  • starcop
    Originally posted by herbert Stötter
    Hallo, vielen Dank für die schnelle Rückmeldung. Werde mir den Jetpiloten bestellen.
    Gruß Herbert
    Guten Tag, Ich helfe gerne. Ich versuche... Ich hoffe, Sie finden, wasSie suchen.
  • herbert Stötter
    Gruß Herbert
  • starcop
    Originally posted by Elbee
    SC, thanks, he's a keeper. The cockpit kit is designed by Dirty Dee and makes the pilot look like he knows more than really does which sounds familiar some how... Best, LB
    How about this for a co-pilot... They make a great team! Elbee, you were a Commander in Desert Storm per se?
  • starcop
    BTW, a very true statement. Quote, the pilot looks like he knows more than really does. Bravo.
  • starcop
    Elbee, You've done a fantastic job on the aircraft. I love your statement. Be humble...be approachable...and be credible. Music to my ears! Happy Flights; buddy.
    Originally posted by starcop
    Beautiful job Elbee! That pilot looks fantastic.
    SC, thanks, he's a keeper. The cockpit kit is designed by Dirty Dee and makes the pilot look like he knows more than really does which sounds familiar somehow... Best, LB
  • starcop
    Herbert, ich habe die moderne Pilotfigur im Maßstab 1:10 von Jet Hanger Hobbies verwendet. Es sieht gut aus und passt gut. Die meisten verwenden diese Zahl. Am besten, LB
  • starcop
    Welcome to Jet Hangar Hobbies, Inc.
    Hallo, wo gibt es die Piloten (Ganzkörperpiloten) für die A 10 von Freewing Gruß Herbert
  • starcop
    Gruß Herbert
    BenchCraft 85mm (3.3") Jet Pilot Figure - Green [BCT5032-014] Motion RC Das konnte ich finden. Hier ist der LinkHier ist der Link.
  • herbert Stötter
    Gruß Herbert
  • Warthog
    I don't have a printer,, so I was wondering if anybody sells them.
    Originally posted by Warthog
    Where can I buy one of these printed units??
    If you are talking about the nose gear brace and you don't have access to a 3D printer, there is someone selling these on RCGroups:
    You don't "buy" them. You download the 3D file and you print it yourself.
  • Warthog
    What I did was take some square hardwood and glued it into the holes in the plastic from the top, then used larger wood screws on that side. Helps a lot. But there is a 3D printed nose gear mount as well.
    Nose gear mount file here: https://www.thingiverse.com/thing:4177413
  • dsmithwc04
    I'm trying to find if there was an adequate front gear mount replacement and if it was mentioned in this thread. Maybe I'm just to dense but did anybody find a worthy fix for the weak front gear mount?
  • Warthog
    So for a short runway, a 12 blade would be better. I think I'll go back to the 12. Thanks!
  • jaldendifer
    My experience has been that 9 blade has higher top speed, but the 12 blade has better low to mid range thrust
  • Warthog
    Not trying to open a can of worms here, but Just want the facts. 9 blade or 12? Both 90 mm and spinning the same speed. Which one makes more thrust?
