OT............What is that chrome cone shaped flange serving as a collar/washer on the head of the socket head screw used as slide stop on the strut you pictured??
Flightline RC Tigercat F7F
HSD Skyraider FlightLine OV-10 FMS 1400: P-40B, P-51, F4U, F6F, T-28, P-40E, Pitts, 1700 F4U & F7F, FOX glider Freewing A-6, T-33, P-51 Dynam ME-262, Waco TF Giant P-47; ESM F7F-3 LX PBJ-1 EFL CZ T-28, C-150, 1500 P-51 & FW-190 -
THANX...........Never seen them before..............those are SWEET.............gotta get me some.:Cool:Socket head washers
yes Sir, it slides in this application.
https://hobbyking.com/en_us/sockethe...___store=en_usWarbird Charlie
I'm gonna go with the stock gear for now, might get the upgrade if I feel I need to. But at the moment, I'm gonna give it a try on the stock wireComment
Stock gear works fine! Nice to have the upgrades for rougher landing surfaces, but I never had any trouble with my stock gear, until I tried to remove it that is..........
Grossman56Team Gross!Comment
A real easy flyer!
I went the 15/30 degrees for flaps. At 15 degrees, she didn't need any elevator mix and at 30 just a bit, she'll land without any flaps regardless, just comes in a little hotter.
Got her up and complete, just waiting for the batteries, even have the parallel adapter made and installed. Was hoping I could have done it direct to the esc wires. But wouldn't work since I have to remove the wings for storage and transport1 PhotoComment
Hmmm, parallel adapter ...
That actually makes sense, given that if you loose a battery for whatever reason, you won't lose a motor....
Have to run that one by CB.
Yes, actually, I think we both came to the same conclusion after he and I both lost our P38s to battery failureComment
You don't have to run that by me.............I have documented my voice on many of the twin engine airframe threads about running the batteries in parallel.
I REFUSE to have independent power sources per side. It is just asking for trouble :Scared:Warbird Charlie
Bingo! To heck with losing a plane on a cell failure or anything like that. Redundancy is the key to sucess. However esc fails and you're still screwed. But for the most part, it's the same chance you take with single engines as well as twinsComment
"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
I hear you CB, makes good sense to me as well... So what did you use??
What I've always done with ALL the twins.............parallel the ESC power leads into one connector and have a parallel adapter for the batteries.
One connector from the 2 batts into one connector for the ESC's. The ESC's/motors see the same voltage and thus no surprises.
If you get a cell go bad or you just become dumb about your time to where LVC is hit both motors come down and you dead stick like a any single in the same scenario.
My only exception was the A-10 and that was because the EDF's are so close to the fuselage that I wasn't concerned about the yaw of the powered side like the prop driven twins.Warbird Charlie
There is no way to 100% guarantee you won;t have a "single-engine-out" You can reduce the chances, but not eliminate them.
I've had a motor spit the collet based prop adapter. That one is not too bad because you don;t have a windmilling prop to add drag to the side with the inoperable power system.
I've had one pull the engine mount off the firewall... fortunately pulling one motor wire loose so the motor didn't just keep chewing up the wing. TONS of drag with the motor hanging at an odd angle and the prop ticking against the wing and wheel.
Its nice to do stuff that reduces the chance. But its a good idea to practice some single-engine-out flying anyway.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
