Sounds good to me, keep the updates coming!
Skyshark 1/9th Scale TBM Avenger Build
So I got the fuse, vertical and horizontal glassed and primed. Elevator and rudder covered and doped. The fuse is g9ng to require a bunch of filling ans sanding as I took me awhile to get back into the swing of glassing. 1/64th chart tape for panel lines and I'm waiting on some 1/8th tape to do the fabric. Been a bunch of work with very little to show for it. While things are drying I'm sanding and filling the wing in prep for glassing. It's all good though I'm pleased with the progress.
Mike3 Photos\"When Inverted Down Is Up And Up Is Expensive\"Comment
My where did the time go? 10 days in the Caribbean than another 10 to catch up from being gone. The shops a disaster ( my fault). My age is catching up with me. I was hoping to get the Avenger finished for fall test flights and I may not make it. Priority is getting the shop squared away. A friends vision got really bad and he grounded himself I acquired a few things that I didn't really need but the deal was too good to pass up. He donated a bunch of stuff to our club and I need to figure out how to dispose of it and I thought retiring and cutting back my .part time hobby shop gig would net me more time for the hobby.
Mike\"When Inverted Down Is Up And Up Is Expensive\"Comment
Been awhile and I got caught up in several other projects. The turret section was really bugging me than I found IFlyTailies did a 3D printed one. So I'm going to see if I can adapt it to my Avenger.
Mike2 Photos\"When Inverted Down Is Up And Up Is Expensive\"Comment
Squadron/Signal publications and chartpack tape.... That is when it gets fun!! (and a calculator if you are full-blown OCD)… Nice job!!! 1/9th scale x full scale divided by how many beers X why is the tape crooked? :PComment
My backs killing me this morning from leaning over the bench all day. If you ever done this process you know what I mean. Think I'm going to take a few liberties on the fuse panel lines.
Ok. started on the fuse and not sure how far I want to go. What's on there is about 1/2 of what should be there. I'll take a break and maybe do some more. Funny thing is from 10 feet no one will even know there there.
Roger that!!! However, YOU will know!! I love doing that stuff....
Just a suggestion. I am 6' 2" and a normal table kicks my butt from back pain.
I have two (2) heavy duty black tote tubs with yellow lids from Lowes or Home Depot, rated at 700 lbs capacity. They are empty and are used under the legs of my folding table. It puts the work surface right at my hands and no bending over necessary.... Unless you drop your beer!!! LOL
Hope that may help Bro!!! Great job!!! :Cool:Comment
Looks great Mike. We really need an Avenger in 1600mm -2000mm maybe yours will be the incentive, right Alpha??
Team Gross!Comment
Thanks. Worked on setting up the motor mount and mounting the cowl along with the tail feathers today. Very productive day. Once I'm satisfied with the fuse I'll paint it. the wings done but needs to be glassed and panel lined which is no big deal. Straight flat surfaces are easy compared to the fuse. Amazing what you can get done in just a few hours. I have no clue why this has taken so long.
Mike
Primed the Cowl , Elevator and Rudder. Mounted the horizontal this AM and got the motor mount fabricated (modifies a Eflite I had) and motor mounted. Clearance looks good. I'll fabricate a mount for the ESC once I'm sure that it will all work. The cheap dummy radial have might work with modification. Really going smooth lately.
Well been hard at it. The wing didn't want to mate correctly (no clue why0 fit fine when I built it. Had to cut into the belly pan and "adjust" everything. Manufactured some semi scale gear doors. Think I have it. I'm really close to glassing the wings. Think I may have found a dummy radial that looks OK I'm working on fitting it today. On her wheels for the first time really a great feeling. Looks like she wants to fly.
.png)
