SanExup , thanks a lot for the advices!
I should be able to fix it, the damage is not that bad.
I came up with the 100% throttle with 3S because I heard someone used 60-70% for 4S. So I thought 100% throttle for 3S is ok. Seems I need to try your suggestion of 70% with 3S next time.
Definitely I will try underhand toss next time too. Overhead toss is kinda of hard to control the launch direction. Also next time I think I will use left hand to do the underhand toss too, such that my right hand can hold a bit of up elevator!
Hopefully the third time will be the charm! Thank you again for the detailed explanation!
