Official FlightLine 1600mm P-51D Mustang Thread
    P-51D Mustang 1600mm (63") Wingspan - PNP from FlightLine - FLW307P
    The North American P-51 Mustang is widely regarded as one of the most important and capable fighter aircraft of World War II. Designed as a long-range escort fighter, the Mustang combined speed, range, and maneuverability to protect Allied bombers deep into enemy territory. Its laminar-flow wing, sleek fuselage, and powerful Merlin engine helped make it one of the most effective piston-engine fighters ever flown.
    The FlightLine RC 1600mm P-51D Mustang captures the speed, elegance, and authority of one of aviation’s most iconic fighters in a large-format electric warbird designed to look right and fly smoothly. Capturing the unmistakable Mustang lines and stance, this model delivers true scale presence on the ground and commanding performance in the air.
    The airframe comes fully painted from the factory, showcasing a clean, scale-accurate finish that highlights the Mustang’s sleek lines and surface detail. Included with the model are four complete marking options, allowing builders to choose their preferred scheme during final assembly. The featured “Frenesi” markings serve as the flagship livery, while three additional decal sets provide flexibility to represent alternate looks without the need for repainting.
    Built using FlightLine’s proven multi-material construction, the 1600mm P-51D combines molded EPO foam with plastic, plywood, carbon reinforcement, and aluminum components to create a strong, lightweight airframe. Functional flaps and retractable landing gear enhance realism while supporting smooth takeoffs, stable approaches, and confident landings on a variety of field surfaces.
    Designed to balance scale authenticity with everyday flyability, the FlightLine 1600mm P-51D Mustang offers predictable handling, excellent visibility, and the kind of smooth, flowing flight that suits the Mustang’s legacy. Whether flown in wide, graceful passes or displayed as a centerpiece in the pits, this is a Mustang that delivers size, style, and substance without compromise.
    Commanding Mustang Presence
    With a 1600mm wingspan and true 1/7-scale proportions, the P-51D Mustang commands attention on the ground and in the air. Its unmistakable lines and stance deliver the presence expected of a large-format warbird.
    Factory Finished, Builders Choice
    The airframe arrives fully painted from the factory, showcasing crisp panel lines and a clean, scale-accurate finish. Four complete marking options are included, allowing builders to choose their preferred livery during final assembly, with “Frenesi” serving as the flagship scheme.
    Screwless, Quick-Release Wings
    Spend less time in the pits and more time in the air. The P-51D Mustang uses screwless, quick-release wing mounts that make field assembly fast and convenient. Transport is easy, and setup takes only minutes.
    Scale Gear, Real Confidence
    Electric retractable landing gear, including the tail wheel, feature CNC-machined scale shock absorbing struts and cycling gear doors for authentic operation. Large 95mm main wheels improve ground handling and make the Mustang well-suited for grass and uneven field surfaces.
    Realistic Details Brought To Life
    Integrated LED navigation lights and switch activated simulated gun muzzle flash LEDs in the wings add realism and enhance visibility in the air. These functional details bring the Mustang to life both on the ground and in the air.
    Built Scale, Tuned For Performance
    Functional flaps reduce approach speeds and improve landing control, while the tuned airframe minimizes torque effects during takeoff and landings. Combined with an accessible sliding battery tray for quick swaps and easy CG adjustment, the Mustang is built to fly as confidently as it looks.
    • Large-format P-51D Mustang with 1600mm wingspan and 1420mm length for commanding scale presence
    • Designed at approximately 1/7 scale, balancing visual impact with stable handling
    • Factory-finished airframe ready to receive four included marking options, with “Frenesi” as the flagship scheme
    • Integrated LED navigation lights enhance visibility and scale realism
    • Functional simulated gun LEDs in the wings add authentic WWII combat presence
    • Screwless, quick release wings and auto-connect wiring make field assembly a breeze
    • Accessible sliding battery tray allows quick battery changes and easy CG adjustment
    • Scale 4-blade propeller (16x12) enhances realism and performance
    • Proven multi-material construction combining EPO foam, plastic, plywood, carbon reinforcement, and aluminum structure
    • Predictable and controllable ground handling for smooth takeoffs and landings
    • Functional electric retractable landing gear (including tail wheel) with scale cycling gear doors
    • Large 95mm main wheels improve operation from grass and uneven field surfaces
    • Functional scale flaps reduce landing speed and improve approach control
    • Optional drop actuator support for scale fuel tank or other payload drops
    • Carefully tuned design minimizes torque effects during takeoff and landing for improved directional stability
    • Factory-installed 5055 brushless outrunner motor compatible with 6S power systems
    • 80A brushless ESC matched for smooth, reliable power delivery
    • Ball linkages on all control surfaces provide precise handling
    • Long-lasting nylon hinges built for reliable performance
    • FlightLine P-51D Mustang 1600mm (63”) Wingspan Warbird - PNP
    • Electronic, CNC machined retractable landing gear and cycling gear doors (installed)
    • Factory-installed digital servos (3x 9g plastic gear, 1x 9g Hybrid, 2x 9g metal gear, 5x 17g metal gear, 1x 23g metal gear)
    • Factory-installed Daylight-bright LED lighting system and functional wing gun lights (installed)
    • Motor and ESC (installed)
    • Instruction Manual
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 2 Hours
    Model Scale 1/7 Scale
    Wingspan 1600mm / 63in
    Length 1420mm / 55.9in
    Weight 3270g / 115.4 oz (without battery)
    CG (Center of Gravity) 120mm (4.7") as measured from the wing root leading edge aft
