    Originally posted by bikerGus View Post
    Thanks all for the tips.
    I purchased an Eagle A3 L V2 3 axis gyro to install... has anyone else installed a gyro in the Spitfire or is it not worth the addition of another potential failure point between servos and receiver?
    A gyro can't hurt. I have the Spectrum AS3X receivers in all my planes, including my fleet of 3D planes. As Grossman56 points out, you can always turn it off. I generally use gains in the 45% range for flying and when deploying flaps for takeoff or landing, it's cranked up to 85-95%. Does the Spitty need a gyro, no, but it does smooth it out for gusty crosswinds. In a calm day, it has no affect.
    It was worth it in my opinion. I still had an A3 which gave me Sport and Safe as opposed to Sport and 3D with the A3L. I was having trouble with the airplane until I added weight to the front to move the CG forward she kept wanting to swap ends, didn't know what that was like until the Spitfire. Anyway, with the addition of the A3 and the extra weight she flies like a dream now.
    BTW, just turn the 3D screw all the way off as it isn't going to help you anyway. I have my gain for the Sport mode at 100% and the gain assigned to the knob of my radio, which I usually start at around 40%.
  • bikerGus
    I might be over thinking the blue box lights connectors... just didn’t want to burn out the bulbs.
    Brushing a light coat of minwax to prevent the decal backing pulling off the paint makes sense. Followed by a coat over the decals.
  • Gringotuerto
    Originally posted by Grossman56 View Post
    As the famous Barbeque sauce commercial says, "I put this #### on everything!
    It is probably good as a general coating, but I have also used this just on small areas when I want to put Callie's decals on painted foam. Sometimes the decal backing will pull paint off the foam. If you give the decal area one coat of poly urethane and let it dry before applying the decal, then this doesn't happen. If you match flat/satin/gloss to the rest of the model, you don't even need to cover the entire model, you can just cover the area around the decal and the polyurethane boundary won't show.
    Click image for larger version  Name:	027426359055.jpg Views:	0 Size:	97.5 KB ID:	305278
    The can is the same, it just says 'clear gloss' on it. I find that if you want the most glossy, use a brush, slightly less, use a spray gun. If you want a flat finish, buy the matte version and shoot it on with a spray gun. I would still use the gloss initially to seal in the decals as my experience has shown that the matte finish doesn't seem to seal in the decals, at least not as well as the gloss. As for rattle cans, I can't say as I have no experience with them.
    Results?
    Click image for larger version  Name:	IMG_8927.JPG Views:	0 Size:	123.2 KB ID:	305279Click image for larger version  Name:	IMG_9678.JPG Views:	0 Size:	174.0 KB ID:	305280
    No, the Mustang is Flite Metal, but the wings are Spar Urethane as P-51's came from the factory with painted wings.
    First time post... question on the blue box reference post #2460... Grossman56 provided the light plugins for the wing tips go to the “Strobe-Light” connector and beacon strobe go to the “Wing-Light” connector because the Flightline User Manual is wrong. Correct?
    next question: are the right wing and left wing retract plugs connected on the same side of the blue box in “Landing -Gear 1” and “Landing -Gear 2” ? (Spit has no landing gear doors so nothing connected to “Landing-Gear Door 1/2/3 blue box)?
    last question: is it recommended to paint the whole plane with a brushed on coat of minwax before installing the decals, followed by a second coat to seal the decals?
    Having read all 148 pages, thanks to all posters for the good information.
    just returned to rc flying after a 25 layoff, purchased the Spit after relearning how fly on a Sig Kadet Senior and an Eflite Air Tractor.
    bikerGus
    Clear Coat after everything is on, including graphics. I like to do 4 lite coats so there are no clumps or hardened drips. Spray is better, gets more even coats, but requires a lot more masking of areas that you don't want this stuff on and you need to be careful on vertical surfaces (rudders) and wing edges, which is why an even lite coat each time is preferable. I use the Varathane Spar Urethane clear gloss exterior water based and like that, but I'm sure the MinWax is just as good. Make sure it is the Exterior (resists yellowing in the sun) and the water based (not oil based).
ID:	305122Click image for larger version
    It's been a while since I played around with mine, but I do remember the strobe light being wrong in the manual. However, when I rewrote the Spitfire Online manual, I believe is is the correct version, again, been awhile...
