The North American P-51 Mustang is widely regarded as one of the most important and capable fighter aircraft of World War II. Designed as a long-range escort fighter, the Mustang combined speed, range, and maneuverability to protect Allied bombers deep into enemy territory. Its laminar-flow wing, sleek fuselage, and powerful Merlin engine helped make it one of the most effective piston-engine fighters ever flown.
The FlightLine RC 1600mm P-51D Mustang captures the speed, elegance, and authority of one of aviation’s most iconic fighters in a large-format electric warbird designed to look right and fly smoothly. Capturing the unmistakable Mustang lines and stance, this model delivers true scale presence on the ground and commanding performance in the air.
The airframe comes fully painted from the factory, showcasing a clean, scale-accurate finish that highlights the Mustang’s sleek lines and surface detail. Included with the model are four complete marking options, allowing builders to choose their preferred scheme during final assembly. The featured “Frenesi” markings serve as the flagship livery, while three additional decal sets provide flexibility to represent alternate looks without the need for repainting.
Built using FlightLine’s proven multi-material construction, the 1600mm P-51D combines molded EPO foam with plastic, plywood, carbon reinforcement, and aluminum components to create a strong, lightweight airframe. Functional flaps and retractable landing gear enhance realism while supporting smooth takeoffs, stable approaches, and confident landings on a variety of field surfaces.
Designed to balance scale authenticity with everyday flyability, the FlightLine 1600mm P-51D Mustang offers predictable handling, excellent visibility, and the kind of smooth, flowing flight that suits the Mustang’s legacy. Whether flown in wide, graceful passes or displayed as a centerpiece in the pits, this is a Mustang that delivers size, style, and substance without compromise.
| Commanding Mustang Presence With a 1600mm wingspan and true 1/7-scale proportions, the P-51D Mustang commands attention on the ground and in the air. Its unmistakable lines and stance deliver the presence expected of a large-format warbird. |
| Factory Finished, Builders Choice The airframe arrives fully painted from the factory, showcasing crisp panel lines and a clean, scale-accurate finish. Four complete marking options are included, allowing builders to choose their preferred livery during final assembly, with “Frenesi” serving as the flagship scheme. |
| Screwless, Quick-Release Wings Spend less time in the pits and more time in the air. The P-51D Mustang uses screwless, quick-release wing mounts that make field assembly fast and convenient. Transport is easy, and setup takes only minutes. |
| Scale Gear, Real Confidence Electric retractable landing gear, including the tail wheel, feature CNC-machined scale shock absorbing struts and cycling gear doors for authentic operation. Large 95mm main wheels improve ground handling and make the Mustang well-suited for grass and uneven field surfaces. |
| Realistic Details Brought To Life Integrated LED navigation lights and switch activated simulated gun muzzle flash LEDs in the wings add realism and enhance visibility in the air. These functional details bring the Mustang to life both on the ground and in the air. |
| Built Scale, Tuned For Performance Functional flaps reduce approach speeds and improve landing control, while the tuned airframe minimizes torque effects during takeoff and landings. Combined with an accessible sliding battery tray for quick swaps and easy CG adjustment, the Mustang is built to fly as confidently as it looks. |
- Large-format P-51D Mustang with 1600mm wingspan and 1420mm length for commanding scale presence
- Designed at approximately 1/7 scale, balancing visual impact with stable handling
- Factory-finished airframe ready to receive four included marking options, with “Frenesi” as the flagship scheme
- Integrated LED navigation lights enhance visibility and scale realism
- Functional simulated gun LEDs in the wings add authentic WWII combat presence
- Screwless, quick release wings and auto-connect wiring make field assembly a breeze
- Accessible sliding battery tray allows quick battery changes and easy CG adjustment
- Scale 4-blade propeller (16x12) enhances realism and performance
- Proven multi-material construction combining EPO foam, plastic, plywood, carbon reinforcement, and aluminum structure
- Predictable and controllable ground handling for smooth takeoffs and landings
- Functional electric retractable landing gear (including tail wheel) with scale cycling gear doors
- Large 95mm main wheels improve operation from grass and uneven field surfaces
- Functional scale flaps reduce landing speed and improve approach control
- Optional drop actuator support for scale fuel tank or other payload drops
- Carefully tuned design minimizes torque effects during takeoff and landing for improved directional stability
- Factory-installed 5055 brushless outrunner motor compatible with 6S power systems
- 80A brushless ESC matched for smooth, reliable power delivery
- Ball linkages on all control surfaces provide precise handling
- Long-lasting nylon hinges built for reliable performance
- FlightLine P-51D Mustang 1600mm (63”) Wingspan Warbird - PNP
- Electronic, CNC machined retractable landing gear and cycling gear doors (installed)
- Factory-installed digital servos (3x 9g plastic gear, 1x 9g Hybrid, 2x 9g metal gear, 5x 17g metal gear, 1x 23g metal gear)
- Factory-installed Daylight-bright LED lighting system and functional wing gun lights (installed)
- Motor and ESC (installed)
- Instruction Manual
- 6-8 Channel radio - select a minimum 6-8 channel radio from our Radio Collection
- 6-8 Channel receiver - select a minimum 6-8 channel receiver from our Receiver Collection
- 6 Cell 22.2V 4000 - 6000 mAh LiPo Battery with EC5 connector - we recommend the Admiral 6 Cell 5000 mAh LiPo battery
AGE LEVEL : 14 and Up
SKILL LEVEL : Intermediate
BUILD TIME : 2 Hours | Model Scale | 1/7 Scale |
| Wingspan | 1600mm / 63in |
| Length | 1420mm / 55.9in |
| Weight | 3270g / 115.4 oz (without battery) |
| CG (Center of Gravity) | 120mm (4.7") as measured from the wing root leading edge aft |
| Power System | 6S 5055-340Kv Brushless Outrunner Motor (included) |
| Electronic Speed Control | 80A, EC5 Connector with reverse thrust (included) |
| Propeller / EDF | 18x12 4-Blade Propeller (included) |
| Servos |
| Landing Gear | Electronic retractable main gear with all metal shock absorbing struts and retractable tail wheel with scale plastic details (included) |
| Required Battery | 6S 22.2V 4000-6000mAh LiPo with EC5 connector (required) |
| Required Radio | 6-8 channels (6 for flight; +1 per optional feature: Muzzle Flash, Thrust Reversing) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | Yes |
| Brakes | Thrust Reversing |
| Gyro | No |
| Hinge Type | Nylon |
| Material | EPO Foam |
| Skill Level | Intermediate |
| Build Time | 2 Hours |
| Recommended Runway Surface | Well manicured, short grass and hard surfaces |