    Power System 6S 5055-340Kv Brushless Outrunner Motor (included)
    Electronic Speed Control 80A, EC5 Connector with reverse thrust (included)
    Propeller / EDF 18x12 4-Blade Propeller (included)
    Servos
    • Tail Gear Door - FSS31091-700
    • Main Gear Door (Left) - FSS31091R-300
    • Main Gear Door (Right) - FSS31091-300
    • Tail Wheel Steering - FSS31093-500
    • Landing Gear Lock (Left) - FSS31092-200
    • Landing Gear Lock (Right) - FSS31092R-200
    • Elevator - FSS31231-700
    • Flap (Left) - FSS31172-200
    • Flap (Right) - FSS31172R-200
    • Aileron (Left & Right) - FSS31172-500 (1 per aileron, 2 total)
    • Rudder - FSS31172-200
    Landing Gear Electronic retractable main gear with all metal shock absorbing struts and retractable tail wheel with scale plastic details (included)
    Required Battery 6S 22.2V 4000-6000mAh LiPo with EC5 connector (required)
    Required Radio 6-8 channels (6 for flight; +1 per optional feature: Muzzle Flash, Thrust Reversing)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Yes
    Brakes Thrust Reversing
    Gyro No
    Hinge Type Nylon
    Material EPO Foam
    Skill Level Intermediate
    Build Time 2 Hours
    Recommended Runway Surface Well manicured, short grass and hard surfaces
    PNP Version:
    Buy FlightLine P-51D Mustang 1600mm (63”) Wingspan Warbird - PNP online at Motion RC. Order online with fast delivery.
    PNP with Gyro Version:
    Buy FlightLine P-51D Mustang 1600mm (63”) Wingspan Warbird with Gyro - PNP online at Motion RC. Order online with fast delivery.
      • 4873
      Aros
      Well y'all have done it again.:partying_face:
      Looking forward to the reviews on this one.
      Best, LB
        • 5424
        It's exactly what I want but the price is nuts.
          • Nov 2013
          • 2787
          • Cody, WY
          I'd prefer it less expensive, but since I retired my E Flite P-51Ds, I could see getting this one. I like the droppables, the scale landing light, and the lighted machine guns, just for fun.
          As a hopeless scale geek, I like they have it painted in the basic color of the famous 357th FG out of Yoxford England. I would probably choose Nooky Booky that was flown by "Kit" Carson, one of the stalwart aces in this unit along with the likes of Chuck Yeager and several others.
          Davegee
          • rc_air_shenanigans
            • Dec 2022
            So we released the plane- showcased the droppable tanks, but can’t get the plane with the droppable tanks….
            • jetfool
              • Nov 2022
              • 1366
              • Crawfordsville, Indiana
              Elbee,
              Expensive yes, but this could be a start of a great P-51B malcom hood project that I think you could well accomplish and we would all enjoy watching.
              Best Regards, Rex
              • f4u ausie
                • 1242
                • Melbourne
                Well it is about time. Was always going to be expensive. However looks. Good. I'm sure to to get one just not right now
                  • 4873
                  jetfool,
                  Yes, I, too, can see a "B" hiding in there from way over here.
                  Best, LB
                    • Nov 2013
                    • 2787
                    • Cody, WY
                    Originally posted by Elbee
                    jetfool,
                    Best, LB
                    I can just see a Malcolm hood from here, too!
                    • f4u ausie
                      • 1242
                      • Melbourne
                      I've had a quick look. What is or was a Malcolm hood. I think was retro fitted in England for European conditions in the early p51???:face_with_monocle:
                        • Nov 2013
                        • 2787
                        • Cody, WY
                        Craig: here is a link to some info on the Malcolm hood: http://www.aerofiles.com/malcolm-hood.html
                        Cheers
                        Davegee
                          • 5424
                          It was a retrofit canopy that had much better visibility.
                          • f4u ausie
                            • 1242
                            • Melbourne
                            Thanx guys
                            • f4u ausie
                              • 1242
                              • Melbourne
                              Trouble some me again... The motion video says a 340 kv but the freewing says 390 get with the program . Which is it. Lol. Ones for spit and 1 for f4u
                              • Randy H
                                • 70
                                • Surprise AZ
                                Another P51 just what we need. Its a beautiful model but how about some adversaries such as a ME109G or a Zero? Cost is also kind of high but then everything is going up.
                                • WDivCV61
                                  • Oct 2023
                                  • 23
                                  • Show Me State
                                  Yeah for the price the Quick Drop Actuators should've come with imho. I ordered one. Love me some planes with functional gimmicks.
                                    • 5424
                                    $660 is more than kind of high when the very similar Spitfire which was $349 when released is now only $469. 41% more.
                                    • WDivCV61
                                      • Oct 2023
                                      • 23
                                      • Show Me State
                                      Considering the E-Flite 1.5 Mustang was pushing $600 at the end of its availability I can't get too excited about this one's price especially considering it has more features, and is biggerrr..and looks more scale. To me anyway.
                                        • 5424
                                        I'm not a EFlite fan (I consider them exorbitantly priced) though I had, I think six of the FMS 1450 Mustangs. Did that $600 include a receiver?
                                        Looks like it did @$580. The Spektrum AR637TA 6-Channel Receiver is about a $100 receiver so not really comparable in price either.
