Thanks, I was going for authenticity and this is pretty unique. We actually used some 'pink' zinc chromate on our DC3, couldn't figure out why it was this color, now we know.Team Gross!Comment
That's a great period video taken in 1945. By that time the landing sequence for getting aboard the boat in one piece had been pioneered by the Brits before and additions like the stall strip on the right wing helped both wings to stall at the same time (instead of its nasty tendency to stall the left wing first and a deadly torque roll off the fantail of the ship), just before they touched the deck for a safe "trap." I believe they got the airplanes down to an approach speed of about 80 knots with full flaps, did a continuing 180 degree turn to the deck from a left downwind leg, and kept the LSO (Landing Signals Officer) in sight all the way to the deck. It was very tricky, but you can see when done properly, it was possible to get this aircraft on the deck somewhat safely, although there were a lot of crackups in late WWII and Korea.
Brits devised this method of approach for Seafires in '42, I think. Another first is we were the first to use the Corsairs on carriers. The Seafire, though a good fighter, could not really take carriers ops as the undercarrige wasn't robust enough and it didn't really have the endurance, so we used the Corsairs, Hellcats and Avengers. All good aircraft.Comment
Is it my bad flying or rather my bad landings but it is costing me fortune in retracts for this Corsair.Even a soft landing seems to rip out the retracts on this bird..Any one else haveing the same proplem ?.I do fly off grass but the grass js like a bowling green .Taken to belly it in to save on the cost of replacing the retracts🫤Comment
Most of us had that early in the process.. I agree they r not great. 2 wheel landing looks nicer. But I found 3 point broke way less gear. U can repair them depending on the problem.. they crack the case. Bend the worm drive.. I reinforced the case with automotive 2 part plastic glue from new helps alot If U do that make sure U scratch up the case with some 80 grit for adhesion... Awesome flyer. Mine is semi retired now. But has around 500 flights
I realize that its not ideal as I have also rebuilt my gear.
I have a full set of replacement parts doors as well as gear.
forces me to really pay attention to landings and touching down just right.
Current Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,Comment
for sale super clean stock fl corsair, only 6 flights pm if interested bunker hill scheme, Dave Brown foams , two complete spare props and the complete plastic spares set new in bag. new retract strut sets L/R as spares new in bag flies like a trainer never any retract issues .custom 3d printed pilot custom painted , location Ventura CA local pick up only .never left in the sun to get damagedComment
I have had my 1600mm Corsair since 2019, maybe earlier than that. I never recorded each flight on a little log sheet inside the fuselage back then, but I figure I have over 200 flights on it. Some parts are showing their age, and one of those is secure mounting of the main gear struts that were getting pretty loose and sloppy. I flew it again this morning and after two flights, I had to ground it to address those issues.
Fortunately, after giving some attention to cleaning out the threads and putting new grub screws in they are now very sturdy and ready for another test flight tomorrow morning, weather permitting.
This Flightline aircraft is one of my alltime favorites, and with these maintenance issues addressed, will put it back up at the top of my fleet for just enjoyable and impressive warbird flying.
I took a pic of it after the flights this morning. I like the backdrop of our Heart Mountain, (8,500 feet MSL). It reminds me of pics I have seen of these Marine flighters like this one flown in the Solomon Islands by top ace (25 kills in the Corsair) Lt. Robert "Killer Bob" Hanson who served and was eventually killed on a fighter sweep in 1944. He was posthumously awarded the MOH for his actions on this combat tour.
👍 1Comment
Davegee,
The Corsair is my favorite bird. Would like to get the bubble top F4U-1D and do a USS Franklin paint scheme, adding all the details like my Birdcage.
Great news on delivery. My prop order should arrive tomorrow so I can have it ready for its test flight. Someone on RC Groups has a flight report. He recommends less movement on ailerons,
Sitting next to the Corsair and P-47 it doesn't look that small. The real one wasn't that big. I've seen both P-12 and F4B-4 at the Navel Museum.
Best Regards, Rex
P. S. I follow my plane shipments also, don't want the driver stopping for sleep. lolComment
I think the size is great for this particular airplane. Should be easy to throw in the truck with a larger plane like the Corsair, P-47, or P-51 in the enclosed truck bed. Can’t wait to put it together and flint maybe next week. Paint scheme and design is just awesome for that era.
cheers
davegeeComment
Davegee,
It is a beautiful plane in that paint scheme. Plenty of room in the backseat of my 1500 chevy. I usually carry two big ones in the bed and 2-3 smaller in the backseat. With electric I don't have to have as much support equipment. Radio's, charger and batteries and no mess to clean up. Give us your first impressions when it arrives.
Best Regards, RexComment
Will Do, Rex! I'm following the online map of the position of the Fedex driver "Wayne" and he is in town and headed generally this way. As we say, Cody isn't at the end of the Earth, but you can see it from here! Seriously, even with only 10,000 people in the county seat of Park County which includes Yellowstone NP, they still have a bunch of deliveries before me. Will let you and others know my impressions when I open it up once it comes later this afternoon.Davegee,
Best Regards, Rex
Cheers
DavegeeComment
Been doing some work on my Corsair. The main retracts and struts were really worn out, replaced them last in 2023. So, I pulled everything out and replaced them with brand-new parts from MRC that came the other day.I have had my 1600mm Corsair since 2019, maybe earlier than that. I never recorded each flight on a little log sheet inside the fuselage back then, but I figure I have over 200 flights on it. Some parts are showing their age, and one of those is secure mounting of the main gear struts that were getting pretty loose and sloppy. I flew it again this morning and after two flights, I had to ground it to address those issues.
I used to have Robart 3.5" diamondtread tires on the mains, it was beautiful! They literally "stuck" the landing almost every time! This time, the struts came with the stock somewhat spongy tires and I decided to fly those this morning. Every landing, (5 of them) it skipped a bit on touchdown and then settled in. I didn't like that so I brought it home and reinstalled the Robarts that had worked so well for me for years. I only got one flight early this afternoon when I went back to the field to see if I could "get the old magic back" on landings. It was a bit gusty but the wind more or less down the runway, so I put it up for one more flight before I hang it up for the winter. The landing worked out great, just as I have been used to with this wonderful airplane since 2019.
So, I'm going to hang it up in the garage, with the caveat that I might pull it down for another flight here and there over the winter when we have some decent flying weather.
I highly recommend the Robarts wheels and tires for this airplane. I also use them on my FMS 1.5m P-47s of which I have three that fly on a regular basis.
Happy flying, everyone!
Cheers
Davegee
👍 1Comment
Even on grass those are the best tires to use.
Cheers
Davegee
