Official Nexa 2060mm SBD-5 Dauntless Discussion Thread
  • Scotterc
    • Dec 2022
    • 7
    Originally posted by I_Fly
    Glad to see a number of others with this plane. Mine, actually the VQ Banshee) is a fantastic flyer and gets attention at the field. I do have an issue with losing the hatch and forward canopy. The canopy has been sold out so I'm wondering if anyone has an extra. I can rebuild a hatch but the canopy is a bit more of a challenge.
    PSA - Use a pin or screw or something in addition to the magnets holding your hatch. It's not fun to watch the hatch float down and land in a bean field that seems endless!
    Hey I_Fly!
    Thanks for the tip on the screw. I'll definitely take your advice. If you don't mind me asking, are the required servos mini's or micros? I know the instructions call for mini's, but the photos I've seen with servos looks like the guys are using micro's.
    What is the correct choice on this one?
    • Drvr4spd
      • May 2024
      Originally posted by Scotterc
      Hello all! I just ordered one of the 81" SBD's. I was kinda hoping to put a Saito fg30r3 in her. Has anyone done this? I don't want to destroy the cowl in the process.
      I couldn't find dimensions, so figured I'd post the question here...
      Thanks!
      Did you ever get an answer? I just ordered mine 2 days ago and am deciding between the FG30r3, the FG60r3, or a UMS 55 5 cylinder. I'm definitely putting a radial in her, but need to know the inside dimensions of the cowling to make sure whichever i choose will fit inside completely, minus the exhaust exit of course.
      • Matt Mathias
        • Dec 2021
        • 25
        Yes the small Saito fits in the cowl perfectly. have to use the baffles. Its what I fly mine with.
        • Scotterc
          • Dec 2022
          • 7
          Thanks, Matt. Sounds like if I go this route, skip the Keleo ring and stick with the stock exhaust tubes? Or should the Keleo ring fit without cowl mods as well?
          Also, I've never used a baffle... this would be my first radial. Do you have a photo to demonstrate the placement of the baffles?
          • Matt Mathias
            • Dec 2021
            • 25
            I use the Keleo ring no problem
            • Matt Mathias
              • Dec 2021
              • 25
              I'm not home now or I would show you the baffles I bought from keleo the glue into the cowl and should be positioned about midway on the cylinders of the radial
              • Hockeypoor
                • Oct 2025
                • 3
                Ordering as soon as they are back in stock. Will a 30CC twin fit in the cowl? And is that enough engine?
                • Hockeypoor
                  • Oct 2025
                  • 3
                  Originally posted by Fallguy44
                  Hello. Can't find too much info out there on this plane. Curious to hear from other owners how they feel about this plane. Wondering what the ideal engine is. Will a DA35 or DLE35ra fit inside the cowl? Any other info would be great. Thank you!!
                  Did you ever get an answer? I have a dle35 and am wondering the same
                  • Hockeypoor
                    • Oct 2025
                    • 3
                    Will a dle 55 with starter fit?
                    • Joe Hockey
                      • Oct 2024
                      • 37
                      I have seen this plane fly on a 35 and 55 with cuts to the cowl , obviously the 55 requires more cuts. I have the smaller one flying and painted and the larger one new in box waiting for assembly . I am going electric with a power system equal; to gas 35 cc. I have dealt with this brand long before Motion was ever involved.
                      I have had great luck with the brand VQ and the models fly great .
