The mighty F-16 has finally come to Freewing's 64mm class of EDF jets. The clean lines, classic profile, and scale details are all captured in this exceptional 64mm EDF Jet F-16C Fighting Falcon from Freewing Models. Simplicity and durability were major design factors with this model. The airframe has been refined with a simplified control and gear structure that reduces the overall weight and wing load. The ailerons and elevators are joined by two servos for a flying delta configuration. An updated V2 40A ESC includes a reverse thrust function to help slow the jet on the landing roll out. Quality electronic components come pre-installed so you can be in the air in less then one hour.
- NEW! 40 Amp V2 Electronic Speed Control has reverse thrust functionality
- NEW! Ailerons and elevators are joined by two servos for a flying delta configuration
- Comes with 12-Blade EDF with 2836-3300Kv Brushless Motor
- 4S LiPo capability for High Performance Flight
- Scale details including painted pilot and cockpit, panel lines and landing gear
- 3x 9g digital gear servos come pre-installed
- Freewing F-16 64mm EDF Jet - PNP
- Servos, motor, fan unit and ESC are all pre-installed
- 4 Channel Radio - Select a minimum 4 channel radio from our Radio Collection
- 4 Channel Receiver - Select a minimum 4 channel receiver from our Receiver Collection
- 4 Cell 14.8V 2200 mAh LiPo Battery with XT60 Connector - EPR22004PROX6
- 4 Cell Compatible Battery Charger - Select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL :14 and up
SKILL LEVEL :Intermediate
BUILD TIME :1 Hour
| Model Scale | 1/15 Scale |
| Wingspan | 680mm / 26.8in |
| Length | 1050mm / 41.3in |
| Flying Weight | 730g (without battery) |
| CG (Center of Gravity) | 81mm from the leading edge of the wing root |
| Power System | 2836-3300Kv Brushless Motor |
| Speed Control | 40A, internal SBEC with XT60 Connector |
| Propeller / EDF | 64mm 12-Blade EDF |
| Servos |
| Landing Gear | Fixed main landing gear, steerable nose gear. |
| Required Battery | 4S 14.8V 2200mAh with XT60 Connector |
| Required Radio | 4 Channel 2.4ghz radio |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Nylon hinges on all control surfaces |
| Material | EPO Foam |
| Skill Level | Intermediate |
| Build Time | 1 Hour |
