    Originally posted by Elbee
    davegee
    It's looks good to me, though I am certainly not an expert in any form on this.
    There is some small detail near the base in a couple pictures, do you think that is worth the effort?
    It appears to be a flat metal plate, a hole at each prop center, and screws that are wire locked.
    Best, Steve
    Click image for larger version Name:	image009-10+.jpg Views:	0 Size:	150.0 KB ID:	426733
    Thanks, Elbee. to be quite honest, your mentioning those details in a recent email was the first I had even Known those things exist! Somehow, those details escaped me over the years. Yes, I definitely think that those details are worth adding to these CE prop domes. I plan to do that with these test article spinners. They're small, but not too small to be noticed as fine details in a good scale model. Thanks for bringing that up, should be fun to add those details! Funny, that photo you just posted of the nose of that P-47, a few hours ago I found that same one online, printed it up, and have been studying it for adding these details later. Small world!
    davegee
    Originally posted by jetfool
    Davegee,
    That spinner looks great. I hope my alum. spinners come out as good. Thinking of using plas-ti sheet to make the flat plate and add tiny screws in spinner base. Every little detail I add just improves the scale look. Taxied mine at our grass field and the lower wheel door cover came off. I think the test flight will be flown without them. Those little screws don't have much bite in the plastic to the strut. Went flying today. Beautiful out.
    Best Regards, Rex
    Glad to hear that, Rex. I'm sure your machined CE prop domes will look just like the real thing!
    I have two printed spinners I got from the STLs that Elbee was kind enough to let me have. I'm going to use them as test articles to see how they stand up to flying stresses. I think they'll do fine. I might fly tomorrow morning if the winds aren't too high. We had some pretty intense lightning storms this afternoon, and I might not be able to fly for a few days. Next weekend is a fly-in at our local field, usually some campers come from all over. I generally stay away from those things. Mostly 3D stuff which is fine for them, but I'll always be a warbird guy!
    Let me know if you'd like me to send you one of the test spinners once I'm done with them. Might be nice having a spare in case something happens to one of the others you are making.
    I look forward to hearing about your maiden of "Lucky." I'm sure you'll do fine with it. Those wide gear are always great for takeoffs and landings. One of my favorites to fly,, the FMS 1500mm P-47. If you get a chance sometime, if you could send some pics of your detail work of the base of the CE prop dome, that would be helpful as I want to add those details to these test spinners, too.
    Cheers
    Davegee
  • jetfool
    Davegee,
    Best Regards, Rex
    davegee
    Best, Steve
    Hi Steve: I didn't see an interior profile yet, but I can see through the CE prop dome as I look at it from behind. I think it will be plenty strong, based on a similar profile we did 2 years ago. There shouldn't be much stress on this prop dome as all the stress is on the nut and prop hub behind it. I flew several flights with the one we came up with and it has never been an issue.
    I like the shape of your CE prop dome more than what we came up with back then. I printed two of them that I plan to test on two of my jugs. I might be able to do that tomorrow and sometime next week, weather permitting. I'll attach a pic I just took of one hand torqued to the prop shaft of "Ole Cock." The M10 150 tap you suggested worked out great.
    Cheers
    Davegee
    davegee
    Did you take a look at the interior profile?
    Since there is little stress I simply tried to make it light in weight.
    I 'borrowed' that structure from what I have seen in designs from other spinners.
    It is similar to what I had done for the Flightline Spitfire and Flightline Corsair.
    Thanks for the update and I'm looking forward to your review at a later date.
    Best as always, Steve
    Originally posted by davegee
    Hi Steve: I've got the printer warming up now! I'll let you know how it goes. I think Rex is still planning to make me a machined aluminum hub for my plane, so I could send this one to him if he wants it and isn't going to machine his own CE dome. Is always good to have a spare on hand just in case....
    Thanks so much!
    Davegee
    Hi Steve: print went very well. I'll pick up a tap for it tomorrow at Ace. I like your profile of this bullet shaped prop dome, better than what we came up with over 2 years ago. After I sand and prep it, I'll probably use some Alclad alumiinum paints to paint it. Should be able to test it in the next week or so with my Ol' Cock P-47D that had the CE prop on it. Will keep U advised!
    Thanks again!
    Cheers
    Davegee
    P-47 Curtis Prop Hub_v2.stl
    Dave,
    Give this a go.
    I will print one later today or overnight.
    I enlarged the base opening where the thrust washer and nut are to 0.906"
    The thread is M10 150 and I would run a tap through it by hand after printing.
    The only place it should require 'support material' in the hollowed opening for the thrust washer and nut.
    Extra detail could be added at the base to simulate the flat metal flange, the locking nuts with wire and holes for alignment, but I digress .
    Let me know how it goes...
    Best, LB
    Thanks so much!
    Davegee
    Hi Elbee: if you still need the specs on the thrust washer and nut:
    the thrust washer is 0.8655 inches in diameter
    the prop nut maximum diameter measured from point to point across the nut as it spins, is .7335 inches, so it looks like it would barely clear a .75 inch diameter hole, in theory, anyway.
    cheers
    dg
    Dave,
    Give this a go.
    Best, LB
    davegee
    In your first picture of the thrust washer, nut, and shaft, what is the diameter of that thrust washer?
    Will 3/4" hole be large enough?
    Best, LB
    cheers
    dg
    Right on Durango!
    Was hoping my new NX8 would be waiting for me when I got home, but it was delayed:face_with_symbols_o
    Now they're saying Monday, what can you do??
