Hay SoonerNation. The size of invasion stripes for twin WWII planes was 24"s in width, so seeing that this plane is about 1/10th scale the stripes should be 2.4" or about 2 3/8". The upgrade landing gear are definitely worth the price, just get some Robart diamond tread tires and wheels to swap out for the white wheels that they come with. I went with Motion's Admiral 3600mah batteries. They fit fine. Also if you're going to use the prop decals and the small nomenclature, do you're self a favor and clearcoat the hole plane afterword with Krylon Colormaster Acrylic Cristal Clear in "Flat" finish. When it dries you won't even know it's there, but it adds a little protection to the stickers and the weight is very little.
Soonernation, welcome to Hobbysquawk and the brotherhood of P-38 pilots. I second the advice from rzing. I'll be doing the invasion stipes on my silver one as well. It may not be historically accurate, but being able to keep orientation is a bit more important. No need to reach the airframe's "expiration date" prematurely.
As far as a receiver, if you are familiar with Spektrum, stick with it. I'm using an AR8000 in mine as I like to run differential on my ailerons for birds that don't have semetrical airfoil. This is a fairly hefty bird, and from what I've seen, a great flying bird. So I personally don't see any advantage to going with AS3X.
I'll be running 60C 3600mAh batteries in mine as they can be used for many of my other high performance birds.
Hi SoonerNation, great to have you on the Squawk.
The boys absolutely love this bird as you can tell. receiver vary but I haven't heard of anyone having any problem with a specific one. If you run across any troubles in assembly, feel free to ask and there are also some great videos on the Motion R/C You Tube channel as well.
Grossman56Team Gross!
1. Receivers: Any recommendations? All of my current planes have Spektrum stuff in them so I'm familiar with that brand. How about AS3X. Do I need it? I have some planes with and some without.Originally posted by SoonerNation View PostAnswers to two of your questions.
I fly a mix of Spektrum & Lemon receivers, the only problem I've had is with a Spektrum that experienced a brownout that cost me the plane (it was an F-86).
2. Batteries: Of all my planes & heli's, none are 4 cell so I will be in the market for new batteries. I read a mix of anywhere from 2500mAh to 3600maAh. What are the advantages to the lower v upper range in mAh?
I am using ADMIRAL 3600'S in my planes, they are a good balance between weight and capacity. I have other planes that also use 4 CELL so I standardized on this size.
I find the plane flies really well, no need for AS3X as far as I'm concerned.
