Official Dynam 1270mm Waco Yellow Thread
  • boomer108
    Chief Boom
    • Apr 2014
    • 868
    • Chicago IL.
    Wait till you fly it you'll have a blast. I especially like doing touch & go's with mine.
      I concur ;)
      • Hoomi
        Cactus Dodger
        • Apr 2018
        • 863
        • Baja Arizona
        Alas, Tucson has been having an unusual amount of wind lately, so not much flying the last couple of weeks. :(
          Dang that's a bummer man :(
          • Hoomi
            Cactus Dodger
            • Apr 2018
            • 863
            • Baja Arizona
            The rigging is done, and I'm very pleased with it. The tail rigging is elastic cord from the fabric store, threaded through small holes punched in the rudder and horizontal stabilizers, and secured at the bottom in small holes poked in the fuselage. Where the cord passes through the surfaces, I added a drop of flexible CA to secure it.
            The wing riggings are made of small wire actuator or control cables of some sort that I found in a surplus many years ago, and thought they looked useful. They've been sitting around ever since, and they struck me as the perfect thing to make the riggings. The springs are from Ace Hardware, and I used photos of real Waco YMF-5D's from the Waco Aircraft Company website for placement. About the only thing missing are the two short lines that stretch from right in front of the foreward cockpit to the upper wing, and those would be problematic with that portion of the model being the battery hatch.
            My pilot is still incognito until the decorating is completed, and the plane is ready for the full reveal.
              Wow! That looks great!
              • Prowler901
                • 940
                • Gunnison, CO
                Woah! Great job on the cables. :Cool:
                • Hoomi
                  Cactus Dodger
                  • Apr 2018
                  • 863
                  • Baja Arizona
                  I'm glad I wasn't working on a model of the J-1. Dang, looking at photos of those, I'd need about two weeks just to work on the rigging alone!
                  • Dual Prop Dave
                    Just another Prop Nut!
                    • 144
                    • Sunbury,Pa
                    Absolutely a stunning job Hoomi! That looks fantastic! :Cool:
                    • boomer108
                      Chief Boom
                      • Apr 2014
                      • 868
                      • Chicago IL.
                      Looks great Hoomi!:Cool:
                      • Hoomi
                        Cactus Dodger
                        • Apr 2018
                        • 863
                        • Baja Arizona
                        My custom decals are on order from Callie, so that should be the last bit I need for the Waco.
                        • Pauly
                          Just Fly It
                          • Apr 2015
                          • 469
                          • Warsaw, NC
                          Hoomi, what kind of decals are you putting on?
                          Still Learning:D
                          • Pauly
                            Just Fly It
                            • Apr 2015
                            • 469
                            • Warsaw, NC
                            Hey guys, I've been slack here, but have been a little busy lately and sad to say as excited as I was to get me a Waco, it's still sitting in the box. My question really is, is there anything special I need to know or do before I get build this plane? All I've heard is how great it is and will be using a 4s 3000 battery.
                            Still Learning:D
                              Only thing that I would recommend is that the cooling of the motor/ESC is problematic.
                              I cut the webbing between the two bottom faux cylinders which allows airflow directly into the bottom channel in the fuselage where the ESC is located.
                              No over heat issue since the easy mod which has been better than 4 years now.;)
                              • Hoomi
                                Cactus Dodger
                                • Apr 2018
                                • 863
                                • Baja Arizona
                                That'll be revealed when it's all finished. ;)
                                As I've mentioned a couple of times on this topic, the instructions for the Dynam Waco leave a lot to be desired. I found it very useful to go over to YouTube and watch a couple of build videos. The two-part build video from RCPlaneviews.com over on YouTube were pretty decent.
                                • BluesDragon
                                  RC Planes Fanatic
                                  • 574
                                  • Arizona
                                  Beautiful work there, Hoomi! Looks fantastic... can't wait for those shots in flight.
                                  We've been getting those winds over here in the east valley as well. Totally blows (pun intended), but can find a few good hours throughout the day to sneak in a flight or two. The UAV Forecast app is great for keeping an eye on the winds by the hour, at ground level as well as at higher altitudes. I've been using the hell outta that app these passed few weeks.
                                  Dynam; E-Flite; Freewing
                                  • Hoomi
                                    Cactus Dodger
                                    • Apr 2018
                                    • 863
                                    • Baja Arizona
                                    The decals from Callie arrived today, and look fantastic on the Waco. A couple more minor details, and I'll be ready to post the finished photos, and take her out for a maiden flight.
                                    I should practice with the taildraggers a bit more on Realflight before then. This will be my first experience flying a taildragger in real life, and after as much work as I put into this, I don't want to mess it up on the first flight.
                                    • Pauly
                                      Just Fly It
                                      • Apr 2015
                                      • 469
                                      • Warsaw, NC
                                      I look forward to seeing it Hoomi
                                      Still Learning:D
                                      • Hoomi
                                        Cactus Dodger
                                        • Apr 2018
                                        • 863
                                        • Baja Arizona
                                        And here she is - Air Hooterville, with your pilot, Arnold Ziffel.
                                        If it confuses you a bit, you're probably a bit too young to get the reference.
                                        The "Air Hooterville" and plane numbers are from Callie's Custom, while my better half made the flying pig decals on her Cricut. The pilot name (with my AMA number, since many clubs like the AMA number on the plane some place), was done on a basic Brother P-touch label maker.
                                        Bonus points for anyone who gets the significance of the plane number.
                                        The inspiration for the design grew out of discussion with a coworker on different amusing pilots I could put in the plane. Snoopy is always fun, but between this not being a Sopwith Camel, and that others have done it, I passed on that idea. Muttley, from the "Dick Dastardly" cartoons, would have been fun as well, but finding a workable figure from that old a cartoon wouldn't be real easy. We then joked about "when pigs fly," which led to some bantering back and forth, until I hit on the idea of Arnold Ziffel. Since Arnold was never a real large pig in the series, the smaller figure from the toy section works. His goggles (which I need to get a better photo of) are made of double-layered heat-shrinkable tubing and flat black lacing, while his scarf is simple white ribbon.
                                        This has been one heck of a fun project, and I'm looking forward to a chance to get Air Hooterville airborn for her maiden flight.
                                          Green Acres ran from 1965 till 1971.
                                          I love it, Ziffel was awesome:Cool:
                                          I have Lisa in mine...;)
                                          Click image for larger version  Name:	Waco_iOS.jpg Views:	1 Size:	263.0 KB ID:	135594
