    Will do! These are the struts that I am looking at using: https://hobbyking.com/en_us/alloy-ol...class-1pc.html
    Are you going to drill out the axle holes for 5mm or bush down the wheels?
    Thanks for the info man! Will be putting in my order for some 115mm oleos pretty soon. This thing is going to be quite the beast!
    I would be curious too as I may be transitioning to flying more off asphalt than Geotex or grass. We may be soon losing our field to a solar farm. Those with runways at old landfills beware but a club just North of me is getting a new paved runway. It is a little further drive but hey, I think I can live with that considering.
    Originally posted by DCORSAIR
    Let some of us know on which struts you bought and how they work out for you, that is one thing I did not like about it, I fly off asphault so struts would look better and work just fine for me. Thanks
    Was thinking of doing the same thing. Now I'm thinking of hanging with the wing tube to lessen the chance of denting the horiz stab.
    If you distribute the load on the leading edge of the horizontal stab it would probably be fine. This thing feels amazingly solid and just not much flex in anywhere.
  • DCORSAIR
    No noticeable compression under static load and I am looking at an AUW of 15.5 lbs. with two Roaring Top 5800 mAh 35C packs, the sound system, powder canon and full load out. It's a big bird.
    The wing tube is a great idea as well. :Cool:
    Originally posted by T-CAT
    I hate to bother you with this, but if you have time, can you measure the horizontal stabilizer (not including the vertical stabilizers)? I'm hanging up mounts and looking to see if the distance is the studs in the wall (16 inches apart) is perfect, or if I need to go much more narrow and go through the drywall on one of the hangars. Thanks!
  • Mike_Then
    Thanks Mike, I am looking into my options concerning it. Never hurts to ask. I need to make darn sure it is effective and reliable before moving that direction as I do not want it to be problematic for people.
    Totally understood and thanks for the reply!
    No bother at all T-CAT. Looks like it's 21" between the vertical stabilizers. Is that what you needed to know?
    Thanks a ton RCjetdude. That's exactly what I wanted/needed to know. That helps me tons. Thanks again!
    Here is a quick video of the sound system, taxiing through my basement and the canopy opening.
    It does include them. The leading edge slats are non-functional.
    Excellent! Thanks!
    That AUW doesn't yet include a working canopy or leading edge slats mod, correct?
    Very cool mods by the way, and looks amazing so far. I'm looking forward to seeing the finished product. :Cool::Cool::Cool:
    Awesome, thanks so much for the info! Do they compress much under the static load? Looks like a 115mm Oleo would a nice fit.
    Originally posted by OV10
    Very :Cool: RCJD.........Am glad that Motion reached outside it's normal circle of "testers" and bestowed one rightfully on you because of your planned mods ;)
    Am stoked to see it first hand @ NEFI with the canopy and canon mods.
    Thanx for those measurement because I like DD am considering a more scale main gear oleo.
    What is the diameter and length of the main wheel axle?
    The main wheel axles are 35mm long and 5mm dia.
    That's a great list of mods. What is the weight of the prototype powder cannon and what do you hope to get the final version down to? Great idea.
    Looks like all together it is about 15 ozs. with powder.
    Originally posted by Mike_Then
    Congrats Steve!! That's incredibly awesome! I'm very much looking forward to your progress, especially in the areas of the powder cannon. Flying the A-10 is going to be pure sweetness, but adding the scale details you outlined is going to be icing on a very, very tasty cake. This may be jumping the gun a bit - if you'll pardon the unintended pun - but upon completion of the powder cannon and once it's working to your satisfaction, would you be willing to provide instructions so we could make our own? I'd be more than happy to pay you for the instructions as well, to compensate you or your time, energy, and ideas. Understand if you didn't, but figured it couldn't hurt to ask.
