The FL P-38 silver match is TAMIYA TS-30 silver leaf.
You know what that finish looks like.
There may be a better option for a polished aluminum-like paint, but the TS-30 is pretty good, and it re-paints/repairs very well.
No the polarity was correct. It was in the AUX2 port. I never changed it from when I originally plugged it in. It simply stopped flashing the next time I plugged the battery in. Weird.
When I plugged it in again it stopped. I assigned it to a switch and it’s working fine now. Who knows? Dang gremlins.Leave a comment:
Something not plugged in right I would suspect. If 100% sure everything is in right it would be a bad E27 Control Board.Leave a comment:
I can’t comment on the guns firing…I don’t use / 6 ch radio. Possible wiring short or incorrect factory wiring?!
For the elevator/flap mix…by the manual initially. After some flights, I reduced the mix amount slightly.
The manual mix is a good starting point.
Let us know how your maiden flight goes.
-GGLeave a comment:
Question...I bound successfully, everything is working as it should - but - the guns are firing at all times. I even unplugged the gun lead from the port and it's still firing! Wait, what??
Also, what are you guys doing for the elevator/flap mix?Leave a comment:
Good deal, and thanks for doing that.
Potentially MUCH safer, now, for this powerful motor/big prop combination.
-GGLeave a comment:
