Hi f4u Aussie: The primer I am trying on this project is Krylon Fusion All-in-One Painter Primer in Matte Glacier Gray color. The number on it is 2757. So far, so good. Most of the parts on the Hun Hunter project are new, with the exception of the center wing section which has been around for over two years and getting a lot of flying. There is a bit of gatoring from the past, but the Krylon primer seemed to cover it fairly well, as well as you can do for foam. I did use some thin bondo in spots where there were divots or scratches due to using and transporting the plane in the truck to and from the field over the years.
Overall, I am impressed with it for use on foam. It hasn't had any reaction to the foam and I think will be a good base for painting, which I'll probably do over the Independence Day celebrations here in the USA. I sent in a request to Callie for decals for this plane, and should be getting them underway fairly soon, after the holiday.
I'll let you know how it goes after I have applied the paint coats which will be Tamiya RAF Dark Green in rattle cans. The silver paint over the entire fuse and underneath the outer wing panels will be Rustoleum metallic aluminum color, also from a rattle can.
Stay tuned!
davegee
Stay tuned!
davegee
looks like u have primed almost all and u dont mess around
