Flightline RC Tigercat F7F
  • PappaBear
    • May 2015
    • 377
    • California
ID:	74165Click image for larger version
ID:	74166Click image for larger version
ID:	74167Click image for larger version
ID:	74168Click image for larger version
ID:	74169Click image for larger version
ID:	74170Click image for larger version
ID:	74171Click image for larger version
    The latest offering from Flightline RC is the Grumman F7F Tigercat This new model is a similar size to the P-38 with a wingspan of 63". It is the same excellent quality we have come to expect from Flightline RC.
    At this point, I would recommend you carefully check the model and make sure you are 100% satisfied with the operation of all the controls and servos before you begin the assembly. In doing that if you have a problem and you need to return the model to Motion RC you will be able to pack it in the box. Once the rear of the fuselage is glued to the front section it will no longer fit in the box.
    I assembled the model in a slightly different sequence to that called for in the instruction manual. I will explain what I did and the reason for it as I go through the assembly of the model. The first thing to do is to assemble both of the propellers. These are the same style as the P-38. One is clockwise rotation and the other is anti-clockwise. They are simply held together with sheet metal screws. They go together very easily and when the decals have been applied they really do look the part.
    It's at this point I deviated from the instructions. The instructions state to fit the propellers to the motors and then install the units to the wings. I didn't do this, for two reasons. First I want to make sure the motors run correctly and to be safe I don't want them fitted to the motors to carry out the tests. Also, they could get damaged while fitting the motor nacelles to the wings.
    I chose to test the servos and connect all the pushrods required in the wing. These included both ailerons and four flap servos. I connected the servos to a servo tester and cycled the servos for a few minutes to makes sure they were going to be reliable. The servos should be cycled before they are connected to the control surfaces, and the control surfaces should be checked for free movement through the entire range. I intend to use a Spektrum DX8 to fly the model and a Spektrum AR8000 RX. I connected the RX to the servos and used a 4.8V battery to center all the servos. I then connected all the push rods and adjusted the control throws. I found it easier to do all this now than after the engine nacelle has been fitted to the wing.
    The nacelle has to be attached to the wing next and this is simply bolted to the wing with four screws that screw into hard points installed in the wing. The wires for the retract unit and the ESC are routed down a channel in the underside of the wing. I tested the motor and the retract unit for correct operation before fitting the whole unit to the wing. When you are satisfied with the operation Both left and right wing assemblies are now ready to fit to the fuselage.
    The next stage is to fit the two halves of the fuselage together. The rudder and elevator servos are located in the rear section of the fuselage and the leads have to be routed through the front half to locate in the correct position. However, before joining the two sections together I checked both servos for correct operation and again cycled them a few times to make sure they are going to be reliable. I tried a length of string to the servo leads and fed it through the front half of the fuselage before I glued the two together. This also prevents glue sticking the leads to the fuselage.
    It's a good idea to fit the wings to the fuselage before gluing the fuselage together. With the wings in place on the fuselage, it is a simple job to turn the rear half of the fuselage left or right to align the wings and the horizontal stabilizer together before the glues sets. This will make for a perfectly straight model. The horizontal stabilizer fits to the fuselage on a carbon fiber tube and it is secured to the fuselage with four small screws, two on each side. I fitted my RX inside the fuselage close to the main control board, and the satellite RX ahead of the main one. I used double sided sticky pads for both.
    The decals are fairly easy to apply. Three different color combinations are supplied with the decals. This model does not include a lot of small decals that require a lot of time and attention to fit.
    All that is left to do now is to balance the model and go and fly. The two batteries are located in the front of the fuselage, one behind the other.
    The first take off and landing was really a non event. I was really very surprised at how well this model flew right off. I did not use flaps for the take off or landing. I can say the model flies really well and I would recommend it to anyone who is looking for something a little different. As you can see from the photos above the model does look very realistic in the air.
    Martin.
  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    One thing I plan on changing is the direction of rotation of the motors, the P38 correctly rotates the props away from the fuselage, the real Tigercat rotates toward the fuselage.
      DK.......Actually the full size didn't have counter rotating props.
        Watch for this distortion around the nacelle mount, if it's like this trim it off so it will sit flush against the mount.
        ...I used a control rod to pull the rear servo wires through the fuse.
        • dkalwishky
          Warbird Lover
          • Sep 2015
          • 1382
          • Des Moines, IA
          You are right, not sure what I saw that made me think the full scale plane did.
