Official Freewing 70mm Twin Me 262 Thread
  • fhhuber
    Originally posted by JFandL
    This setup looks good while its of a P-38 you may want to give it a try. Not My p-38 or work.
    Link to p38 build http://www.flyinggiants.com/forums/s...t=50949&page=2
    Works for that plane because the correct flap movement is not the same as the Me262's
    Full scale Me262 has tracks at the ends of each flap section and each section is pushed back by 4 lead screws. Tracks keep the flaps from skewing.
    Making the scale tracks would be useless on the model because material flexing in flight would have the flaps popping out of the tracks.
    the normal solution on models is to not do the push back and low hinge the flap. It looks pretty good, but doesn't produce the classic Folwer gap (or effectively increase wing area, which is why they move back) as the flap moves.
    Not as important to gain the area for the foamy by Freewing. The large one I am doing needs the added area to reduce landing speed.
  • themudduck
    Yeah I wondered the same thing, on the original model-- why do split flaps, they could have easily done normal ones.
    Its a shame that we lost almost 3 years worth of posts on this thread (everything between post #17 from Dec 2014 and post #18 March 2017 is gone). There was a lot here. Guess we need to start over again! Seaviper, can you post a new pic of your mod flaps? Or perhaps Brandon Moon?
  • seaviper
    I was just asking why they chose to do split flaps instead of the more scale version, hoping to get some insight from the MRC dudes as to why they did that. The area of the wing directly above the split flaps on mine was rather warped. The split flaps would not close properly. That is why I did the mod. It helped the looks and the function.
    That being said, the 262 was liked by everyone at the field. And, it sounded pretty good too.
  • JFandL
    Originally posted by fhhuber
    correction.. saw a pic posted, thought it was the model... its not.
    Split flaps used on the model are really not appropriate.
    they are doing the classic "split"... upper half of TE fixed, lower half comes down.
    The sections of flap inboard and outboard of the engine nacelles is the correct idea.
    Full scale it appears the top of the flap is shorter than the bottom, and the whole flap pushes back as it rotates down. This is essentially a single stage Folwer flap. (typical modern airliners use multiple stage Fowler)
    Linkage to do scale movement of the scale flap sections is difficult. I'm trying to solve it for a 107 inch span Me262. Closest I have come up with gets the correct movement but requires 2 servos per flap section (and a ton of ball links)
    Some early experimental results:
    Yes, the servo has to be that far away for the geometry to work.
  • fhhuber
  • themudduck
    My old one got smashed up beyond repair due to a brownout which was my fault (I would have had to replace the fuse, and why would I when I knew this one was coming) so I just ordered the new one!
    Order 343327
    Yay, so I already have some spare parts. (check out post #71, I tried to sell the "remains" but no one was interested!!)
    Guys, its strongly recommended to add some CF reinforcement to the inside of the nose on this plane. There's some weight up front and the physics of inertia can snap the nose right off in a bad landing (its a weak spot). Other than that - like you see in the video, this plane is an awesome flyer. I can hardly wait to fly the new one!
  • themudduck
    Originally posted by seaviper
    I don't understand the split flaps on this model. Why?
    This is the same model as before, just painted up differently (and of course it also has the motor upgrade). They didn't change anything on the airframe because that would have incurred a big expense.. In earlier posts I did notice that someone cut the wing up and installed "real" flaps instead of split flaps to make it look like that picture above. So its doable...
  • JFandL
    Click image for larger version  Name:	Me262A-1a_7621.jpg Views:	1 Size:	114.1 KB ID:	144970
    Why? Scale to airframe, maybe not
  • seaviper
  • JFandL
    Oh man Love the paint!!! Did they ever fix the nose gear area so that you can land on grass? I've seen a few nice landings with this aircraft in grass and the nose just snaps off.
  • James
    Unboxing & Assembly video for everyone. Thanks Ryan!
  • dkalwishky
    And the build video.
  • James
    Flight Review of the new scheme Me 262
  • dkalwishky
    The version with the new paint scheme is now in stock, I just ordered it. There is a really good chance it'll be here Saturday for a Sunday maiden.
  • MANFRED
    These fly great warped or not
    Awe man about the hatch, but very good stuffabout the flight and landing :Cool:
  • Helmsman52
    So I did my maiden and I lost my foam servo hatch in the bean field but it flew and landed beautifully.
    Anyone have a spare hatch not being used? lol
    Click image for larger version  Name:	811E54A8-2B35-4183-A5C2-C3C6EF935997.jpeg Views:	1 Size:	74.5 KB ID:	142908
    Thanks
    Sweet! Very awesome news my friend!
  • Helmsman52
    I’ve been a Mrc customer ever since I started the hobby about 5 years ago and imo they are the best all around in customer relations and service.
    I received my replacement wings today and they are straight!
    Thanks Mrc!
    Paul
    Click image for larger version  Name:	79854F81-584C-480B-B54F-A6E319258DFE.jpeg Views:	1 Size:	97.5 KB ID:	140366Click image for larger version  Name:	A0048434-80D8-4326-AFAD-6E9E7472E05F.jpeg Views:	1 Size:	61.7 KB ID:	140367
  • johnslag
    Hello Everyone, Does anyone have any photos or information on the how to install the max crashproofing kit, or how/where to install carbon fiber to reinforce the nose of this plane? I haven't flown in a few years after my Dad died, and I'm ready to get back into it. I own one of the original 6 blade fan version of this jet and I love it. However, I have had issues with 2 broken fuselages with this plane because of a rough grass runway. I have another fuse new in the box that I would like to reinforce with carbon fiber, but I'm looking for some advice from someone who has done it before. Or at least a few pictures of one that was completed. ie drill hole locations, size of c.f. rods, that sort of thing. Thanks for the help guys!
