    That'd be great!
    I'm looking at the forward area as per the first pic and the cockpit pieces (seats, gunsight and instrument panel)
    I think that with adding the printed frame in the nose, it would add to the overall strength and rigidity of the damaged area.
    I'm looking back through your build thread, was there something you did to strengthen the nose gear area?
    I'm going to stay true to Dave's Cactus Kitten so nothing in the rear will change unless I can find a good pic of the gunners bay, then I'll hop on Tinkercad and see what I can do.
    (Dangerous Dan)
    Grossman56,
    I have the aft greenhouse if you want it.
    I modded mine to a "C" variant, so no greenhouse, just a bubble.
    Also, if you'd like some of the STL's for the forward greenhouse, let me know.
    Best, LB
ID:	452950 Click image for larger version
ID:	452951 Click image for larger version
Name:	Rear Fuselage Bubble-2.jpg
ID:	452952 Click image for larger version
Name:	Pilot Mod-2.jpg
  • jetfool
    Nice job Grossman. Going to look great after you detail it out. Rex
    You must have been reading my mind Elbee!
    What with having the green house off and the canopy as well, plus winter coming,
    PROJECT!
    She's out of the clamps, bound and gear is down.
    As Dave was saying, there is nothing on the southern end. No rudders and no elevator.
ID:	452941 Click image for larger version
ID:	452942 Click image for larger version
ID:	452943 Click image for larger version
ID:	452944 Click image for larger version
ID:	452945 Click image for larger version
ID:	452946 Click image for larger version
    I suspect the little box at the rear so I have another one on the way as well as the birdcage and a new gear door.
    Then I'll pull the tail off and see what's up.
    Should have ordered some prop blades as well, I was thinking that they were the same as the Tigercat but according to Wes, they're different although they fit in the spinners.
    At this point they're not necessary but always nice to have some spares.
    (Dangerous Dan)
    Got some stills off Kermit weeks tour of his B 25, good stuff as his is very authentic.Gret for reference.Grossman56(Dangerous Dan)
    Danger,
    Ah yes, the "Kermie Cam"...great videos.
    Are you going to detail out the cockpit and forward gunner's office?
    I know a guy with STLs. LOL
    Best, LB
  • jetfool
    Grossman 56,
    Your rebuild is amazing. You are a foam craftsman. Better be careful when it's finished Dave will pry it out of your hands yelling MINE! MINE! MINE! LOL
Name:	Screenshot 2026-09-20 220054.png
ID:	452870 Click image for larger version
Name:	Screenshot 2026-09-20 220222.png
ID:	452871 Click image for larger version
Name:	Screenshot 2026-09-20 220307.png
ID:	452872 Click image for larger version
Name:	Screenshot 2026-09-20 220447.png
ID:	452873 Click image for larger version
Name:	Screenshot 2026-09-20 220620.png
ID:	452874 Click image for larger version
Name:	Screenshot 2026-09-20 221231.png
ID:	452875 Click image for larger version
Name:	Screenshot 2026-09-20 221301.png
ID:	452876 Click image for larger version
Name:	Screenshot 2026-09-20 221557.png
    Gret for reference.
    (Dangerous Dan)
    Making impressive progress!
    Dan's patented airplane pinchers at work, the clothes pin adjusts the amount of pressure applied while the elastic bands hold the thing together.
    Wheel retract mount is back in place. Future note, reinstall this piece first as it would have been much easier. It also adds a lot of strength to the forward section.
ID:	452866 Click image for larger version
    The forward section is still split. Last step is to glue them together once the other parts are dry.
    hen a little sanding and a little painting ad voila! She's new!
    A couple of parts to order like the forward cover and gear door, pitot tube and the Radom underneath seems to be missing as well. Then bind it and drop the gear, see what's up with the electronics.
    (Dangerous Dan)
    I have every expectation that Dan will be able to rehabilitate this airplane to its former glory. Over the weekend, I decided I wanted to get my 100th flight in that day. I was sitting at 90 and just decided to keep on flying it until I hit 100. It has never been severely or even mildly damaged up to this point. Anyway, got FMS P51 Mustang 1450 & 1700 Flight Times? in, but before packing it up, I thought I'd like just "one more" to finish up its career as the previous landing had been less than ideal, not terrible but one I wanted to improve on. I had no plans on flying it after that.
    Unfortunately, even though I had 100 successful flights on this airplane, the takeoff roll went normal and then I noticed that I had no control of my elevator as the airplane was screaming down the runway towards the end. I was too slow to try and use the Very impressive reverse thrust on this airplane, and it went rolling at high speed off the end and impacted into some nasty scrub brush which wrecked the nose section. The rest of the plane was undamaged. So, a major chore will be finding out what happened to elevator and rudder control. Nothing obvious at this point.
