Official Dynam 1270mm Waco Yellow Thread
  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    Yikes! I hate the wind. We get a lot of that in the Spring here.
      • 7405
      Can you believe it, it's 55 degrees outside and the snow is melting so fast you can almost see it. Of course the wind is up as well, but who cares, I SEE GRELOLEN!!!
      :Sleeping2:of:p51:spitfiresoon!!
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        I think dkalwishky will win. I've never seen a warmer winter here. Well.. except for the WIND! Doc
        • doctormike
          • Oct 2013
          • 1260
          • Santa Fe NM
          Just received my Dynam Waco. Wow! It's big and beautiful! No factory applied decals. Great! My mind is abuzz working on my paint scheme. Only cons are... the horizontal stab is warped and the elevator just snapped off. Pin hinges or E6000. Not sure yet. Every Dynam plane I have bought has had warped wings and/ or stabs. When I get replacements, they are warped exactly the same. Must be in the molds. If you want their great scale atributes you have to deal with warps, bad foam hinges, prop shafts snapping off when you simply tighten them, etc. etc. For the most part I am very happy with it. I hope it will have enough power to fly at 7000 ft. Doc Oh...WARNING! Put Foam Tac or E6000 on all your foam hinges!!! :Loser: Addition....... What's with the red landing lights and clear navigation lights?!!!! I guess they just grab some lights from a pile and slap 'em in.:Confused:Doc
          • SfC Wade
            High Altitude with Attitude
            • 39
            • WV
            Can you use a 3 cell in this?
              NO...........would require you change out the motor to a higher kV
                OV10 is right on the money, we highly recommend flying the Dynam Waco with its recommended 4s battery.
                • SfC Wade
                  • 39
                  • WV
                  Thanks Guys! 4 Cell Roger That!:Cool:
                  • dkalwishky
                    Warbird Lover
                    • Sep 2015
                    • 1382
                    • Des Moines, IA
                    In a crazy series of weather I'll be maidening tomorrow. It hit 75 today in Iowa.
                      Good luck with the maiden. You're going to like how she flys. Send some of that weather our way.
                      • Shoetec
                        • 2
                        I love the Dynam Waco I got last year. I fly it with 3000s and 2200s and, aside from flight times, I honestly can't tell the difference. Both go up to the hole in front. The warped tail feathers annoy me to no end but don't seem to effect flight. Mine were packed in the same box as the wings. I believe they got mis-shapen from being wrapped around the wing's airfoil. Really unnecessary because there's room in the big box to pack them separately. Putting together my third Dynam, the Gee Bee right now.
                          Fixing the tail feathers is pretty easy and well worth the half hour to do it.
                          All you have to do is CAREFULLY apply a little heat from a monocoat heat gun or even a hair dryer. Start with the heat source at least a foot away and start to warm the warped surface up. Don't hold the heat source still in one spot. Move it around to warm the whole area of the surface.
                          Then, with your hand, carefully flex the warped area of the surface in the opposite direction of the warp while keeping the heat on the area. Less is more here. It's easier to adjust it a little further with another application than to have to go back the other way. Continue with the heat for a minute or so. Just be sure not to get the heat too close or you will "alligator" the foam. One rule of thumb I use is "if it's too hot for your hand, it is likely too hot for the foam".
                          Continue to hold the flex and remove the heat and when the surface is cool then release the pressure. Check your progress and repeat if needed.
                          • dkalwishky
                            Warbird Lover
                            • Sep 2015
                            • 1382
                            • Des Moines, IA
                            Yesterday was a spectacular day in Iowa, we set a new temperature record for the day of 67 degrees and winds under 5 mph. I'm using Admiral 3600 4 cell batteries. The plane balances well and at full power I get a solid 5 minutes of flight time. Checking the battery after I land I see cell voltage in the 3.7 volt range.
                            The plane flies very nice at 50 - 75%, take offs and landing are really easy, this plane will go to the field most days with me. She really flies nice, if I were to crash this plane I would order a replacement as soon as I got home.
                            I give it 5 stars, completely happy with the plane and flight characteristics.
                            • wvrailfan
                              • Sep 2013
                              • 682
                              • West Virginia
                              Glad the maiden went well. It is a sweet and under rated model.
                              Jim
                              • Prowler901
                                • 940
                                • Gunnison, CO
                                Congrats of the maiden! She's a great little flyer isn't she.
                                • dkalwishky
                                  Warbird Lover
                                  • Sep 2015
                                  • 1382
                                  • Des Moines, IA
                                  Yes she is and I agree with Jim, it is an underrated plane. I put seven flights on it Saturday.
                                  • doctormike
                                    • Oct 2013
                                    • 1260
                                    • Santa Fe NM
                                    Great news! Can hardly wait to get mine in the air. Doc
                                    • jagilly
                                      Excellent airplane and so much fun to fly. I have had two of them before moving on to other other models. I would only suggest you run at least a 60A ESC with the 4S 3600 batteries. The motors seemed to get quite hot on both of mine until I upgraded the ESC. Just sayin'. Enjoy!
                                        Welcome to Hobby Squawk jagilly. The motors can get warm. What I did with both of mine was to get better air flow to the motor. Open up the area around the motor opening by about 1/4". Then cut out some of the webbing between the cylinders. Just doing that put the motor temp back where it should be.
                                          On my Waco the only mod that I did for cooling was to take advantage of the air channel that is located at the bottom of the fuselage starting right below the motor mount.
                                          All I that I did was remove the webbing on each side of the very bottom center faux cylinder and that provides most excellent airflow for the motor and the ESC which is in that channel.
                                          Still going strong after 3+ years on the stock 40A ESC