    As my old DX8 Gen1 finally gave up the ghost (registered her on Dec31, 2014)
    No radio, lots of yardwork.
    (Dangerous Dan)
  • jetfool
    Thanks Dan. Modelers helping modelers, best hobby to be in.
    Here's a great video showing a lot of close ups of the RB P47
    And here's a still of the spinner used with the Curtis electric props
Name:	Screenshot 2025-05-30 140818.png
    Hopefully this helps!
    (Dangerous Dan)
  • jetfool
    Gentleman, My old eyes are deceiving me. Just measured the bore and washer. The washer is 7/8" (.875) diameter and I used a 29/32 (.906) drill bit to bore the hole. Forgive me!
    Best Regards, Rex
  • jetfool
    Davegee and Elbee,
    On my alum. spinner I found 3/4" bore and 3/8" depth works great and clears the prop nut and washer ok. The prop washer was in mm and smaller than my 3/4" bore, spinner fits tight against prop hub with hand tight, takes a little muscle to untighten. 1/2" depth would be ok also.
    Dave I'm still working the vs2 alum. spinner. It will weigh more than a 3d one, but I still think the weight will not be a problem flying with it. I will keep all informed. The alum looks good on the model polished up.
    Best Regards, Rex
    davegee
    Best, LB
    DG,
    So, if I increase the "gap" at the base to 0.5" from 0.375" and decrease the threaded portion to 0.5" from 1.0" it's a go?
    And you think the profile is good to go as well?
    Best, LB
    Hi LB and Rex: I am enclosing a few pics I took of my setup for a CE (Curtiss Electric) prop set up and printed propeller dome done a couple of years ago. I have been using this with this airplane with no problems at all since then. There are certainly ways to improve it, but it worked for this project for the time being.
    You can see that I have mounted the FMS V3 Corsair prop and hub and replaced the FMS OEM prop shaft with the larger one that the 1700mm Corsair uses for the V3 setup. Works great.
    My printed spinner or CE prop dome I just measured the inside with a caliper. From the aft edge of the prop dome to where the threaded hole for the prop shaft to screw into is 1/2" (.5") deep. We continued that hole much longer than it needed to be, drilling and tapping it to 1 (one) inch deep. With this arrangement, the prop dome inside clears over the nut that fastens down the CE prop and hub to the prop shaft and airplane.
    There's probably a lot of ways you could go with this, but that's what we did two years ago. Other things came up after that and we didn't go any further until Rex and I came up with the idea to have some HS students use this as a project to learn more about 3D printing and other topics for their school.
    I think your profile shape for the prop dome looks very good. Mine has a definite point where it changes from a cylinder to a curved dome at the end. I didn't like how that looked and we were going to try and improve that, but never did.
    I think to your question, you could try it reducing the "gap" from .5 inches to .375 inches deep, but without test fitting one with that reduced dimension, I couldn't guarantee that the inside of the CE dome wouldn't catch on something when you tried to screw (hand torque) it on over the propeller shaft and the nut. For ours, .5 inches worked fine, and we made a carved out dome area inside just to be sure. It was never a problem doing it like this. Same for the depth of the threaded hole to screw on the CE prop dome onto the prop shaft. I'm pretty sure if you only drilled and tapped to .5 inches instead of the 1 (one) inch that we did, it would work fine. Even though weight really wasn't a problem for this printed CE dome, I think we wanted to test for any problems if we eventually made an aluminum spinner, which was one of the goals at that time, to reduce weight as much as possible.
    Would be good to get Rex' opinion and take on these things before going any further.
    Best,
    DG
    Click image for larger version  Name:	IMG_2906.jpg Views:	0 Size:	68.0 KB ID:	426700 Click image for larger version  Name:	IMG_2904.jpg Views:	0 Size:	54.0 KB ID:	426702 Click image for larger version  Name:	IMG_2907.jpg Views:	0 Size:	90.1 KB ID:	426701
    Hi Elbee: I think I can chime in a bit and Rex can add anything he wants to, since I have been using these for several years. The M10 nut screws tight with a wrench onto the threaded prop motor shaft. That's what keeps the propeller and its hub attached to the airplane.The simulated Curtiss Electric prop dome is recessed about 1/2" or so to clear the nut affixed on the prop shaft. The Curtiss prop dome is also threaded to hand-tighten onto the threaded prop shaft but really doesn't have any structural strength (at least as a printed part to keeping the propeller in place on the shaft in flight.)
    Working with my contact on the East coast a few years ago, we never really came up with a satisfactory profile design as good as you have come up with to mimic the Curtis Electric prop dome. I still fly my printed dome on one of my P-47s, but a light weight machined aluminum dome has always been preferred. Weight is an issue, especially with foamies, as you can imagine.
    Best,
    Dave
    DG,
    Best, LB
    Grossman56,
    Glad your back. We finished out our basement a few years ago and having the outlets where I need them makes a job go smoother.
    Elbee, your spinner looks great, thanks for stepping up and designing a 3d spinner. It has to be a lot lighter than my aluminum. I have included a drawing with Dave and My measurements, the spinner screws on the motor shaft and fits hand tight against the propellor hub. A recessed opening 3/8" deep allows the prop washer and nut to fit inside the spinner. Our measurements fit and look well on the FMS P-47. If my drawing is hard to read, please advise.
    Best Regards, Rex
    Best,
    Dave
    commented on 's reply
    So the prop hub is functional, i.e., it is what keeps the propeller on the motor?
    Or do you use a M10 to secure the prop and the Prop Hub simply threads onto the shaft?
