Official Freewing 70mm F-104 Thread
  • gooniac33
    The Original Gooniac
    • Jun 2016
    • 1047
    Guys I apologize... I thought this was for the 90mm...
      • 8207
      That's it. Now you've done it. Guess you're just going to have to hand all of your airplanes over to me. LOL
      • gooniac33
        • Jun 2016
        • 1047
        Ha!!! Good luck with that....LOL
        • Bob Vincent
          • 12
          • Buckeye, AZ
          Ok yesterday I was visiting my daughter and her family in Goodyear AZ and saw the 70mm version fly all stock. SOLD!!!!!!!!!!!!!!!!!!!! Now I have to have one! I have seen Gary's from Efflux RC up close but never in the air and also seen Tony's up close but never in the air. If anyone here is from Goodyear AZ and was there yesterday I would love to learn your names because from now on when I visit I'm bringing some of the fleet :D This is for sure going to be one of them!! I can't believe how scale it looked in the air with speed and the way it took off and landed. I was leery of these because until I saw this one, no one has gotten the Starfighter even remotely close to correct. Now I gotta call Alpha so I can get one and my son fell in love with the 70mm Yak 130. So I have 2 planes to get quick!!
            • 8207
            Great! Looks like a fantastic jet and welcome to Hobby Squawk!
            • urrl
              • Oct 2013
              • 494
              Looks and flies great. Having lots of fun with mine. If I crashed tomorrow I probably would buy another.
              • the snake
                I can't help my self dear! I love RC!
                • Nov 2013
                • 126
                Why you don't want a 70mm f-104 also ray?
                • urrl
                  • Oct 2013
                  • 494
                  Morning flight.
                  • urrl
                    • Oct 2013
                    • 494
                    Mishap with the 70mm. Apparently mine tends to loose altitude during slow and low fly by.
                    • urrl
                      • Oct 2013
                      • 494
                      Morning flight.
                      • scooter genie
                        • 164
                        The product web page says this is constructed of EPO foam, but some of the reviews, and earlier threads say it's EPS. What is it really ?
                          • 2816
                          • Arlington, TX
                          The older ones were EPS with a 5 blade edf. The new ones have been upgraded to EPO and a 12 blade edf.
                          • scooter genie
                            • 164
                            EPO....oooohhhhh......gotta have one now. The eps is what held me back from purchasing one.
                            • CFIT rob
                              • Jul 2016
                              • 220
                              • Indy
                              Can anyone tell me how well the epo version flys with the original "gen 1" 6s ,6 blade edf out of the eps version. Crashed on maiden(so nervous i left the bind plug in.) Repaired it,had a few good flights till i spun it in on a too slow turn to final. Ready for another one. Epo version i assume is heavier. Using 6s 4000admirals.
                              • scooter genie
                                • 164
                                Has anyone tried the 70mm f16 upgraded gear struts in this Bird?
                                • scooter genie
                                  • 164
                                  I was slumming around in Motions parts section, and noticed that the stock nose retract fits the following planes...70mm Fi6, and 70mm F104. Then I cross referenced the part nos. for the mains. The numbers between the planes is different, But the stock mains look identical from the pictures. I'm thinking that the upgrade struts for the F16 should fit the F104. I sure hope so, because I'm on the fence, and if I could put those struts in the 104, it would seal the deal for sure.
                                  • scooter genie
                                    • 164
                                    Well, I ordered the upgraded struts for the F16....hopefully they will fit without too much work. I am going to get the kit version of the 104 because I have a changesun V3 70mm 10 blade with a cyclone power CS480-2800Kv outrunner with an unusual shape that puts the motor in the airflow of the fan. It was left over from a LX TV F16 I had a few years back. That plane flew very fast on 5s, but will be using 6s on it this time.
                                    • scooter genie
                                      • 164
                                      bench tested the out runner setup on 6s and it got way too hot. I already ordered the kit version of the 104, so.....can anyone suggest a nice inrunner setup for 6s ? I'll be using a 3300 to keep the weight down.
                                      • scooter genie
                                        • 164
                                        OK, While waiting for the airframe, I am tinkering with the gear. The first obvious difference is that the F16 nose gear retracts aft. the F104 retracts forward. So the first thing that has to be done is to loosen the grub screws on the nose strut, and rotate the strut so that the trailing link is pointing down. That way, the trailing link will be forward in the down position. Also looking at the 12 blade fan and 2200Kv inrunner combo from edf hobbies, and hobbywing 100a ESC.
                                        • scooter genie
                                          • 164
                                          Airframe will be here tomorrow ! Yee haa ! The only other potential issue with the mains is if the strut pin is the same size.