          • Silver Kiwi
            Delta Innkeeper
            • 3
            • Florida
            I believe that you are correct. The propellers should rotate toward the fuselage as this keeps the total thrust closer to the centerline of the aircraft which is critical for a twin engine airplanes as it keeps the Vmc (velocity of minimum control) lower when operating on one engine. This would not be a problem for an electric powered model most of the time except when one motor doesn't produce the same RPM as the other. This is the case for my newly purchased F7F Tigercat. Grrrrr......the left motor turns 1,200 RPM slower than the right and makes it a real bear, no pun intended. Add the fact that the rotation of the motors isn't correct and it now becomes a real problem. Electric motors of equal KV should turn the same RPM with batteries of the same voltage, right! I haven't yet checked to see the Wattage output of each but as of now I have no clue for the large RPM difference. I would love to hear others comments.
              Hello SK and welcome to the Squawk,
              If you've got a 1200 rpm(almost 15%) difference between your two motors then their is an obvious problem(read defect) with the slower motor.
              If you've had the plane less than 30 days, give Motion a call 224-633-9090 or open up a support ticket(link below) to get this problem resolved.
              Best regards,
              • dkalwishky
                Warbird Lover
                • Sep 2015
                • 1382
                • Des Moines, IA
                Watch this video of a real one starting, no counter rotating propellers.
                • Silver Kiwi
                  Delta Innkeeper
                  • 3
                  • Florida
                  Sorry, I didn't mean to suggest that the full scale aircraft had them. It's just that our model does and I think that changing the rotation on the motors would help greatly in order to keep the total thrust closer to the aircraft centerline thus lowering the Vmc and helping with directional corner at low speeds or if the motors aren't turning at the same rpm. Thanks for your input.
                  • Beeg
                    • 1335
                    • Texas
                    When's the next batch of Tigercats due in? Is there going to be a V2?
                      Beeg...........curious as to why your asking about a version 2? I haven't seen that many things wrong that would even justify a rev bump and besides that, FlightLine isn't FMS ;)
                      • Beeg
                        • 1335
                        • Texas
                        Oh, it was just mentioned some time ago. Not really important just need another Tigercat really.
                        • Beeg
                          • 1335
                          • Texas
                          Are more Tigercats coming on a separate boat or are they coming with the Spits and Avanti's?
                            • Nov 2013
                            • 2789
                            • Cody, WY
                            I agree with OV 10. The Tigercat used two standard P&W R2800 engines, They both turned clockwise as seen from the cockpit. I believe that is why they increased the size of the vertical fin and rudder over 20 percent from earlier models, in concern for single-engine performance and controllability.
                            • Silver Kiwi
                              Delta Innkeeper
                              • 3
                              • Florida
                              Best regards,
                              As an update to your suggestion, I have contacted Motion and they have been most helpful. They have agreed to send a new motor to replace the slow turning original one. We are not sure yet if it is the motor or the esc that's the problem but this is the first step. The bad news is that the motor isn't in stock and I have to wait to give this beautiful plane another try. I also will reverse the rotation on the motors and swap sides on the props to get them to rotate toward the fuselage.
                                • 7434
                                Hey Kiwi, first of all, welcome to the Squawk. Sorry to hear of your frustrations. Motion will get it straightened out as quick as they can, they're that type of company. The motor is the same size/type as the one in the P-38 if I remember right so that could explain the lack of stock. Also there's possibility of one of the guys having a spare because they've done the power upgrade. Anyone out there have a spare??
                                  Hello SK,
                                  I notice you mentioned that your unsure whether it be the motor or ESC. I really doubt that is the ESC but to further help alleviate any of your concerns about that, a simple check is to swap the ESC's from the bad powered side over to the good side and vice versa and see if the results swap over too. This will absolutely provide you with the validation of your faulty device. There have been some low level volume of reports regarding this motor being defective and the opposite for the ESC's which are a new proprietary design for these twin motor FL birds. I had a bad motor on my Lightning and Tigercat and Motion took care of it without question, which again is another testimonial on why they are at the top of the list for customer satisfaction.........Bar None !!
                                    • 7434
                                    Can't wait to order this one. Have the decals here, the paint here, the pearlescent clear coat. Just waiting for the credits to come through and the planes to come back in stock...Then she's mine!!!
                                    • Beeg
                                      • 1335
                                      • Texas
                                      Grossman, any idea when they'll be back in stock?
                                        • 7434
                                        I haven't heard anything, but I don't get that inside info. Maybe Tom or Mark or even Martin might know. Anyone have an update?
