New E-Flite AT-6
I’m so used to adapting anything to everything, connector changes are a way of life.
I have a dedicated stand to solder on with a removable fan for the window. I stock every thing that I need to avoid trips to the store.
I do 95% of my soldering with a Bernzomatic torch, refillable with butane. All jigged up so it won’t move until cooled of.
Flew the AT-6 today in a fair crosswind, handled it very well indeed!
Fantastic re the flying in crosswindOriginally posted by Ole-Timer View PostI’m so used to adapting anything to everything, connector changes are a way of life.
i have an old butane torch my dad had, not used it as have been all electric solder experience, may have to as it takes a while to heat the heavy gauge wires with electric, picked up a set of extra hands several months ago which helps a lot. Like your block of wood with the holes for holding the pins. I have used a block of wood with holes when changing motor shafts but not for soldering. Will be setting one up for future soldering.
After receiving my AT-6 from MRC I started my conversion to my favorite SNJ. Doing this was fun seeing it change over to a Navy paint scheme. I used graphics from Callie Graphics. She is great to work with. I changed out stock wheels for Robarts following Pilots Ryan instructions on the RCGroups thread for this plane. I do have to remember to cover the plane with a white towel this summer in the pits to avoid the dreaded foam surface alligatoring. Unfortunately I live in Minnesota so I to wait for Spring to arrive. They are calling for 6 inches of snow tomorrow, yech! Can't wait to maiden this amazing plane. Larry2 Photos
- Likes 3
Very nice AT6 Flyer! I like your changes. I have the stock EFlite AT-6. and it is a sweet flying plane. I've always been fond of the yellow, sliver and red paint scheme I've seen on some, but for now, I will just fly her as she is. For me, I like the stock set up with 3S power. I have used up to a 4500mAH 3S battery in her, and she did fine with it. Plus, I had over 10 minutes flight time with that battery! My standard battery in this one is a 3300mAH Admiral. Balances perfectly with it all the way forward. The 4500 is a Hobby People battery, and I have to move it slightly to the rear, but still works great.
I have a couple questions I'm hoping folks can help me with. First is the flap settings. Manual says to add 4 percent and 6 percent of UP elevator. Is that correct? Second are the throws. To get the high rate throw of 20mm on the ailerons I had to move the linkage position. Has anyone done that and ha e to adjust the gains?
thanks
Hi Chalredline1,Originally posted by Chalredline1 View PostI have a couple questions I'm hoping folks can help me with. First is the flap settings. Manual says to add 4 percent and 6 percent of UP elevator. Is that correct? Second are the throws. To get the high rate throw of 20mm on the ailerons I had to move the linkage position. Has anyone done that and ha e to adjust the gains?
thanks
i have found with previous planes when setting up the flap system(I have Spektrum DX9) that you have to put in the elevator setting at a plus value( gives down elevator). Best Check is to dial in say 25 to 30 % elevator and then look closely at which way your elevator moves when you flick your flaps to take off and landing.
i have yet to set up this on my AT6, am still working on the 4S upgrade with Flightline 880kv motor.
cheers
Bob
I've been eyeing one of those T-6's but then start comparing T-28's.
since my dad was an instructor in both, I would like to have USAF versions, maybe even find some old photos of his squadron for Callie graphics reproductions.
But I have 3 models yet to build, I have 4 (soon 6) airplanes ready to fly, and don't want to attract any more attention in the hangar from the GF!
Especially when one of the builds is for her - she wants to learn to fly a Gentle Lady, and she wants me to get the Ryan done before I work on hers.
I'm pretty lucky, but anyone got a creative way to sneak a 50" model into the hangar unnoticed?:Not-Talking:
Bob, what is confusing to me is the manual wants you to program in up elevator when deploying flaps which seems counter to what I typically would expect .I believe when I entered a positive number for elevator I got up elevator trim when I deployed the flaps. Had to enter a negative number to give down trim
You could have the AT6 Texan delivered to a mates place. As it comes in three pieces, fuse, wing and tail horizontal stabiliser you could easily fit the stabiliser with supplied 2 screws and then on your way home from a day flying pick it up as if it was one you had taken to the field. You can fit the wing in a couple of minutes with the supplied 4 screws(it has quick connect for controls) or leave the wing off for transport depending on vehicle space and unload it into the hanger as normal upon return from a day of flying.
good luck
- Likes 2
When you have aOriginally posted by Bob Symes View PostYou could have the AT6 Texan delivered to a mates place. As it comes in three pieces, fuse, wing and tail horizontal stabiliser you could easily fit the stabiliser with supplied 2 screws and then on your way home from a day flying pick it up as if it was one you had taken to the field. You can fit the wing in a couple of minutes with the supplied 4 screws(it has quick connect for controls) or leave the wing off for transport depending on vehicle space and unload it into the hanger as normal upon return from a day of flying.
good luck
She
Who
Must
Be
Obeyed
and have to hide your hobby purchases...
LOL
- Likes 2
Now yer' talkin sense!Originally posted by Bob Symes View PostYou could have the AT6 Texan delivered to a mates place. As it comes in three pieces, fuse, wing and tail horizontal stabiliser you could easily fit the stabiliser with supplied 2 screws and then on your way home from a day flying pick it up as if it was one you had taken to the field. You can fit the wing in a couple of minutes with the supplied 4 screws(it has quick connect for controls) or leave the wing off for transport depending on vehicle space and unload it into the hanger as normal upon return from a day of flying.
good luck
Chalredline,Originally posted by Chalredline1 View PostBob, what is confusing to me is the manual wants you to program in up elevator when deploying flapse the manual which seems counter to what I typically would expect .I believe when I entered a positive number for elevator I got up elevator trim when I deployed the flaps. Had to enter a negative number to give down trim
not sure, just download the manual at work and you are right. Has to be a typo!
i will check what happens when I set mine up and will ring our Aussie distributes for a check as well
The settings could be specific to how the receiver has been set up. Check the control surface movement with the manual percentages. I have not had much luck with the AR636 receivers with safe mode in the past, almost lost my Sukhoi 29 due to lack of elevator movement, only way I could get it down was to drop power and do wide circle spiral. Local distributor did not really shine any light on the AT6 manual, just indicated that was what is needed to adjust for change when applying the flaps.Originally posted by Bob Symes View Post
Chalredline,
anyone out there that has flown the AT6 got any info on the flap mix to use?
Bob
Great news,Originally posted by Chalredline1 View PostIf I plug in +4% and +6% per the manual when I deploy the flaps I get down elevator not up elevator
talked to horizon and it should give down elevator when the flaps are deployed which makes sense .
still confusing how the manual is written.
should have mine ready to maiden in a couple of weeks
Thanks Chalredline
Regards
Bob
Well, it's on the way - taking advantage of the markdown. BNF version.
Not flying off grass - still need retract upgrade?
After bashing the Carbon Cub nose on Friday, I applied the Minwax Polycryllic over the whole plane after all the repairs and paint touch ups. The added rigidity is quite impressive, so I will plan on 2 coats of that with a detail gun before assembly.
Has anyone completed a retract upgrade? If so some details on parts used and photos would be much appreciatedOriginally posted by F22trainer View PostWell, it's on the way - taking advantage of the markdown. BNF version.
Cheers
Bob