    I offered the plane to Dan, as he is well known for his amazing restorative skills with foam airplanes. There is still a lot of life with it if he can repair the damage to the nose. I also offered that if that doesn't work, he can buy a replacement forward fuselage section for about $117 and essentially have a new airplane.
    I did a lot of upgrades with the plane that are still good. The Robart diamond tires, WWII scale wheels for the nose and mains, and other stuff like that. This was based on a real airplane that lfew in the Southeast Asia Theater in WWII, and was lost to antiaircraft fire near Saigon in what was then French Indochina. All five crew were lost, unfortunately.
    So, I"ll look forward to see Dan's progress and hope he has a lot of good flights on it like I did for over two years.
    Cheers
    Davegee
    Grossman56,
    An emerging Phoenix from the ashes.
    Best LB
  • RRHandy
    A little foam-tac, a little steam, a little paint and you have a plane again. Balsa, well what can I say.
  • jetfool
    Grossman56,
    Looking forward to the re-birth. Rex
    And so it begins.
    Dave had an accident with his B25, resulting in a crunched nose. He was kind enough to donate it to yours truly and as I have had lots of practice in rebuilding destroyed planes.
    This to this:
ID:	452809 Click image for larger version
    And this to this:
ID:	452811 Click image for larger version
    among the latest. I couldn't resist the challenge.
    So she's in traction right now as the first step begins... Click image for larger version
ID:	452813 Click image for larger version
    The first trick is to try and get everything aligned and glued back into place. The metal ruler helps to reinforce a straight line although when the other side of the nose is reinstalled, the final effort at alignment is made.
    Cool airplane, too cool to sit in the scrap box, just like the others.
    (Dangerous Dan)
  • vrosi1963
    My B25 custom is for sale for the right price , that includes the 3d printed gun nose , dave brown foams installed Cali graphics only flow 8 times stIll looks like new .pm if interested local pick up only on so CAL
  • Flyer Phill
    Hi guys,
    Quick question regarding replacement wheels. Has anyone had issues trying to remove the axles? I've removed the grub screws but the axles won't budge.
    Edit: Found the answer....heat!
  • GINGERBREADPILOT
    I have one for sale. I purchased it from Hobby Haven in Des Moines. It was hanging from the ceiling. Never flown. Rudders have not even been glued on. Has all the electronics. I never found the time to get it airborne. I am located in Norwalk, IA. $150.00 Firm. I paid 200.00. Want to pick up a 90MM F22 and need room for it. I will get some pics uploaded. Anyone is welcome to stop by and look at it. I have never paired it to my radio. I do know that the original owner passed away before getting to maiden it. His daughter brought it in to sell on consignment. It has been stored in by entertainment room and never exposed to humidity or heat. Just want it to fly and make someone happy.
  • Fast N Light
    Originally posted by vrosi1963
    Yours looks great. I went with the stock rims and Dave Brown foams that completely cancel out any bounce on a paved runway., the silver keep the plane very cool in the California summer sun , green will bubble the skin . will print a set of the 3d rims soon but use foams glued to the rim possibly. haven't mad a huge effort to detail the b-25 yet
    Thanks It came out even better than I expected. Callie did a fantastic job on my custom graphics.
    I have used Dave Brown tires extensively and they are great! However, I recommend Robart for the B-25 based on appearance. The 3.5" main wheel has presence, taking away the toy look of the OEM wheel. Both DB & Robart perform well as low bounce. Robart has a bit more weight, but it will have better durability in the long run.The B-25 can carry another oz or two...
    Originally posted by Craterman
    I need some assistance...I just assembled my Flightline B-25J last night following Wesley's video...and it went very well! He addressed needing a 7 channel receiver if using the bomb bay. Something that wasn't addressed is on each of my throttle wires, there is also a reverse brake connection. I assume they also connect to a Y cable, but I'm not sure where to plug it into the receiver. I have a Spektrum NX8+ transmitter, and do I just choose a switch for the brake or does it connect to the throttle somehow?
    "Y" the 2 plugs together, knowing that the single wire on each is a "signal" wire (disregard the color). Plug that into an empty channel and then assign a switch to that channel. On your NX8, go for ch.8. I assign the long toggle on the right. It's a 3-way but just don't stop in the middle. Test to make sure both motors reverse together and at the same time.
  • Craterman
    Originally posted by Fast N Light
    Your model looks great! I like the silver and for me the gunship nose is the only way to go.
    For mine I stayed with olive/grey and made a drop in 3D printed nose. Replaced the 50 cal barrels all around including Browning M2 full bodies for the turret. Rims for ]
    F&L,
    Great mods and perfectly executed per usual.
    Best, LB
