and the motor does not respond. I believe I have everything connected correctly. Any advice?Comment
Do you have a servo tester? Servo tester/battery tester. Test the servos to see if they are working. Then check that you've plugged into the Rx correctly. Check your channels in your TX. Did it actually bind? Your elevator is working, youe nose wheel steering is working?Comment
So I am having issues with ailerons and motor won't run. Just purchased withing the last month. Stearing works, elevators work. One aileron does not respond at all and the other just flutters. I believe I have all connector correct but just not sure what's upComment
I've actually been thinking about doing it and have a plan. I have an Xfly A10 that I upgraded the gear with suspension gear that I bought from rc castle. I'm thinking of getting the same and swapping in the front gear from the A10 or from the FW F9F. It's really the only weak point of the 64mm F22. Otherwise it's a badass little plane.Comment
Diarossi86 I know this is super late but if anyone else has the same issue and finds this thread, the issue you're having is due FYI one if the servo wires being connected upside down... usua instead oflly the the one that isn't fluttering is the one that is connected wrong. Came across this issue helping a friend fix his after tearing the wingthe off in a crash. Got up and let off the throttle instead of letting off the elevators and it came down like a leaf. It's mine now and I've upgraded to 6s avian esc and matching motor upgraded the fan and run 3300mah 6s batts. It now gets in the air in half the distance it used to and clocks @ 110mph. I replaced all the stock servos too and added a byme A gyro and I couldn't ask for more from it... Thinking about adding flaps or retractable landing gear but haven't decided yet, that's why I'm here hoping to see success stories and not too many war stories.Comment
Just ordered mine today, not sure I will like the transmitter that come in the bundle with it, what upgrade transmitter would you folks recommend that would be compatible?