Name:	flight control board.PNG
ID:	305114 when it comes to the landing gear, go with "landing -Gear 2, port for port side and starboard for starboard side. If you use any combination of 1, 2 or 3 you'll get a delay on one side. I set mine up like that and took a video.
    Hope that helps
  • bikerGus
    bikerGus
  • kallend
    This week marks the 85th anniversary of the maiden flight of the Spitfire.
    Header image: Spitfire prototype K5054 at Eastleigh in the unpainted state in which it flew for the first time in March 1936. Eighty-five years ago this month a momentous event took place with the first flight of the Supermarine Spitfire prototype, K5054, from the company’s airfield at Eastleigh, Southampton. At the time, those present could not have realised the full
  • RodgerC
    Has anyone ordered a Motion RC plane and had it delivered to New Zealand or Australia lately? Just wondering how long delivery would be if I ordered the Corsair (I already have the Spitfire). I am aware due to COVID deliveries are taking longer than usual.
    Got some RAF formation flights in with RudyD54 and his Spitty today. What a blast flying these 2 together, getting 7-8 minutes in the air. Truly an outstanding flying aircraft, thanks MRC. And oddly enough, I didn't even hit him in the air. Oh well, next time I'll try harder. He's probably safer if I fly trying to hit him than trying to avoid him cause I seem to never be able to fly where I want!
    And in the photo it's his that is the more "scale" of the two, big surprise, right? Got to fly a bunch of others as well.
ID:	295593Click image for larger version
  • Beetlemankurt
    Thanks Chaps! :)
    Kurt
    Originally posted by Beetlemankurt View Post
    I finally got my aces of iron pilot and the cockpit kit in! You can’t see much of the detail in the cockpit kit in the photos but if you peer really closely through the glass in person you can.
    Overall, I’m really pleased with the extra detail it adds.
    Kurt
    The detail in the cockpit actually shows quite well, great work and detail on the pilot, outstanding!
    Well, it been a while since I posted...Now I’m on holiday I finally got my aces of iron pilot and the cockpit kit in! Overall, I’m really pleased with the extra detail it adds. Happy New Year everyone!Regards, Kurt
    Kurt, Truly well done, Sir. Good Hunting. Best, LB
  • Gringotuerto
    Looks good, well done! (Edit : also I looked up history of that plane - interesting, good choice).
  • Beetlemankurt
    Well, it been a while since I posted as work has been crazy busy and I’ve been spending some time doing RC Trucking which is also massively fun.
    Now I’m on holiday I finally got my aces of iron pilot and the cockpit kit in! You can’t see much of the detail in the cockpit kit in the photos but if you peer really closely through the glass in person you can........
    Overall, I’m really pleased with the extra detail it adds. Just need to rebalance as I’m not too sure what effect it’s had on CG and I’ll be able to take to the skies again. enough talking, here’s some pics .
    Regards
    Kurt
    Click image for larger version  Name:	695F4D75-087B-4495-8CD3-FBB1300D097C.jpeg Views:	0 Size:	105.8 KB ID:	293176Click image for larger version  Name:	A1A10577-B7EE-4257-88B8-384F9F2E329F.jpeg Views:	0 Size:	93.2 KB ID:	293177Click image for larger version  Name:	7D252D73-0F32-434C-B676-D8A3FF897E99.jpeg Views:	0 Size:	115.3 KB ID:	293178Click image for larger version  Name:	AB771E7D-4DD6-46F5-BBDB-7D5CAA4F577A.jpeg Views:	0 Size:	313.7 KB ID:	293179
    Loose with the screw so you can take the wing off.
  • Jeffco
    I've assembled it, fitted the 5000 Admiral battery and it balanced at 90mm back.
    This air intake, do you glue it onto the wing or leave it loose to be fixed with the screw?
  • paulrkytek
    Good luck Jeffco,, with the hard runway touch down on the mains and let the tail settle on its own as it slows down., just cut the throttle as the wheels touch, no flaps required..
  • Jeffco
    Thank to you all for the advice. I'll let you know how I get on. Paul, I'll PM and phone you if necessary but your description of what to do is very clear.
    I've not checked CG yet, but will let you know how it is with my Admiral 5000 battery set as far forward as possible. This is my first 6 cell prop plane, as I bought these batteries for the Avanti.
    Chichester club has a hard runway so nosing over won't be such a risk. But I can't fly right now otherwise I'd have had it finished by Boxing day.
    I have some of the foaming type Gorilla glue which I use to re-stick gear boxes, and I may try and get some to flow in via small drilled holes.
